XM-L2 voltage
11 posts / 0 new
akv
Last seen: 4 years 4 months ago
XM-L2 voltage
hi
if i’m connecting lithium battery directly to XM-L2, will it turn on? even when the battery is fully charged?
what is the voltage range?
thanks
will34
will34's picture
Last seen: 4 hours 46 min ago
Take a look here: http://budgetlightforum.com/node/20120
The XM-L2 needs much lower voltage than a fully charged cell to power on, if you connect them directly you will end up driving the LED to very high current and possibly blow it up if not heatsinked correctly.
akv
thank you
is there any drivers that i can use them with 0-1 switches?
what i want to do, is to connect few switches / few drivers in parallel, so every switch addes more current. and i also want to get the max lumens possible from the leds.
will34
will34's picture
Why don’t just use a multimode driver for that? http://flashlightwiki.com/Driver
akv
you right, i will. Thank you
will34
will34's picture
For maximum output I suggest you use a FET driver, and of course the LED mounted on a DTP copper mcpcb.
MRsDNF
MRsDNF's picture
Later XML2 leds had a higher voltage requirement that would not handle high currents. Around 5 amps is close to the point of no return. I tested an XML2 U4 the other day and it blew at 5.25 amps, much the same as the XML2 U2’s I was having problems with. The voltages I dont recall. Its well documented here in a couple of threads.
akv
hi, what’s better, the aliminium mcpcb or the star sinkpad?
i’m not from US
ImA4Wheelr
Hi akv. Copper conducts heat about two times better than aluminum. So for high current situations, a copper direct thermal path (DTP) MCPCB is far superior.
Based on your plans, questions, and responses, I’d bet you’re going to make an impressive light cannon. Best wishes. Smile
akv
Wink yes i’m hoping to make this. my planes is to use a computer/cpu heatsink cooler with a fan, so i think the regular/non-copper will do enough good anyway. i planning to use 10×17mm 8*7135 1-mode drivers, 28A in total. best wishes Smile
akv
ok i got it, thank you
