Collect suggestions: Brinyte led canister dive video light
19 posts / 0 new
Brinyte
Brinyte's picture
Last seen: 3 years 1 month ago
Hey,folks in BLF. Long time no see, would you guys miss me or our lightslaughing?LOL.
As you know, our newest canister dive light DIV20 only has focus head now. Because DIV20’s heads are detachable, so many divers asked for using focus and video head at the same time. Now our engineers have designed three plans, and hope to get your suggestions.
Which plan is your favorite? Do your have some ideas for the dive video head?
Plan A.
Use 3*CREE XM-L2(U4) LED, only white beam, about 3000 lumens.
Plan B.
Use 6* CREE XM-L2(U4) LED & 4*CREE XP-E2 R5 red LED, the white beam will be about 4500 lumens.
Plan C.
Use one CREE XHP-70 LED, it will be about 2000 lumens.
All Brinyte members and our company sincerely thank for your suggestions. ヾ(o◕∀◕)ノヾ
Details about DIV20: http://budgetlightforum.com/node/46374
Brinyte,bright your night!
www.brinyte.com
Email:yeguang@brinyte.com
Edited by: Brinyte on 05/18/2016 - 23:42
Wrathbringer27
Wrathbringer27's picture
Last seen: 2 days 6 hours ago
Replace all xml2 with xhp70 Silly
EDIT: I like Plan B hehe
Words can be broken,
so can bones.
Vattern
I like Plan A.
andies
Last seen: 4 years 6 months ago
i would buy the plan B
FlashPilot
FlashPilot's picture
Last seen: 5 hours 49 min ago
Definitely plan B to reintroduce the reds that have been filtered by the water while at depth.
Can you please tell us more about the cell pack? Is there a battery carrier accessible by the user so we can swap in our own cells?
How many cells and type, and how is it configured? ie: total voltage & mAh.
What is the calculated total run time for plan B configuration in its highest mode?
Thanks!
Martin Ren
Last seen: 4 years 1 week ago
Plan B seems more powerful, I like Big Smile
Even more powerful than DIV10W Wink
Brinyte, LED flashlight expert
www.brinyte.com
Email: ledflashlight@brinyte.net
Email: ledflashlight@brinyte.com
Brinyte
Brinyte's picture
Wrathbringer27 wrote:
Replace all xml2 with xhp70 Silly EDIT: I like Plan B hehe
smileGood choice.
www.brinyte.com
Brinyte
Brinyte's picture
Vattern wrote:
I like Plan A.
Great! Thumbs Up
www.brinyte.com
Brinyte
Brinyte's picture
Hey,andies.Recieved your PM. Thanks!laughing
www.brinyte.com
Brinyte
Brinyte's picture
FlashPilot wrote:
Definitely plan B to reintroduce the reds that have been filtered by the water while at depth. Can you please tell us more about the cell pack? Is there a battery carrier accessible by the user so we can swap in our own cells? How many cells and type, and how is it configured? ie: total voltage & mAh. What is the calculated total run time for plan B configuration in its highest mode? Thanks!
Hi, FlashPilot. Thanks for your interests.
Now our DIV20 focus dive light use 8*18650(3400mAh) Panasonic batteries. And you can open the battery canister just turn of the four screws, but should be careful not to make the wire inside broken.
In theory, max runtime will about 5 hours on white beam and 7 hours on red beam.But we are thinking to use 3000mAh batteries instead.  You know, 3400mAh battery is so expensive that the selling price is a little high.
www.brinyte.com
Brinyte
Brinyte's picture
Grad Aha,clever.
www.brinyte.com
Brinyte
Brinyte's picture
reserved. Big Smile
www.brinyte.com
freeme
freeme's picture
Last seen: 3 hours 15 min ago
Panasonic 3400mAh is very cheap now. cool
cyberdiamond
Last seen: 1 year 4 months ago
Plan B and add 4 UV lights as well.
Make the cable removable at both ends (like it already is at the battery) also make it removable at the light head end so when it breaks we can just order a new cable instead of having to send the light back to China to be fixed!
Than we can swap different cable lengths onto different heads, depending where it is mounted or what we are using it for.
Brinyte
Brinyte's picture
Buddy,you are so naughty.tongue-out
www.brinyte.com
Brinyte
Brinyte's picture
cyberdiamond wrote:
Plan B and add 4 UV lights as well. Make the cable removable at both ends (like it already is at the battery) also make it removable at the light head end so when it breaks we can just order a new cable instead of having to send the light back to China to be fixed! Than we can swap different cable lengths onto different heads, depending where it is mounted or what we are using it for.
Hi,cyber. Thanks for your advice.
The cable at both ends is glued to ensure waterproof. But the cable length could be produced according to your required by just telling our salesman.wink
www.brinyte.com
cyberdiamond
The cable is detachable at the battery canister end as written in the first post.
Make it detachable at the light head end as well.
Brinyte
Brinyte's picture
cyberdiamond wrote:
The cable is detachable at the battery canister end as written in the first post. Make it detachable at the light head end as well.
I'm sorry I misunderstood your previous meaning, cyber. Your advice “Make it detachable at the light head end”, I will tell our engineers. Thank you.smile
www.brinyte.com
cyberdiamond
Tell the engineers to make it detachable at BOTH ends.
Then you can use any cable with any light head as needed and order a new cable when you need a different length or it breaks.
