K60/70 battery carrier mod possibility
7 posts / 0 new
zeremefico
zeremefico's picture
Last seen: 2 days 18 hours ago
Acebeam’s battery carrier is now available to purchase as a part. I no longer own an Acebeam flashlight and I wonder if the carrier can be modded to fit in TK75/61 flashlight.
Can anyone who owns both flashlight measure the possibility?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Edited by: zeremefico on 06/27/2016 - 10:56
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 days 14 hours ago
I have a couple TK61’s that could use a XHP35 in one of them. Yes the carrier will work, with a little modification. The carrier O.D. is good, the height isn’t, the K70 carrier is about 5mm shorter and the + / – battery carrier contact would also have to be addressed. Which should be no big deal! The K70 would have to have a spring + (depending on how you would want to do it?) I would use a spring, and solder a larger – contact plate or copper washer to make up the difference in contact diameter’s. I would probably just bottom the carrier out against the driver PCB with a Delrin spacer or PVC tube cut to fit, or you could suspend the carrier at the back with a spring (s) ??? Naturally your dimensions might be different, BUT it is quite do-able! Wink Hope this helps ya!!
KB1428 “Live Life WOT
MRsDNF
MRsDNF's picture
Last seen: 4 months 6 days ago
Do you have a link for the battery carrier?
KawiBoy1428
Here ya go…. http://www.banggood.com/1pcs-Acebeam-Battery-Holder-For-K70-Flashlight-p...
It works in the SD75 if you turn the carrier PCB diameter’s down about 1-1.2mm too!
MRsDNF
MRsDNF's picture
Thanks for the link. Now we need a 50% discount code. Beer
wkhchin81
+1 here. Lol:)
CWK
KawiBoy1428
Got the K70 4S carriers today, thanks Bangood! All tested and work just fine, TK61XHP35?
