Toykeeper Appreciation Gift _ Hardware Upgrades
117 posts / 0 new
Joshk
Joshk's picture
Last seen: 1 month 1 week ago
What’s the status of this?
hank
hank's picture
Last seen: 18 hours 36 min ago
I guess we’re waiting on a specific piece of hardware to chosen, or perhaps invented.
The basic physics appears to be, er, solid: http://i-hls.com/2013/10/star-wars-weapons-scientists-create-lightsaber-...
mattlward
mattlward's picture
Last seen: 2 hours 11 sec ago
I would think a decent reflow station or a bench power supply, if she does not have one. I build most of my drivers and I have neither and would love either!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
hank
hank's picture
Oh, no, we already know the category of hardware TK wants. Scroll back 2 or 3 posts.
ToyKeeper
ToyKeeper's picture
Last seen: 18 hours 33 min ago
Current status? It looks like there’s enough to cover everything on the list. You guys are way too generous. Smile
Tom E made some drivers to send me, and the rest is still a bit fuzzy. I could especially use some tips on what kind of hot-air station to get, and how to aquire a bag of decent parts for drivers. And LEDs and resistors to put on tail boards. Digikey shopping cart maybe?
Mostly though, I’ve been busy trying to cook up the right combination of kernel and distro and tools to make a beaglebone black work with an acme power cape for work, and a little distracted by shiny sword things. As it turns out, building a custom BBB kernel is a bit of a pain, and so is physically organizing its spider-plant-like mess of floating circuits and cables. And by coincidence, SaberForge re-opened its custom saber shop a couple days ago so I put in an order. I can’t get quite the finish I was looking for, so it’s likely I’ll also end up learning how to anodize aluminum and then artificially weather it.
Anyone know a good hot-air station? (aside from broadcast television news Wink )
Tom E
Tom E's picture
Last seen: 1 min 21 sec ago
TK - I'm waiting for you to get back to me. Just made up a handful of these:
But improved:
  • ATtiny85 w/bent pins (of course cool)
  • SIR800DP FET instead (lower resistance, stays cooler, no problem with high amps for parallel LED's)
  • R1 and R2 are 10X the values to cut parasitic drain by 10X
  • 7135 350 mA instead of the 380, for lower moon mode
All hot air reflowed. I believe this is the hot setup! I can get two of these out to you, plus the SRK OSHPark driver, w/85 and the same setup for 10X resistors and SIR800DP FET, 350 mA 7135. I still have to test them out first, but should go pretty quick.
MRsDNF
MRsDNF's picture
Nice Tom E.
ToyKeeper
ToyKeeper's picture
Tom E wrote:
I’m waiting for you to get back to me.
Sorry, I hope things calm down soon. Life has been a roller-coaster lately.
Tom E wrote:
… All hot air reflowed.
Any suggestions for a decent hot-air tool?
I believe you are correct, sir. Smile
For some reason, I feel like a kid in a candy store…
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 2 days ago
with the owner out to lunch. Wink
Scott
ToyKeeper
ToyKeeper's picture
Rufusbduck wrote:
… with the owner out to lunch. Wink
Seriously. I took a shower and all I could think about was how to implement a new easier-to-modify e-switch firmware base. Maybe also a ZL-like UI as an example of how to use it.
Tom E
Tom E's picture
Ok, I also had some major issues. lost a few critical hours. Started on testing the new drivers - here's a couple pics:
I was goin nuts - the computer would not even recognize the USBASP - no red light, nothing. I did tons of things, power rests, tried other USB connectors, order a cable and new USB hub. Stupid me left in the driver all this time. I removed the cables form the USBASP and it recognized the dongle. Eventually tracked it down to the one driver board. Lok carefully at the MTN driver in the lower left - see anything wrong?
Well, there's actually 2 solder grounds - right side of the cap, and where the "3" is in the upper left -- there's actually 2 small pads solder over in a blob. Fixed the shorts, and all works now. Also tricky is the Schottky diode above the MCU is tight to the 85 pins. On two of these boards, I actually had to hot air reflow the diode again and give it a little nudge away from the MCU. I can't blame Richard for this, because the 85 is quite a big chip, and even with bending the pins practically under the chip still barely catch's the pads.
