Test/Review of Charger GyrFalcon All-88 (Enova)
31 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
DSC_4318 DSC_4320
DSC_4319
Enova makes many different chargers, some time ago I tested many of them, include a 8 slot charger. This charger here is a completely new design that is a much more versatile charger. It can charge most types of round cells on the market. The reviewed version is a pre-release version.
The charger uses a very flat design, it is only 32mm high.
Front LeftSide back RightSide
UpSide
I got the charger before the box was finished, instead I got these renderings on how the box is going to look.
DSC_4317
Because I got the charger and a power supply a bit before the release date, there was no manual included.
DSC_4323
The DC input is the usual barrel connector and it is rated for both 12V and 24V input, making it possible to use the charger in a car.
DSC_4332
The display has many elements on it, because the charger can handle many types of cells.
DSC_4333
Here the charger is working with 3 different cell, each with its own setting.
The C.A line shows selected current and is also used to select current when the “>>” marking is at this line.
The V.V line shows selected charge voltage and is also used to the select voltage when the “>>” marker is flashing at this line.
The battery icon is animated when the charger is charging.
The display will automatic dim after some time, any button press will bring it back to full brightness.
DSC_4322
The full user interface with 8 readouts and 10 buttons, one for each slot and two special buttons. All buttons has a leds in them.
The slot buttons will show a green (blue in release model) led while charging and a red led when done.
Start a slot (Method 1):
Press button for slot to select it.
Press button for slot again to select voltage.
Press CV to select current setting.
Press button for slot to select current.
Press CV to select voltage setting again.
Hold button for slot down to start charging.
Start a slot (Method 2):
The above methods are rather long if you want to charge many cells, the charger has some shortcuts to handle that:
Hold button for charging slot down and tap button for other channel will copy the settings and start charging on the other channel.
Hold Fn down and press CV will select 1A and 4.2V charge voltage for all idle slots, pressing multiple times on CV will change voltage.
These short-cuts means that charging any number of (4.2V) 18650, 26650, 32650 can be started by holding Fn down and tapping once on CV.
Charging any number of AA can be starting by holding Fn down and tapping CV twice.
Due to the long display the brightness is not uniform in the display.
DSC_4337 DSC_4338
The sliders work very smooth and can handle from 30.0mm to 71.2mm, up to ø26mm cells can be placed in each slot and it is possible to use ø32mm cells in each other slot if they have a large top (i.e. LiIon will usual work, but not NiMH D cells).
Due to the wide slots, care has to be taken with thinner batteries to get a connection.
supportedBatteryTypes
supportedBatterySizes DSC_4451
DSC_4447 DSC_4450
The charger can handle 71 mm long batteries including flat top cells.
With 10180 cell the 100mA charge current is on the high side, but because most 10180 are high current cell it will usual be acceptable.
C cells has a tendency to slide of the plus connection.
Measurements on charger
  • Power consumption when idle is 1.5 watt
  • Will discharge a LiIon with 0.1mA when not charging.
  • Will discharge a NiMH with 0.03mA when not charging.
  • Will not charge at 0 volt.
  • LiIon charging start at 0.6 volt with a few mA.
  • NiMH charging start at 0.6 volt with selected current.
  • From about 1.5 volt to 3.0 volt it will charge with 50mA (All LiIon chemistries)
  • Above 3.09 volt the select current will be used
  • Meter starts working at 0.7 volt, but is first precise at around 1 volt.
  • Meter is within 0.03 volt.
  • Meter stops updating when battery is full.
  • Meter will not reduce reading.
  • Charger will restart silent if LiIon battery voltage drops below 4.05 volt.
  • Charger cannot be restarted with a nearly full battery.
  • Power cycling and insertion of a battery requires button press to start charging.
Charging 4.20V LiIon cells
GyrFalcon%20All-88%201A%20(PA18650-31)%20%231
A good CC/CV charge curve with about 100mA termination current.
