4th Annual BLF/OL Scratch Made Light Contest- Hand Made 10/31 finished
266 posts / 0 new
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 1 day ago
Just a small update. While house sitting for my folks I used Dad’s drill press to start the switch hole in the wood tube. After stepping up drill bits to 5/16” I used a Dremel sanding drum to do the rest. They came home Wednesday so I’ve since shifted operations back home to work on more small brass bits to squeeze in but I’m behind on picture taking. After tomorrow’s session I’ll post some more pics but it will likely be at a late hour PST.
Gluing and soldering
Scott
MRsDNF
MRsDNF's picture
Thats an interesting drill press. I haven’t seen one that the table moves up to drill the hole before.
If you keep posting pictures of your Burl I’m going to come around and knock it of so I can use it. Silly
lostheplot
lostheplot's picture
awsom cant wait to see the finished product
sorry all images down
thanks photobucket
Rufusbduck
Meh, once again had to move the contents of this post to the next one to get images to load.
Scott
Rufusbduck
After a whole lot of hole fiddling I hitched up my britches and glued up the tube. I greased up some older o-rings to seal in the epoxy and used a brass tube to keep the wood and brass holes aligned. Also pretinned the ground wire, reassembled my switch with the wires soldered to the tabs, reflowed a 219C, and assembled the pill. As you can see I also cut up a p60 pill to make a new retaining ring. I used my 20mm die and the failed retainer as a stop nut to cut the pill. and then drilled out the center with a step drill. Much of the fiddling had to do with the brass bits that line the switch hole and act as a button. The liner piece I’ll epoxy in place in the morning and the switch piece and tail cap get cabochons I ordered 3 weeks ago that arrived today.
Scott
Rufusbduck
A while ago I made these And now they look like this The larger one is now epoxied into the tube And the smaller one gets a moonstone cabochon. Another, larger cabochon goes into the tail cap with some trits underneath. I wasn’t sure if they would get here in time.This is what they look like
Replacement tail cap
Scott
CRX
CRX's picture
Cool.
lostheplot
moonstone is that what we call opal’s?
thanks photobucket
Rufusbduck
I think they’re different from Opals. They were certainly less expensive. Justin was fond of using cabochons to dress up a light so this is my way of showing respect in a contest that is part of his legacy. It has to be finished in time and work or it’s a hollow effort though. The head/pill is fully functional, what remains in doubt is whether my switch mod will handle the roughly 4A expected current draw. The driver is an RMM Mtn 17DD with A6 firmware. I still need to ream another few .1 mm’s from the tail cap to fit the stone and braze in a seat for it and finagle the switch pill together but I think there’s just enough time.
Scott
Rufusbduck
Hmm, tail cap seems to have slipped in the shower and the hammer fell out of the soap dish. So I spent most of the afternoon making a new one starting with a pill with the shelf removed. Then clamped in the hack saw blade to remove the taper. And added a few more brass bits. Both the spring and the cabochon fit into the hollow but I need a shelf ~4 mm from the threaded end for the spring. And with the spring soldered in I could epoxy the wood in place as well. And the stone fits in the other end. I won’t glue it in until it’s closer to finished but at least now I can get going on the sanding. Assembling the switch pill
Scott
MRsDNF
MRsDNF's picture
So close.
Rufusbduck
All set to assemble the switch pill. Here are the two boards glued together(contact board has a notch for the led board). Here’s the backside, led is connected to the contact board after the switch. JB weld is used to isolate the metal bottom of the switch from ground(case). Will it fit? YES! Now to solder up a positive spring pad that I ground thinner and smaller from a 1-mode nanjg board. Then soldered it to the red wire and JB welded it in place. Sliding it into the battery tube it ended up pretty well centered. A solder dab on the locator/ground wire will fix it in place but that’s after the finishing us done, probably Sunday. All the rest of the brazing and fitting is done, woohoo.
Finishing up
Scott
MRsDNF
MRsDNF's picture
I love it and understand it for once. That is so novel. Thumbs Up
MtnDon
MtnDon's picture
Last seen: 6 hours 13 min ago
Amazing! RBD’s work that is, not DNF’s understanding. Facepalm
Rufusbduck
Big Smile So far everything has tested out functional but it won’t get a current draw test until the very end when I hope to do beam & glam shots. I’m pretty psyched though.
Scott
DavidEF
DavidEF's picture
Last seen: 2 weeks 2 days ago
Looks great, RBD! I’m excited too! I wanna see the beam shots and glam shots!
- The YKK Philosophy
TexasLumens
TexasLumens's picture
Last seen: 1 year 1 month ago
Nice work….and a ton of it Rufus!!! Super duper innovative and beautiful even before finished.
Thank You For Sharing All This Work!!!! TL
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Rufusbduck
Thanks TL, when I modded a 502b last year with a cherry tube Steve suggested I make one all of wood so this year I went for it. Not quite all wood but a lot more wood anyway.
Scott
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 10 months ago
Rufusbduck wrote:
I'm pretty psyched though.
You're psyched?  I'm falling off the edge of my seat! I would say I love you but no one would understand, but I love your work for sure!laughing
Hell, must be the med mads...tongue-out
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Rufusbduck
3rd of 4 coats of epoxy done so tomorrow night I’ll polish it up. Dry weight of host only is roughly 106g.
Scott
TexasLumens
Beautiful Rufus!!!! Tell us…me…. About finishing with epoxy. I don’t work with wood much but I am sure curious as to how you do that.
GREAT WORK!!!!!!! TL
FmC
FmC's picture
Have not checked in here for a while – this work is astounding! Smile
Rufusbduck
Thanks FmC, this is the final build post, it’s all done. Tired
Some final fitting and glue ups. I trimmed the front end threads to length. Glued 3 trits to the back of the tail cap cabochon. Glued thd switch cabochon into its holder. Also sanded out some scratches in the brass bezel and aluminum fins and polished them. PAfter the cabochons had cured I glued the larger one into the tail cap resting it in a flat surface so it will be sure to tail stand without rocking but still be as far out as possible. With all the parts now ready it’s time to put it all together. And see if it works. All seven modes work perfectly including batt check (Mtn17DD) but I’ll probably switch to 4. I’ll just show moon and turbo since the camera makes the rest look pretty much the same. The wall is actually a pastel green so tint is skewed. At seven feet the hot spot is roughly 7” across which is ok for such a small reflector even though it’s deeper than a p60 the OD is about the same. Size wise it’s a tad longer than an L2M but still has a thinner head so it’s pretty handy, especially with the thumb switch.
Scott
FmC
FmC's picture
Thumbs Up Thumbs Up Love
Bravo Smile
southland
southland's picture
Last seen: 2 months 5 days ago
Beautiful light, really impressive.
DavidEF
DavidEF's picture
Good looking light!
giorgoskok
giorgoskok's picture
Last seen: 1 week 3 days ago
Incredible !
lostheplot
You have excelled ….
thanks photobucket
TexasLumens
WOW! Rufus, that it absolutely stunning!!! What a beautiful piece of work.
TL
RobertB
RobertB's picture
Last seen: 1 day 7 hours ago
+1, very impressive, Nice Job!