For the hot air reflow station, I bought this one: https://www.amazon.com/gp/product/B00XTK1JMG/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1. $46 shipped is pretty good. I use it on the lowest fan settings. I prefer it separate from the soldering iron. I only move it to be work area when needed. Dunno if this is the best way, but I would never trade down from my Hakko. There's no way I can solder as well as I do without that Hakko.
Anyways, in the detail pic above, you can see where my replacement parts are. I think RMM nailed the design for stable performance from the 24/45/85's. With the tiny 402 FET gate pulldown, and the addition of the zener, I believe he greatly reduced the spikes going in to the MCU, I believe caused by the FET gate.
I also like he gave us a pad (tiny one) off of pin #3, which I use for the indicator LED.
Ohhh - I ran out of SIR800DP FET's, and getting low on 85's, so got in my order with Richard before they went out on vaca -- glad I got that in. Also just had to add another SupFire L5. They apparently changed the switch since the last ones I ordered - it looks much better. Like to see how good it is. The old L5 had a small switch that was a hard press - the new one looks easy, more like an SRK -- I'll see soon enough.
MRsDNF
MRsDNF's picture
Richard going on holidays?
Your pictures dont do justice to how small these components are. For those that dont know the small components are really really small.
Nice problem solving Tom.
FmC
FmC's picture
I’ll 2nd the Hot Air station that Tom E linked above. I have a lot of hours on mine & it’s still kicking.
MRsDNF
MRsDNF's picture
Even the crazy dude gives it a good wrap.
https://www.youtube.com/watch?v=vva2t21sOAs
Tom E
Tom E's picture
Just mailed out two assembled and tested ATtiny85 drivers to ToyKeeper. Both have the latest Narsil version, so TK can at least use it as a confirmation the drivers work ok when installed. One is an SRK style/size - our original BLF Q8 V1 (https://oshpark.com/shared_projects/BjPlsgMu) that I've been using in a 4X SRK clone for quite some time now. The other is an RMM 17mm FET+1 driver - the MTN17DDm v1.1, with parts upgraded.
The SRK style should be like this:
The MTN17DDm driver, bought here is this:
pm'ing TK now with the tracking #.
MRsDNF
MRsDNF's picture
Thats kind of you Tom. I’m sure we will all benefit from your generosity and Toykeepers abilities.
ToyKeeper
ToyKeeper's picture
It took me a few days (busy week), but I got the larger driver installed in my SRK. It’s the gold one in the site logo.
I’m really looking forward to messing with the code on it. Smile
With Narsil installed, it defaults to the ramping UI and the ramping is buttery smooth. It goes super-low, super-high, and so many steps between that I can’t see where the changes happen. I just got it soldered together a few minutes ago so I haven’t gotten through all the modes and settings yet, but the Narsil manual should help with that.
ToyKeeper
ToyKeeper's picture
Oh, also, it’s a pity it won’t be seen much in a finished light, but it’s really nice how the “Q8” vias let light pass. Put the driver in front of a light surface and it shines right through. Clever and elegant design there.
Mike C
Mike C's picture
Last seen: 11 hours 30 min ago
I could certainly donate one or two of my drivers fully built, flashed and calibrated if that would be of interest.
Tom E
Tom E's picture
Cool! Glad to hear you got it ok, and installed. I've been working on updates to Narsil, some details posted here: http://budgetlightforum.com/comment/970309#comment-970309, but I'm still in progress, and still hunting down a bug FmC has been seeing, his mod thread here: http://budgetlightforum.com/node/47747, but dunno if it's hardware or firmware yet - I've been unable to reproduce it.
I know you have, or will have your own plans for e-switch software on a 85, but almost wish you could help me on Narsil. Still have more plans for it. I'm at about 75% used code space, so still a ATtiny25's worth of free code space.
Actually - what am I say'n? You already have helped me with Narsil! I stole (borrowed) quite a bit of your code that's in there now smilewink!!