GyrFalcon%20All-88%201A%20(PA18650-31)%20%232
GyrFalcon%20All-88%201A%20(PA18650-31)%20%233
GyrFalcon%20All-88%201A%20(PA18650-31)%20%234
GyrFalcon%20All-88%201A%20(PA18650-31)%20%235
GyrFalcon%20All-88%201A%20(PA18650-31)%20%236
GyrFalcon%20All-88%201A%20(PA18650-31)%20%237
GyrFalcon%20All-88%201A%20(PA18650-31)%20%238
All the other slots look the same, but there is a small variation in final voltage, it is within acceptable tolerances.
GyrFalcon%20All-88%201A%20(SA18650-26)%20%231
GyrFalcon%20All-88%201A%20(PA18650-34)%20%231
Different capacity means changes in charge time.
This charger has a fairly flat CV phase, this means the charging is as quick as possible. The higher voltage on the 2600mAH cell does not force the charger into a pseudo CV phase at an early stage.
GyrFalcon%20All-88%201A%20(BE18650-26)%20%231
This old cell reaches CV phase fairly fast.
GyrFalcon%20All-88%200.1A%20(SA18650-26)%20%231
The lowest charge current is 0.1A and the charger will adjust termination current down to about 13mA.
This current is mostly for very small cells, that requires the use of a spacer.
GyrFalcon%20All-88%200.5A%20(PA18650-31)%20%231
GyrFalcon%20All-88%200.5A%20(KP14500-08)%20%231
GyrFalcon%20All-88%200.5A%20(AW18350-IMR)%20%231
The 0.5A current is fine for 14500/18350 and other cells with 0.6Ah to about 1.3Ah and it works fine.
GyrFalcon%20All-88%201A%20(8xPA18650-31)
The charger can charge 8 cells with 1A simultaneous.
GyrFalcon%20All-88%201A%2012V%20(8xPA18650-31)
Doing this requires about 3.5A from the power supply.
Temp3113
M1: 43,5°C, M2: 45,9°C, M3: 44,6°C, M4: 44,3°C, M5: 45,5°C, M6: 42,7°C, M7: 42,7°C, M8: 38,4°C, M9: 49,0°C, HS1: 61,0°C
Some heat will be generated at this current, but the temperature is acceptable.
StartupLiIon
To start charging hold the button down for 1.5 to 2 seconds, the current will ramp up and the charging commence.
CurrentChangeLiIon
It is possible to change current during charge. To do that first press the slot button, then the CV button, now the slot button can be used to change current.
Charging 4.35V LiIon cells
GyrFalcon%20All-88%201A%20(LG18650-30)%20%231
The charger supports both 4.30V and 4.35V cells, I only did a test with 4.35V and it looks fine.
The way the tolerances (+/-0.05 volt) falls on this slots, means it could charge both 4.30V and 4.35V cells on the 4.35V setting (On slot #3 that would not be acceptable).
Charging 3.6V LiFePO4 cells
GyrFalcon%20All-88%200.25A%20(14500-LiFePO4)%20%231
GyrFalcon%20All-88%201A%20(18650-LiFePO4)%20%231
GyrFalcon%20All-88%201A%20(SO26650-LiFePO4)%20%231
The charger works perfectly with LiFePO4 cells.
Charging NiMH cells
It is possible to start a NiMH cell on a LiIon program, but it is not dangerous. Charge current will be low and the charger will stop after a few hours.
GyrFalcon%20All-88%201A%20(eneloop)%20%231
The NiMH charging stops on -dv/dt and looks fine.
GyrFalcon%20All-88%201A%20(eneloop)%20%232
GyrFalcon%20All-88%201A%20(eneloop)%20%233
GyrFalcon%20All-88%201A%20(eneloop)%20%234
GyrFalcon%20All-88%201A%20(eneloop)%20%235
GyrFalcon%20All-88%201A%20(eneloop)%20%236
GyrFalcon%20All-88%201A%20(eneloop)%20%237
GyrFalcon%20All-88%201A%20(eneloop)%20%238
On all slots, there is a small difference in current, but that is not important.
