How about magnet wire…
9 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 1 day 29 min ago
… as driver to baseplate conductors?
I have a good deal of it “at hand” and, although i haven't found evidence of any other using it for this purpose, its characteristics seem pretty good for an effective routing of power where space is at a premium.
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Edited by: Barkuti on 05/09/2016 - 10:42
flydiver
Last seen: 4 min 7 sec ago
Should work. Coating integrity can vary a lot. Radio Shack for example is not very good. You need to be careful to clean the ends before soldering.
To Air is Human, to Respire….Divine.
Barkuti
Barkuti's picture
Well, sounds gnarly enough. I was anyway going to strip off the windings of an old AC transformer so, two for one. Since it's not going to undergo much rubbing, jostling and/or bending, it should be pretty fine (either that or I'll put the led on uncanny direct drive or short-circuit the batteries lol).
I presume a lighter is all I'll need to prepare the wire tips before soldering…
Cheers Party
flydiver
I scrape with a blade. If it’s good coating it’s pretty heat resistant, though a flame would take it off. But then you’d have burnt crap there and need to clean that off anyway.
Dimbo The Blinky
Dimbo The Blinky's picture
Last seen: 1 day 20 hours ago
That must be some transformer!
Assuming the wire gauge is sufficient to carry the current you’ll need, I’d have to guess the insulation is probably pretty ‘set’ by now & may not survive the trip to its new home. But, there’s always Heat Shrink…
I’d be curious to know the gauge of the wire you’re getting, and what transformer it came out of. Sounds like a good idea to me, within reason.
“There is no darkness but ignorance.”
scianiac
scianiac's picture
There are a few different coatings used, and from trying to remove them I can tell you some are nearly indestructible. It’s the hobby “EZ strip” stuff that burns off in a few seconds that you want to avoid, the industrial stuff requires a surprising amount of heat or abrasion to remove and is quite flexible.
Co-owner/Engineer at STO Flashlights.
Barkuti
Barkuti's picture
This…
… and the lady by the right, which uses AWG24 too at its secondary; pinkish coating. Pretty old, unused stuff.
Should do good.
Cheers Party
Dimbo The Blinky
So you’re looking at ~3.5A… Cool Looks good to me. Be sure to let us know how it works out for you!
Barkuti
Barkuti's picture
Aiming for 4'2-4'8A, 22AWG standard wire was somewhat unconfortably tight on my pill but this way I can use two AWG24 magnet wires in parallel because of its ovoid holes.
Cheers Party