I found this 150 ramping table works pretty well across multitudes of lights, from the pocket/headlamp 14500 Skilhunt H15 to the modded up SRK clones. It doesn't work smooth/well with the the MtnE 7135 based SRK driver, modded out to 50 7135's, because of obvious reasons - he used 380 7135's, so the lower PWM values don't work, and, the transition from 1 7135 to the large bank (49) isn't an incremental step up. This light/driver will require a different table.
I also need to generate a "FET Only" version of Narsil to support LDO based drivers to go in lights like the Convoy L6. From what I understand, the 7135 doesn't work well at higher voltages, and will eventually fail or overheat, so the "FET+1" drivers are not a good choice. Actually it doesn't matter if the 7135 is populated, as long as the firmware doesn't use it.
ToyKeeper
ToyKeeper's picture
Your drivers are pretty awesome. I certainly wouldn’t complain about having one… Smile
However, personal enjoyment wasn’t really the point of getting these Narsil drivers. It’s mostly so I can collaborate on new code for BLF’s next round of FET+1 drivers (which will likely get popular when the Q8 ships), and a new e-switch code base. The driver itself is an evolutionary step along the same lines of BLF’s current FET+1 drivers, albeit a pretty nice step. The Narsil interface is pretty sweet so it doesn’t really need more firmwares, but I’m hoping to make it easier for other people to make custom interfaces too.
For your drivers, they’re less evolutionary and more revolutionary. I think the main roadblocks right now are hardware availability and adoption. The biggest wins will probably come from finding someone willing to make and sell the drivers, which isn’t a thing I’m any good at.
As far as stuff which could benefit BLF, having a Mike C driver would at least let me test more of the available firmwares for repository maintenance purposes, and would become more relevant later if the hardware becomes commercially available.
On a related note, your pin-combining insight has already spread a bit. I hear a non-BLF enthusiast named Paramatrek was inspired by it and is using the same technique for some of his upcoming projects. I’m not sure of the details, since he doesn’t want to say much until it’s working. It reminds me of the early days of FET drivers and 2-channel drivers, where people tested the waters and eventually it became sort of a community standard.
ToyKeeper
ToyKeeper's picture
Tom E wrote:
I’ve been working on updates to Narsil, …
I updated the repo to the latest published version, but that was from last month. I’ll try to keep it up to date as new code becomes available.
Anything specific? (er, should probably be PM or in a more relevant thread)
As for my own plans, I’ve been a little distracted again of late. It might have something to do with *ahem* photon swords. I blame 1dash1 and his army of minions. Will post more below.
Tom E wrote:
… he used 380 7135’s, so the lower PWM values don’t work, and, the transition from 1 7135 to the large bank (49) isn’t an incremental step up. This light/driver will require a different table.
I also need to generate a “FET Only” version of Narsil to support LDO based drivers to go in lights like the Convoy L6.
As a compile-time option, those things are usually not terribly hard to do. Of course, I could certainly stand to clean up the code I used for similar options in my projects… Anyway, if you want, we can totally put a thing at the top to choose a 1/2/3-channel driver, and to choose a pre-calculated ramp for common types of hardware. I don’t expect everyone to use the ramp calculator and do the subsequent tweaking it usually needs. (each power channel tends not to be very linear at the far low end, but the calculator doesn’t know that)
ToyKeeper
ToyKeeper's picture
ToyKeeper wrote:
But seriously. This needs to happen.
So, I tried to go into detail about why I’ve been distracted the last few days, and BLF was like…
This is not the forum you’re looking for.
So I guess I’ll just have to link to the details instead: (caution: there be Jedi in these waters)
MRsDNF
MRsDNF's picture
Saber dueling, sprinklers, bent out of shape claws? We need a video to check fighting style and no unwritten Light Saber rules were broken to prevent further damage. Wink
jescereal
jescereal's picture
Last seen: 7 months 4 weeks ago
I’ve been drooling over the sabers shown here:
https://www.youtube.com/watch?v=GXeeUs3H-sI
Always wanted a custom saber. The ones you have look aaaaamazing.
Tom E
Tom E's picture
Latest updates to Narsil released and posted. Details in this 25/45/85 thread post: http://budgetlightforum.com/comment/972129#comment-972129
