Test/Review of Charger Xtar SV2 Rocket
32 posts / 0 new
HKJ
HKJ's picture
Last seen: 21 hours 11 min ago
DSC_4554
DSC_4555 DSC_4556
This Xtar charger can charge NiMH and LiIon batteries, it can handle fairly large cells and can also use a both low and fairly high charge current.
DSC_4536 DSC_4537 DSC_4538 DSC_4539
I got the charger in a retail cardboard box from. The box has a lot of specifications printed on the back.
DSC_4549
The box contained the charger, a mains power supply, a car adapter a instruction sheet and a warranty card.
DSC_4558
The charger has a DC input socket (5.5/2.1mm) where either the power supply or the car adapter can be connected.
DSC_4560
The user interface is a display, two leds and one button.
A short press on the button will change charge current between 0.5A, 1A and 2A, a double tap (Why?) will change to 0.25A, a long press will turn the display off. With display off a short press or removing/inserting batteries will turn it on again.
The CH1/CH2 leds are red while charging and green at all other times.
DSC_4689 DSC_4687
The display shows selected current and how much the batteries are charged. After some time the brightness will be reduced, but it is still easy to read the display and a press on the button will return it to full brightness.
DSC_4561 DSC_4562
The charger uses the typical slider construction with a metal rail and works smoothly from about 30mm to 71mm, i.e. the charger can handle long protected 18650/26650/32650 cells.
Notice the long metal bar at the plus connection, this makes it possible to handle 32650 and D cells, it also means that flat-tops with very retracted plus pole may need a magnet to connect (The flat-top cells I tested worked directly).
supportedBatteryTypes
supportedBatterySizes DSC_4630 DSC_4631 DSC_4632 DSC_4633
DSC_4624 DSC_4622 DSC_4623 DSC_4625 DSC_4626
DSC_4635 DSC_4628 DSC_4629
The charger can handle 71 mm long batteries, including flat top cells.
Many high current 18650 can be charged at 2A with only a minor impact on lifetime.
Measurements
  • When not powered a LiIon will discharge with about 2.3mA.
  • When not powered a NiMH will discharge with about 0.8mA.
  • When LiIon battery is full the charger will charge with 0.6mA.
  • The charger will restart if battery voltage drops below 3.94 volt.
  • Charge will restart charging after power loss, or battery insertion.
  • Charger will charge from zero volt with about 100mA
  • Below 2 volt the charger assumes NiMH
  • Between 2 and 3 volt the charger uses 10% charge current
  • Above 3 volt regular LiIon charging is used.
  • Power consumption when idle is 0.6 Watt (0.9W with bright background light).
Charging LiIon
Xtar%20SV2%201A%20(PA18650-31)%20%231
Nice and fast CC/CV voltage charging with 65mA termination.
Xtar%20SV2%201A%20(PA18650-31)%20%232
It is the same on the other slot.
Xtar%20SV2%201A%20(SA18650-26)%20%231
Xtar%20SV2%201A%20(PA18650-34)%20%231
Other capacities are handled just as fine.
Xtar%20SV2%201A%20(BE18650-26)%20%231
Also the old cell is handled as fast as possible, but due to the higher resistance it will spend more time in CV phase.
Xtar%20SV2%200.25A%20(KP14500-08)%20%231
Again a good CC/CV curve and the termination current is lower at 35mA.
Xtar%20SV2%200.5A%20(AW18350-IMR)%20%231
Also a good charge curve.
Xtar%20SV2%201A%20(2xPA18650-31)
The charger easily handles two cells at 1A.
Xtar%20SV2%202A%20(2xAWT18650-30)
At 2A the temperature raises, but the charge curve is the same nice one.
Temp3209
M1: 45,3°C, M2: 45,8°C, M3: 48,0°C, HS1: 62,9°C
At 2A the charger is warm.
PowerOnLiIon
The charger needs 2 to 4 seconds to start, as can be seen the current slowly ramps up.
CurrentChangeLiIon
This is also the case when changing current, when increasing current it is ramped up, when reducing current drops immediately.
Charging NiMH
Xtar%20SV2%201A%20(eneloop)%20%231
The charger start charging NiMH with a low current, then after about 10 minutes it goes to the selected charge current. Termination looks to be on voltage in this case here, followed by a two hour top-off/trickle charge at 50mA (Charger displays done).
Xtar%20SV2%201A%20(eneloop)%20%232
It is the same on the other channel.
Xtar%20SV2%201A%20(eneloopPro)%20%231
Xtar%20SV2%201A%20(eneloopXX)%20%231
Xtar%20SV2%201A%20(powerex)%20%231
The 3 high capacity cells are also handled fine, two of them with -dv/dt termination.
Xtar%20SV2%200.5A%20(eneloopAAA)%20%231
I use a lower current here, this also means the top-off charge is done with slightly lower current.
Xtar%20SV2%200.25A%20(eneloop)%20%231
With a 0.25A current there is no -dv/dt signal to termination on and it looks like the charger terminates on time.
