Test/Review of AW 18650 3400mAh (Black) 2016
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 9 hours 25 min ago
DSC_4511
Official specifications:
  • Nominal capacity: 3400mAh
  • Nominal Voltage: 3.7V
  • Diameter: 18.52mm
  • Length: 68.16mm +/- 0.3mm
  • Max. discharge rate: 2C (5.2A)
  • Size for reference 168A / 600P
  • PCB protection against overcharge, over discharge and short circuit
  • Safety vent with thermal cut off protection
AW%2018650%203400mAh%20(Black)%202016-info
A fairly high capacity cell.
DSC_4510
DSC_4512 DSC_4513
DSC_4514
DSC_4515
AW%2018650%203400mAh%20(Black)%202016-Capacity
The discharge curves looks good.
AW%2018650%203400mAh%20(Black)%202016-Temp-5.0
AW%2018650%203400mAh%20(Black)%202016-Temp-7.0
At 7A the cell gets fairly hot.
AW%2018650%203400mAh%20(Black)%202016-CapacityTimeHours
AW%2018650%203400mAh%20(Black)%202016-Energy
AW%2018650%203400mAh%20(Black)%202016-PowerLoadTime
AW%2018650%203400mAh%20(Black)%202016-TripCurrent
AW%2018650%203400mAh%20(Black)%202016-Charge
Conclusion
A Panasonic cell with added good protection is can only be very good battery.
Notes and links
The batteries was supplied by aw-akku.de for review.
Compare to 18650 and other batteries
will34
will34's picture
Last seen: 2 hours 15 min ago
Thanks for the review, it’s strange that they release a battery based on the NCR-B now in 2016…
HKJ
HKJ's picture
It is not a new cell, I am just reviewing all AW cells.
