Test/Review of Efest IMR26650 4200mAh (Purple) 2016
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 17 hours 12 min ago
DSC_3294
Official specifications:
  • Rated capacity: 4200mAh
  • Rated voltage: 3.7V
  • Max continuous discharge current: 40A
  • Pulse discharge current: 60A
  • Lifetime: 500 cycles to 60%
Efest%20IMR26650%204200mAh%20(Purple)%202016-info
A 26650 cell with current rating.
DSC_3293
DSC_3295 DSC_3296
DSC_3297
DSC_3298
DSC_3299
Efest%20IMR26650%204200mAh%20(Purple)%202016-Capacity
The discharge curves tracks fairly well and capacity is nearly constant with load.
Efest%20IMR26650%204200mAh%20(Purple)%202016-Temp-15.0
Efest%20IMR26650%204200mAh%20(Purple)%202016-Temp-20.0
Efest%20IMR26650%204200mAh%20(Purple)%202016-Temp-30.0
The battery gets very warm at 30A.
Efest%20IMR26650%204200mAh%20(Purple)%202016-CapacityTimeHours
Efest%20IMR26650%204200mAh%20(Purple)%202016-Energy
Efest%20IMR26650%204200mAh%20(Purple)%202016-PowerLoadTime
Efest%20IMR26650%204200mAh%20(Purple)%202016-TripCurrent
Efest%20IMR26650%204200mAh%20(Purple)%202016-Charge
Conclusion
The battery has good performance, but I doubt the 40A rating.
Notes and links
The batteries was supplied by Efest for a review.
Compare to 18650 and other batteries
EasyB
Last seen: 4 hours 40 min ago
Thanks, this looks like a real low IR performer. Interestingly I just tested a purple Efest 4200mAh I got from MTN this March, and the curve looks different. The one I tested has the hump around mid-discharge, similar to the vappower 4200mAh 26650 cell you tested. I guess this is an example of how Efest rewraps cells and you won’t necessarily get the same cell when you buy. Fortunately, from what I’ve seen, they use quality cells.
http://budgetlightforum.com/comment/979913#comment-979913
sidecross
sidecross's picture
Last seen: 4 years 7 months ago
Again thank you HKJ for these reviews.
This is the newer 2016 Efest battery and it may have been changed or upgraded. In any event a battery test is only relevant to that battery; we assume that other batteries of this production cycle are the same. This assumption would be difficult to verify.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
