12 volts from a single 18650, is it possible?
8 posts / 0 new
lumenzilla
lumenzilla's picture
Last seen: 3 days 19 hours ago
Hi all,
I want to build my own coffee grinder using high torque motor (12 volts). Is there any available “driver” that can convert output from a single 18650 battery into 12 volts?
I want this grinder to be portable so I can use it without plug it into wall socket.
Any advise would be very much appreciated.
Thanks!
MtnDon
MtnDon's picture
Last seen: 4 hours 55 min ago
How many watts is that 12 v motor rated at? How long do you need to run it?
juaquin
Last seen: 2 years 1 month ago
Sure, you just need a boost converter that can handle the watts necessary (and a 18650 that can handle the current). Look around on eBay. Depending on the requirements of the motor it may be easier/smaller to just run three 18650’s in series.
lumenzilla
I planned to use this little motor
:http://www.banggood.com/N20-DC6V-100RPM-Gear-Motor-Miniature-High-Torque...
It will just run a couple of minute every time I want to grind coffee bean for my personal cup of coffee.
Then I found this buck driver, I hope it will work.
https://www.fasttech.com/products/1005/10002934/1219200
hank
hank's picture
Last seen: 1 week 10 hours ago
Firelight2
Firelight2's picture
Last seen: 53 min 56 sec ago
A “buck” driver is used to reduce the voltage, so that the output voltage is less than the input voltage. In this case, your input voltage is 3.7v (from the 18650) and you are seeking 12v output voltage. A buck driver will not work. You need a “boost” driver.
hank
hank's picture
Aside — do you already have a battery and charger?
If not, wait on advice. There are a few good choices, and many others.
lumenzilla
Thanks, I’ll look into it.
hank wrote:
Aside — do you already have a battery and charger? If not, wait on advice. There are a few good choices, and many others.
Absolutely, I have a few spare batteries and chargers. Thanks.