GyrFalcon%20All-88%201A%20(eneloopXX)%20%231
GyrFalcon%20All-88%201A%20(eneloopPro)%20%231
GyrFalcon%20All-88%201A%20(powerex)%20%231
The 3 high capacity cells are also terminated perfectly.
GyrFalcon%20All-88%200.5A%20(eneloopAAA)%20%231
No problem with an AAA cell.
GyrFalcon%20All-88%200.1A%20(eneloop)%20%231
This cell is not supposed to terminate, because -dv/dt do not work at this low current, but somehow the charger do terminate (Very good).
In the release version the charger will stop earlier due to timeout.
GyrFalcon%20All-88%201A%20full%20(eneloop)%20%231
As usual -dv/dt is some time to terminate on a full cell, about 12 minutes is a fairly good time.
GyrFalcon%20All-88%201A%20(8xeneloop)
The charger has no problems with charging 8 cells at full current.
GyrFalcon%20All-88%201A%2012V%20(8xeneloop)
With NiMH it uses about 1.8A from 12 volt.
Temp3117
M1: 45,3°C, M2: 46,2°C, M3: 46,9°C, M4: 45,6°C, M5: 46,5°C, M6: 43,1°C, M7: 43,8°C, M8: 40,1°C, M9: 45,3°C, HS1: 64,2°C
The charger gets warm, but not too hot.
StartupNiMH
Starting is exactly the same as for LiIon.
ChargeNiMH
With NiMH the charger stops every 20 seconds to check the voltage of the cells.
MeasurmenetsPauses
Many slots stop at the same time (I did only check 3), this means the input current will pulse (As can be seen on the 12V chart).
CurrentChangeNiMH
It is possible to change current during charging.
Testing the mains transformer with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a fairly advanced charger with support for most round cells on the market, both fairly large and very small. At first glance it might look complicated to use, but it is not and it is also fast to use for 1A charging on NiMH and 4.20V LiIon. Other types of cells requires a few more keypresses, the short-cuts makes it fast to setup many of the same cell.
The charger has some small text on the display and it is required to check it before charging. The charger will not start automatic, it is always necessary to press some keys to select voltage and current.
Due to the wide slots, it is necessary to be a bit careful when loading thinner cells (Like AA), they have to be centered in the slot.
I will rated this charger as a very good charger, but it requires a bit care when starting a charge.
Notes
The charger was supplied by Enova for review.
Changes on the release model:
  • Time limits on NiMH charging (in the 5-10 hour range).
  • The charger will use red and blue leds (not green).
  • 4 spacers included for easier connection to smaller cells.
FlashPilot
FlashPilot's picture
Last seen: 11 hours 36 min ago
I wonder why such a variation of termination voltages across the 8 stations while charging 4.20V LiIon cells? Maybe you could notify them so they can correct the problem before these go into full production.
HKJ
HKJ's picture
It would have looked neater with the same voltage.
The difference is due to tolerances on the resistive divider for each channel.
With the current resistors it is within +/-0.05V, making it more precise would increase the price of the charger (I do not know what the price will be, but I did ask about the voltage tolerances).
FlashPilot
Thanks HKJ. Its sad that they would execute such an attempt and then fall short, just to save a few pennies. Id advise people to avoid this charger unless Enova resolved the problem. I wonder if the supplied PSU is also contributing to the problem?
If not for your meticulous tests, we would never know about these types design blunders until we had already tossed our money. Thank you for all of your hard work!
MRsDNF
MRsDNF's picture
Last seen: 2 weeks 5 days ago
Thanks HKJ. It looks very tempting. I wonder what the price will end up at?
HKJ
HKJ's picture
It is not really a problem.