This is not a fault with the charger, but use of wrong charge parameters for the cell.
Xtar%20SV2%201A%20full%20(eneloop)%20%231
The charger takes some time to detect a full cell, first the 10 minutes with slow charging and then a few minutes with full current.
It do also use the top-off/trickle in this case.
Xtar%20SV2%201A%20(2xeneloop)
Two cells at 1A is no problem.
Xtar%20SV2%202A%20(2xeneloop)
Neither is two cells at 2A, but things are starting getting warm.
Temp3203
M1: 46,7°C, M2: 46,7°C, M3: 46,1°C, M4: 57,6°C,HS1: 63,2°C
PowerOnNiMH
The charger needs about 4 seconds, before it starts a low current charge.
PowerOnNiMH2
10 minutes later it will switch to full current.
CurrentChangeNiMH
With NiMH the current do not ramp, but jumps directly to selected value.
TrickleChargeNiMH
The top-off/trickle charge is done with current pulses at the selected charge current. The pulse is 1 second wide each 21 second. This gives 47mA at 1A charge current.
Charging LiIon and NiMH at the same time
It is possible to charge one LiIon and one NiMH battery in the charger at the same time.
As usual the temperature sensor is on the opposite cell.
Xtar%20SV2%201A%20(eneloop+PA18650-31)
In this curve I recorded the NiMH battery, it looks the same as above.
Xtar%20SV2%201A%20(PA18650-31+eneloop)
The LiIon also looks the same as above.
Testing the mains transformer with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger can handle from 10440 cells to 32650 cells or AAAA to D cells, the only requirement is that the user selects the correct charge current. The display is rather simple with only current and charge percent.
For a “simple” charger this is a very good charger for both LiIon and NiMH.
Notes
The charger was supplied by Gearbest for a review.
Read more about how I test USB power supplies/charger
FlashPilot
FlashPilot's picture
Last seen: 10 hours 6 min ago
Looks like all other Xtar chargers Ive tested… always with proper voltage termination across both charging stations and with little variance between them. 2A x 2 and the ability to charge 32650’s is a real plus. I hope these guys can come up with a charger/analyser at some point in the future (and one that actually works properly).
atbglenn
atbglenn's picture
Last seen: 2 years 3 months ago
Xtar makes great chargers. I’d pass on this one though because of the lack of a voltage display like the VP1 and VP2’s I own. Otherwise, it’s a charger that does plenty, and does them well.
Edit: I ordered one because it does 2 amps. Yeah yeah, I said I wouldn’t, but I did. Let the flames begin
Boycott Nike
will34
will34's picture
Last seen: 8 hours 11 min ago
Many thanks for the test!
If Xtar can change the % into voltage it would be perfect. 2A charging is a nice reason to replace my VP2.
piasca
Last seen: 8 months 4 weeks ago
A real rocket great review.
lionheart_2281
lionheart_2281's picture
Last seen: 3 hours 36 min ago
Wish I’d got this instead of a VC4
MiG0
Last seen: 7 months 4 weeks ago
Thanks for excellent review. Now ordered with confidence.
I hope it will run cooler at 1A than VP2.
Henk4U2
Henk4U2's picture
Last seen: 9 min 52 sec ago
Excellent review. Thank you.
At BLF we often hear “you can never have to many flashlights”. But about chargers I am pretty sure there is no vacancy at this moment. If at a given time one of my XTAR chargers chooses to persue a new career at the happy flashlight hunting grounds, I think that I know who will be the new kid on the block.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Speed4goal
Last seen: 11 months 1 week ago
Has anyone purchased this product and used it for sometime yet? How so you like it? Its got my interest, xstar seems to make good quality products and some of the best termination currents for li ion I’ve seen. A lot of chargers terminate kind of high. Wish there new dragon charger wasn’t $100 there out of their minds.
I’m considering this one or the lotto 500 to add to my collection of vc2 and liito 100 chargers. The input on the vc2 is fairly accurate with cell capacity. Would be nice to run a discharge occasionally. Maybe get a single or double bay analyzinf charger for my yearly recycling. Might end up getting both chargers. The vc2 input has shown me cells that have worn out and gone to recycling but have to run them down first to tell.
Any experience with this charger is appreciated 2 amp charging is nice in a pinch for time or my 26650.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
sidecross
sidecross's picture
Last seen: 4 years 4 months ago
Thank you for the review.
I have two XTAR SP2 chargers which seem to be a previous version without any readout or a .25 amp charge option. I use this charger often, but see little advantage to change this newer one.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
atbglenn
atbglenn's picture
I have several Xtar chargers. I have to say I’m extremely pleased with all of them. Just ordered one of these to charge my 26650’s at 2 amps, and charge my Eneloops as well. The only thing I wish it had was a voltage readout instead of percentage.
Boycott Nike
teacher
teacher's picture
Last seen: 2 years 2 months ago
I agree, I like Xtar also…. but I sure do agree with what you say about the voltage readout instead of percentage. Thumbs Up
atbglenn
atbglenn's picture
I agree with your agreement Smile
Boycott Nike
teacher
teacher's picture
Party I love it………. Thumbs UpWink
Speed4goal
I’m leaning towards this one or the efest 4 luc.since it has 2 bays at 2 amps or 4 bays at 1amp. But I know of xstar quality. My vc2 would be considered commercial use and still going strong. By commercial I mean it never gets a break 24/7. I have a line of cells always ready to get recharged. The only one amp charger I have is the litto 100. .5 amp charging even in 2 bays isn’t really cutting it anymore. 1 amp would work. It would nearly cut time in half.
What I was thinking with this charger is you could start the charge at 2 amps, around 80-85% scale it back to .5 amp or 1 amp to finish out without to much strain on the batteries. To many choices. I do need a rapid charger just not for my sets of 26650s. But for during hurricanes and such. When the power goes out for days and have 6+ flashlights/lanterns/powerbanks. I need to be able to rapid charge my cells even if it is just to 80+% to keep cells in rotation fast enough. Even with 30+ cells .5amp won’t cut it. With my power inverter and usb ports I can hook up 3-4 chargers in the vehichle as needed
sidecross
sidecross's picture
+1
I agree with both of you. Smile
It might be a good opportunity to purchase at a reduced price the older XTAR SP2 which seems to be a similar but without readout screen and lower amp charging choice of .25 amp.
atbglenn
atbglenn's picture
sidecross wrote:
+1
I have 2 SP1’s that do 2 amps. But they don’t do .25 amps nor NiMH’s, and doesn’t have a display. Even though it doesn’t have a voltage readout, it still gives you enough information about where you’re at in the charge cycle. I’ll probably give one of my SP1’s to a friend.
BTW, I ordered mine from Xtar Direct for $32 delivered. I bought my VP2’s from them and I’m satisfied with their quick USA shipping.
Boycott Nike
sidecross
sidecross's picture
+1
teacher
teacher's picture
sidecross wrote:
+1
Amen!!! Wink
Ya’ know, that is a great idea about the XTAR SP2 ‘sidecross’. Thumbs Up I have one, it charges at 0.5A, 1.0A & 2.0A and you are correct.. it does not have “the screen” or the 0.25A charge. (To me both of those features are worthless anyway.)
I found the XTAR SP2 at this place at what appears to be a good price. Plus these guys are great to deal with…. shipping is almost immediate.
sidecross
sidecross's picture
teacher wrote:
Amen!!! Wink
+1
That is a very good price for an excellent charger. Smile
Speed4goal
Does it charge both bays at 2 amps? Or is 2amp if only one battery is in it the sp2 I mean
atbglenn
atbglenn's picture
teacher wrote:
sidecross wrote:
+1
Amen!!! Wink
But the SV2 Rocket also does NiMH’s for $5 more. Plus the display Beer Yep, I’m having a couple of Bloody Mary’s right now, feeling no pain Silly
Boycott Nike
teacher
teacher's picture
sidecross wrote:
+1
Agreed, it sure is!!! Thumbs Up
And since it can charge 2 batteries at 2.0A each, and through no fault of my own I seem to have somehow acquired several 26650 batteries; (that’s my story and I’m sticking to it…………. FacepalmWink . ) I may get another one of these while the getting is good. Thumbs Up
No bells and whistles for sure, but hey; most of the time bells & whistles are just that………… bells & whistles. Wink
sidecross
sidecross's picture
Amazon through Performance Outdoor Gear is selling the XTAR SP2 for $22.91. Smile
atbglenn
atbglenn's picture
Great price! I’m still happy getting the new SV2 Rocket. I will report back when I get it.
Boycott Nike
sidecross
sidecross's picture
+1
I did not mean to rain on your parade. Do let us know how you like the new one. Smile
atbglenn
atbglenn's picture
sidecross wrote:
+1
No problem my friend. I’ll let you know what I think after I test it out.
Boycott Nike
atbglenn
atbglenn's picture
I have one question. How much better is this charger at charging Eneloops than my PowerEx C 9000?
Edit: Got it today. So far I’m very pleased with it’s perfomance.
Boycott Nike
sidecross
sidecross's picture
!{width:90%}http://i135.photobucket.com/albums/q146/atbglenn/Batteries%20and%20Charg...!
+1
Glad to hear you are pleased with the new XTAR! Smile
Lateck
Last seen: 2 years 1 month ago
Thanks HJK for your great review, as normal.
I just noticed this review as I have added a SV2 to my charging stable.
Lateck,
atbglenn
atbglenn's picture
It’s a simple charger that does what it’s supposed to do reliably. I’ve been using it exclusively to charge my 26650’s at 2 amps. I wish it had a voltage readout like the VP2 instead of percentage. But that’s only a minor gripe. All in all I’m still happy. I highly recommend it to anyone needing a 2 bay charger that does 2 amps.
Boycott Nike
