Interesting Noxluxx "built-to-order" xhp70 flashlight - thrower
I ran across this on ebay while searching xhp70…
(click photo for the ebay listing)
Website: http://noxlux.webstoreplace.com/item/-4100-lumen-led-tactical-flashlight-cree-xhp70-6v-noxluxx-extreme-high-output/322055657736/
Very interesting xhp70 in a SMO reflector, advertised as a thrower
It looks like a Crelant 7G5CS…
“This product is Noxluxx’s version of a classic Crelent full size flashlight”
Looking at the website it’s the Small Sun ZY-T13 (Small Sun’s version of the 7G5CS)
In the description it says:
“It is powered by 2 18650 IMR lithium rechargeable type cells”
But the photo shows a single cell version. I wonder what the tube is?
Also they advertise the xhp70 emitter is “THE NEWLY RELEASED CREE XHP70 P2-1C”
I like how the on their website they have links to the Cree data sheets for the emitter.
Also interesting is the advertised “Rubber Grip” looks like shrink wrap or some type of sprayed on rubberized coating?
I like the “dual” tail switch with removable remote mount pressure switch. (Surefire style)
it looks like the same as the one on the Small Sun ZY-T27 Also I’m wondering if the ZY-T27 single tube would fit the ZY-T16
Makes me want to try to mod my Small Sun ZY-T13, I had been thinking about putting an MT-G2 in it.
And I see Noxluxx is a member here but I couldn’t find any mention of his lights anywhere on the forum. Maybe he will chime in with some further info. It looks like he’s done a nice job putting together and advertising this flashlight!
This photo was already posted on blf, try to use search by image.
Never searched by image before but I just tried with no results, what would I put in the search box? (I tried Noxluxx)
Also tried Noxluxx in the regular search and nothing.
Hey beam0,
Just came across this post. Is there something I can help you with specifically?
I’d be glad to talk about the pro’s and cons of this build.
That looks like Sunwayman T40CS head and Sunwayman remote pressure switch!
I’ve ordered from noxxluxx or dehc111 I do recommend buying from him,very quick service and quality too. I don’t believe you will be disappointed.
Thanx for the support Andy.
Hunter>>>> The hosts are Small Suns. ZY-T13 head and ZY-T27 tube and tail switch. No mod needed as they fit perfectly together.
I had this listed on ebay for a while but very few were interested so I took it off. It is a 1 off light basically cause I dont care much for zoomi’s but the T27 had a good quality tail switch. The configuration employs 18350’s to power an XHP70 P2 from mtn elec… I constructed the light with weapon mounting in mind. All it really needs is an OP reflector. It is difficult to exactly focus a dedomed emitter so as to remove any artifacts from the beam profile of a smooth reflector but it can be done. The driver is a FET/DD for now. I think I may have found a better driver which will provide for the side switch functionality.
Personally I really like the Small Sun brand of flashlights. A little effort and time replacing and/or correcting their shortfalls yields a high quality product.