No.
bugsy36
bugsy36's picture
Last seen: 12 months 4 days ago
Is this available yet? I could really use one of these…maybe 2
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
HKJ
HKJ's picture
According to the manufacturer they will start shipping next week. I would not take that as an absolute, something can always pop-up that will delay it a bit more.
bugsy36
bugsy36's picture
HKJ wrote:
bugsy36 wrote:
Is this available yet? I could really use one of these...maybe 2
Say it isn't so....manufacture is always on schedule.laughing
enova18650.com
Last seen: 4 weeks 7 hours ago
Thanks HKJ for your great work!
ENOVA
enova18650.com
it was terminated with 0dv/dt.
ENOVA
enova18650.com
If reduced the voltage tolerance from (+/-0.05) to (+/-0.01), maybe the retail price will be more than $100.
ENOVA
HKJ
HKJ's picture
There are two ways to improve tolerances:
1) Use parts with tighter tolerances
2) Calibrate each channel (Calibration could be stored in eeprom/flash memory).
The first requires more expensive parts, the second way requires more work during final test.
will34
will34's picture
Last seen: 3 hours 47 min ago
Interesting charger, Thanks for the review.
FlashPilot
Im sorry but this is unacceptable. Why would I want to live with such a voltage imbalanced in my cells and pay more for your charger? Especially when there are several inexpensive chargers that terminate with far higher precision. For instance, a typical scenario is that I can charge 50 × 18650’s while using xtar or soshine brand chargers. After resting, 47 cells will show 4.18V, 2 will show 4.17V, 1 will show 4.19. This has been a typical scenario for many years and does not deviate unless I am testing old used cells.
It sounds like your charger isnt performing as you had intended. Please take a look at HKJ’s graphs entitled “Charging 4.20V LiIon cells” and take note of the termination voltage imbalances between charging stations. Good luck, and I hope you can resolve this issue before this charger comes to market.
Calmaja
Last seen: 3 years 1 week ago
Thanks for the review HKJ. I hope they consider to make 4 slots version with 2A for each channel.
HKJ
HKJ's picture
It looks like they will make a 4 slot version, but the current will be 1A for each channel.
I.e. you need more patience.
FlashPilot
Are you serious? Please do tell what consumer level application you have that would be sensitive to such minute differences.
You aren’t going to get much better than 0.05% tolerance/calibration without spending a lot more money. If you have a cheap charger that you think does better then probably it was just the luck of the draw (or your testing was not accurate).
Yes, I am serious. I sell DOZENS of chargers and test each and every one before they go out the door. Do yourself a favor and read my post again, then you can learn from my experience, not your false conjecture.
FlashPilot
Go troll elsewhere. I already posted my results while using chargers that cost less than $20.
HKJ
HKJ's picture
I rated the charger based on my opinion and experience, other people may have other requirements and give it a different rating. One reason I publish my raw tests is because it allows (Technical) people to do their own evaluation.
If FlashPilot want chargers with better matching charge voltage, he is welcome to that. In a few cases it might be a good idea, but mostly it is not required.
1dash1
1dash1's picture
Last seen: 3 years 4 months ago
Thanks for the review HKJ!
Sounds like a very flexible charger, one that could meet the ordinary needs of most users with a few (minor) issues.
And I’d feel a lot more comfortable with the results from a random pick of the regular production. I guess I just don’t trust manufacturers to “not fiddle around with” their production models. But I guess that it is a good thing … to be given the opportunity to review a product in advance, isn’t it?
P.S. I also appreciate the participation in this discussion by the manufacturer’s representative (enova18650.com).
Rule 1-1 as it applies to life, take it as it comes.
sb56637
sb56637's picture
Last seen: 1 day 22 hours ago
Hi everyone, fighting is not necessary or even permitted here. Please drop the subject if somebody is getting hot under the collar. Thanks.
bugsy36
bugsy36's picture
For me…I need a gang charger with an LED screen so depending on my following question….
