SKILHUNT H03 H03R led headlamp release, 1200 LED lemens
110 posts / 0 new
JIGHEADWORM
Mine gets around 900 lumens on turbo.
Lexel
Lexel's picture
mine with Narsil driver about 1400-1500 OTF lumens
JIGHEADWORM
Wow pretty impressive. I’m gonna try the narsil driver you sent me with a xhp 50.2 .
Blackbeard
Blackbeard's picture
Last seen: 12 hours 25 sec ago
is there a thread for assembly of the headband? feeling pretty stupid right about now and the manual is not helpful
bansuri
Last seen: 6 days 11 hours ago
Long piece goes around head, short goes from back to top of light mount.
You have to fold a portion of the band and squeeze it through the opening in the middle of the adjusters, from the underside.
Here’s a link to a partial view of the assembled headband:
http://www.skilhunt.com/wp-content/uploads/2018/01/3-1.jpg
Check the customer reviews on the following link, there are some users pictures of the assembled headband.
https://www.gearbest.com/led-flashlights/pp_391921.html
Blackbeard
thanks i got the center strap with that pic, still working on the long band
Blackbeard
Cool, think I got it now, for some reason I thought the darker color would be on exterior only, so was having trouble putting it together, but the pic helped, thanks again
Niels
Last seen: 5 months 21 hours ago
I just received my H03, and directly placed a NRC18650B in it and tested it.
Directly I liked it. Nice even light to work with.
The headband I think is not super great, but works fine.
The magnatic tailcap is a heandy feature.
Oncoming weak I’l test the light during work (I work at dark places Silly ).
First impression: Great little light! (And yes, it is a small light!).
Klarus Mi7
Fenix E12
Sofirn SF10
Convoy S2+
WaylonJennings
I assume that your head light has the Narsil ramping UI. Ramping would be amazing on this headlight.
Niels
Loving the H03 Love .
Now driving of to a problem with a heating boiler, glad I can use it again :).
I’l later post some review story of what I think working with it, bud so far…
Klarus Mi7
Fenix E12
Sofirn SF10
Convoy S2+
Overload
Overload's picture
Last seen: 2 days 20 min ago
I measured 1.5A max at tailcap with my H03, I assume that’s not enough to get 900/1000lumen?I’ve tried different high drain 18650 batteries, but all the same current
Edit: I got 2.2A with 2x cr123A @4V each… that’s 17W input vs 6W(4.1V*1.5A) with the 18650 batterie, or am I thinking wrong?
hIKARInoob
hIKARInoob's picture
Last seen: 8 hours 50 min ago
You should get about 3A with an 18650 for ~1000 lumens: http://www.cree.com/led-components/products/xlamp-leds-discrete/xlamp-xm-l2
Are you using a clamp meter? A DMM will give you a lower reading, although I have no idea if it can reduce current down to 1.5A.
Overload
Overload's picture
I measured exactly the same currents with a clamp meter.
I don’t understand the big difference between power input of a 18650 and a 16340 battery
hIKARInoob
CR123 calculation is wrong. First, voltage of CR123 is rated at 3V. But under load of approximately 2A you get a voltage of about 2.25V: http://budgetlightforum.com/node/24632
So 2 of those in series you get 4.5V, and P = 4.5V x 2.2A = 9.9W.
This is the correct value for something like an XM-L2 emitter producing about 1000 lumens. This can be seen again in Cree’s specs: http://www.cree.com/led-components/products/xlamp-leds-discrete/xlamp-xm-l2
It says 10W @ 3A
Of course you still need to take into account driver efficiency, but I’ve excluded that for the time being.
So your light is working fine using 2xCR123 cells, but is doing something wrong using a single 18650 cell.
Overload
Overload's picture
Many thanx for the explanation Big Smile
hIKARInoob wrote:
CR123 calculation is wrong. First, voltage of CR123 is rated at 3V. But under load of approximately 2A you get a voltage of about 2.25V: http://budgetlightforum.com/node/24632 So 2 of those in series you get 4.5V, and P = 4.5V x 2.2A = 9.9W. This is the correct value for something like an XM-L2 emitter producing about 1000 lumens. This can be seen again in Cree’s specs: http://www.cree.com/led-components/products/xlamp-leds-discrete/xlamp-xm-l2 It says 10W @ 3A Of course you still need to take into account driver efficiency, but I’ve excluded that for the time being. So your light is working fine using 2xCR123 cells, but is doing something wrong using a single 18650 cell.
hIKARInoob
OK sorry for the potentially stupid question I’m going to ask. You know that by double clicking you can toggle between two outputs right? So in high/turbo you toggle between something like 1000 and 500 lumens.
Overload
Overload's picture
Yes, I did know that Wink
joechina
Last seen: 6 months 1 week ago
The H03 is rated at 900lm with a single 18650. With rounding and marketing included!
(there is also 1200lm printed on the box)
I think Skilhunt tends to exaggerate stuff, so the low amp reading is OK.
With an added second magnet it is my favourite EDC.
Mr_DuctTape
Last seen: 1 year 9 months ago
My apologies if I didn’t post appropriately but I have this wierd problem thats starting to happen with my H03. It behaves like the batteries are almost dead (the red low voltage flash with a faint drop and rise in output). It worked fine on all of my various batteries up until march. It really starts flipping out on both high groups and the next lowest below each group too. I don’t think its the cells being Ive used like 5 different kinds, when I check their voltage they are consistent with the amount of time I run it on 2 different chargers. I usually run it 2 levels down from the highs for the range I require.
