Test/Review of Nohon 3C usb charger
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 min ago
DSC_4015
Official specifications:
  • Input: 100-240VAC 50/60Hz
  • Output: 5.0V 1.0A
  • Model number: ETPCA-050100C2W
I got it from a reader
DSC_4011 DSC_4012
DSC_4016 DSC_4017
DSC_4019 DSC_4018
Measurements
  • Power consumption when idle is 0.07 watt
  • Usb output is coded as usb charger (DCP)
Nohon%203C%20usb%20charger%20load%20sweep
The charger is rated for 1A and overload trips slightly above that, this looks good.
Nohon%203C%20usb%20charger%20load%20test
I could draw 1A for 1 hour without any problems.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp3062
M1: 47,0°C, M2: 47,7°C, HS1: 52,3°C
HS1 is the transformer.
Temp3063
M1: 48,4°C, M2: 41,9°C, HS1: 49,0°C
Temp3064
M1: 51,1°C, HS1: 56,8°C
HS1 is the rectifier diode.
Temp3065
M1: 45,2°C, HS1: 55,5°C
Temp3067
M1: 50,2°C, HS1: 54,7°C
10ohm
Noise at 0.5A load is 18mV rms and 534mVpp
5ohm
Noise at 1A load is 23mV rms and 472mVpp
Tear down
DSC_4296
I could not open it with my vice, but instead had to cut it open.
DSC_4297
On the input there is a resistor used as fuse. notice how the transformer has an extension for the output leads (This improves the isolation distance). The white plastic secures good isolation between mains and low volt side.
DSC_4299 DSC_4300
The extension of the transformer is very visible here. It is also possible to see the switcher transistor beside the transformer.
DSC_4301 DSC_4302
The green part L1 is an inductor.
DSC_4298
On this side of the circuit board there is a bridge rectifier (DB1), a switcher controller IC (U1).
There is also a big rectifier diode just below the usb connector (D3).
Note the zig-zag trace beside D3, it works as a resistor and is placed between the two capacitors, probably to reduce noise slightly.
DSC_4303 DSC_4304
DSC_4305
The distance between mains and low volt side is nearly 7mm, this is enough.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
The adapter has good safety, can deliver the rated current and for a 1A device DCP coding is correct. I could have wished for slightly less peak noise.
Notes
I got the usb power supply from a reader for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
MRsDNF
MRsDNF's picture
Thanks HKJ.
