Test/Review of AW 17670 1600mAh (Black) 2016
1 post / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 2 days ago
DSC_4499
Official specifications:
  • Nominal capacity: 1600mAh
  • Nominal Voltage: 3.7V
  • Diameter: 17.02mm
  • Length: 67.30mm +/- 0.05mm
  • Max. discharge rate: 2C (3.2A)
  • Size for reference: 168S / 600S
  • PCB protection against overcharge, over discharge and short circuit
  • Safety vent with thermal cut off protection
AW%2017670%201600mAh%20(Black)%202016-info
This cell from AW is fairly thin, this means it can usual replace 2xCR123 in size (Voltage will be lower).
DSC_4498
DSC_4500 DSC_4501
DSC_4502
DSC_4503
AW%2017670%201600mAh%20(Black)%202016-Capacity
The discharge curves looks fairly good, at least up to 3A, but the cell cannot really deliver 5A or 7A. This is perfectly acceptable for a 3.2A rated cell.
AW%2017670%201600mAh%20(Black)%202016-Temp-3.0
The cell warms up at 3A, but nothing problematic.
AW%2017670%201600mAh%20(Black)%202016-Temp-5.0
The temperature is also acceptable at 5A.
AW%2017670%201600mAh%20(Black)%202016-Temp-7.0
AW%2017670%201600mAh%20(Black)%202016-CapacityTimeHours
AW%2017670%201600mAh%20(Black)%202016-Energy
AW%2017670%201600mAh%20(Black)%202016-PowerLoadTime
AW%2017670%201600mAh%20(Black)%202016-TripCurrent
AW%2017670%201600mAh%20(Black)%202016-Charge
Conclusion
The battery looks like it is a old design with low capacity and low current handling, but the cell is still good as a replacement for 2xCR123 cells in equipment (flashlights) that can run on the lower voltage.
Notes and links
The batteries was supplied by aw-akku.de for review.
Compare to 18650 and other batteries
