Finally got the M6 I ordered from Richard. I just wanted to post a few images of the light itself and a couple of comparison shots with the Noctigon Meteor M43. Both lights have 4 brand new freshly charged authentic Sony VTC5’s.
The user interface of the M6 is not programmable like the M43, but it’s simple to use once you get used to it.
Short presses move you forward through levels low to high, long presses move you backwards from high to low, from the off position.
So if you turn it on with a short press, you’re on low, a long press will turn it off. I you long press in the off position you go to high and a short press will turn it off.
It basically allows you to move forward and back through the settings with combinations of short and long presses, and to turn it off using short or long presses depending on which direction would be the shortest.
And it is bright. Real bright. Real real bright. It’s a flooder that’ll light up the whole of whatever it is you’re lighting up.
It is noticeably brighter than the Noctigon M43 as you can see in the beam shots.
Here are some images of the light itself:
Here are some comparison beam shots:
Mega M6 Flashlight - 12x LED - 4x 18650: LED: XP-L HI V2 3B
VS.
Noctigon Meteor M43 Flashlight - 12x LED - 4x18650: LED: XP-G2 S3 3D
Both lights on high (Turbo) Camera: f5.6 - ISO200 - 1/15sec
I shot this one out of focus to see light amount better than light pattern. Camera: f5.6 - ISO200 - 1/15sec
Shot this one fast see light pattern. Camera: f5.6 - ISO200 - 1/250sec