HKJ – Will the included power supply support 8×1A?
HKJ
HKJ's picture
The included power supply can deliver 4A and only 3.5A is needed for 8×1A, i.e. it supports running all slots at 1A.
bugsy36
bugsy36's picture
Thank you!
enova18650.com
Thanks FlashPilot for your criticism; Thanks gauss163 and HKJ for your professional opinion; And thanks 1dash1 for your sincere comments. Because the user’s comments are very important for us,It can help us to develop products more effectively. So I have great respect for your opinions,suggestions and criticisms.
Thank you all.
ENOVA
enova18650.com
Hello BLF members,
Does anybody could help us to make some smaller language reviews?
Such as French, German, Korean, Japanese, Arabic, Portuguese, Italian and so on.
Either you can make a video or write a soft-text.
And then sent them on better-known websites or forums that is related to the flashlights or electronic cigarettes.
If someone will help us, please send me a private letter.
My email address is info@igyrfalcon.com
Thanks.
ENOVA
MountainKing
Last seen: 3 weeks 5 days ago
HKJ: Thanks for the review. Great as always. Flashlightpilot: What particular xtar inexpensive chargers are you referring to?
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
FlashPilot
I’ve distributed around 600 of the cheap DX 2 station chargers and recently swapped to the 2 station Meritline chargers for their superior build quality and slightly higher termination voltage (4.24V) for 4.30V cells. Ive also sold literally hundreds of xstar chargers (all non USB) with external PSU, as well as dozens of the large 4 station 4 amp soshine brand with eternal PSU. Except for the odd ball (perhaps 1 in 20), they all terminate at the same voltage (+/- .005V). The DMM reads the same down to x.xx VDC across charging stations of the same charger. You can rummage HKJ’s excellent extensive charger review database and find many that accomplish this level of consistency and accuracy.
Others rely on my lights in mission critical/dangerous environments, so I thoroughly test each cell, charger and light before sending them on… usually 2 or 3 complete charge/discharge cycles.
Hope that helps…
enova18650.com
Hi BLF members, Gyrfalcon All-44 is coming!
Features
• Optional charging voltage (1.5V Ni-Mh, 3.6V LiFePO4, 4.2V Li-ion, 4.3V Li-ion, 4.35V Li-ion)
• Optional charging current (0.1A - 0.25A - 0.5A - 1A )
• Capable of charging different chemistries at different currents at the same time
General mode (automatic mode) only for 1.5V Ni-Mh and 4.2V Li-ion batteries, it can automatic start charging and termination.
Professional mode (manual mode) for 1.5V Ni-Mh, 3.6V LiFePO4, 4.2V/4.3V/4.35V Li-ion batteries, Have 3 kinds short-cut operations.
• 4x bays wide enough to fit 4x 26650s at the same time
• Longer bay slots to handle 18mm - 72mm lengths
Specifications
• Input: DC 12V 2A
• Output voltage: 1.5V / 3.6V±0.05 / 4.2V±0.05 / 4.3V±0.05 / 4.35V±0.05 ×4
• Output current: 100mA - 250mA - 500mA - 1000mA ×4
• Compatible with:
Li-ion / LiFePO4 / IMR: 10180, 10440, 14500, 16340, 17500, 17670, 18350, 18500, 18650, 26650, 32650
Ni-MH / Ni-Cd: AA, AAA, AAAA, C
ENOVA
ko4nrbs
Last seen: 8 months 1 week ago
I posted the All-88 reviews and manufacture’s website over on the Game Camera forums I frequent. This charger should interest many of the folks there in order to keep up with all the batteries required for the many Game Cameras in the field.
The ability to charge NiMH and 18650 Li-ion cells at 1 amp and simultaneously if needed was all the info I needed. I’ll be placing my order when I get home from Florida in march.
Way to to go Enova!!
Bill
