4th annual scratch / OL build comp thread for pinkpanda
Although I have a few parts already this could be a slow build :sunglasses:
I should really get moving on this eh? What I wanted to achieve here is a 10+ lumen light with better runtime than a 4x cell or even 8x cell light while still not being too huge. Therefore heatsinking will be a priority. I roughly assembled the parts I have to give the general scope/idea/parameter and sat it beside an old dolphin torch. When I was little if your family didnā€™t have a dolphin they didnā€™t have ā€˜the light to haveā€™. And donā€™t worry about the mixed cells in the pic, they are for clarity purposes only and so is the black heatsink at this stage.
Ingredients -
Heatsink (this one is not entirely necessary but I got itā€¦.) Electronic Components and Parts Search | DigiKey Electronics
More heatsink with vapour chamber tech Dynatron R16 1U CPU Cooler w/ Vapor Chamber, Intel LGA 2011, i7, Xeon, Socket R | eBay
Driver http://www.ebay.com.au/itm/DC-DC-250W-10A-boost-converter-Constant-Current-Mobile-Power-supply-LED-Driver-/131768488032?hash=item1eae039060:g:9uIAAOSw6wRW~jDn
Battery indicator http://www.ebay.com.au/itm/Indicator-Coulometer-Capacity-Tester-8-50V-50A-Lithium-Lead-Acid-Battery-Meter-/381439639268?hash=item58cf92fee4:g:Wb0AAOSwo6lWH3Nf
Enclosure box http://www.jaycar.com.au/sealed-diecast-aluminum-enclosure-222-x-146-x-55mm/p/HB5050
15x led reflector left over from some mod I did ages ago.
15x leds (not sure of bin) https://www.cutter.com.au/proddetail.php?prod=cut2534
Cupboard handle from the hardware.
I realised at some point I will need to get a step down module to run the heatsink fan. I will also need to get some switches. Not sure what lens to use yet??
Power 12x 18650 made into a battery pack
Other stuff, battery tabs, thermal adhesive and probably lots of other stuff I didnā€™t account for.
So, given how much Iā€™ve forked out so far I hope to get this finished and flaming trees one day or iā€™ll be spewing about it. Maybe not as much of a challenge if itā€™s just parts assembly but this is my first attempt I guess.
Building -
Hmmā€¦ where to start? I thought Iā€™d start at the back. This might be an arse about way of ding things but thatā€™s me
So the very first thing I was getting stuck into I managed to stuff up :person_facepalming: To fix it I filed some of the board on the battery indicator and the end result is a small gap in the top right of the window.
You can see where I filed the edge of the board in this next pic
UPDATE 12/8/16
I did some work assembling the battery pack today. It occurred to me that I couldā€™ve used some lipo packs to fit the box shape better but it wouldā€™ve been additional cost and it just seems more fitting for the comp this way. I used a spacer from a Makita battery pack to hold the cells while I worked on them.
Whatā€™s wrong with this next picture??
Yeh, I forgot to solder the power leads on :person_facepalming: 2 things Iā€™ve done so far and 2 things I screwed up. I will fit the leads with deans plug (aka T plug) later, luckily I donā€™t need an adaptor for my charger >
this is exciting.
Yes I agree about the exciting part. Another mystery light. :stuck_out_tongue:
Good luck, PP!
Go Panda go!
Slow or not, we will keep an eye out for your creation.
Go Aussie!!
Thanks for the encouragement guys. I better try hard now :student:
i canā€™t see the photo.
Same here, photo wonā€™t load
Good luck!! :+1:
So much mystery that the picture wonā€™t load :stuck_out_tongue:
I am looking forwards to seeing your build, the picture in the OP and wish you good luck!
Doh! Really starting to irritate me now. I was persisting with google hosting because it automatically uploaded from my phone. Iā€™ll find some other hosting site.
This is going to be a beast alright!
It appears the biggest beast here at the moment is Google. :wink:
I can see one pic tho! :slight_smile: Itā€™s the biggest beast here.
Insert speechless here. Iā€™m sure beast may be an understatement. :person_facepalming:
By ā€œbeastā€ you mean ugly right ?! :laughing:
Letā€™s just say that you should never point that at any planes, trains, humans, or even any animals you like to keep around. :wink:
Thinking about it pinkpanda could well be a beast himself. If he was I reckon he would be a nice beast. :innocent:
