10440 li-ion battery and charger suggestions
42 posts / 0 new
Nothing
Last seen: 1 year 8 months ago
I would have thought that the charging current was too high for 300mah-ish batteries but Old4570 has tested it with 10440s and explains why he thinks the initial charge rate of 450ma is not a real issue in this post.
Most of my charger information is second hand from the CPF Shekor review, Ultrafire WF-188 test  and the cradle charger roundup which you’ve probably already read but I see Nil Einne has received one so will be good to read his findings if he posts them.
When I was looking a few weeks ago I couldn’t find any of the Flame packaged 10440s either, only blue and grey.
Cheers,
Gary
fishinfool
fishinfool's picture
Last seen: 2 years 3 months ago
Thanks Gary!  Right now I have the Trustfire TR-002 and the Universal Smart Quick Charger on my list.  I might just get both unless I find something better.  As you know, there aren't a lot of 10440 chargers and batteries for that matter out there compared to the other size batteries.  As for batteries, I'm looking at the blue UltraFire Protected 10440 3.6V 500mAh and the gray TrustFire Protected 10440 "600mAh" 3.7V.
I'm still looking though and thanks to everyone for all of your help.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
midieval10
Last seen: 9 years 2 months ago
What is the difference between the Trustfire TR-001 and TR-002? Is it 1 port vs. 2 ports?
fran82
Last seen: 11 months 3 weeks ago
Yes, external appareance, number of channels, and lack of 12v input in the case of TR-002.
Internally, I imagine that circuitry is the same
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
fishinfool
So other than one being a single cell charger and the other a 2 cell charger, is there much of a difference?  Is one better or more reliable than the other?  Is the TR-002 a newer model?
fran82
I prefer the TR-001 for its 12volt input. You can use always the 12v input to avoid explosions (is the internal power supply what explodes), and also the 12volt input is nice for using in your car, solar panel, etc...........
With the 12v input, with the appropiate connector, you can make it work from 7volt to 16 volt DC.
So in a case of a 220volt power outage, if you have a 12volt SLA battery, or a 9volt alkaline battery or a battery pack of appropiate voltage, you can charge your li-ions, and you always will have your flashlights running, while the SLA battery or whatever keeps charged.
I have read that circuitry of TR-001 is better than the 002. But if you see photos of the inside, they seem identical, but circuitry only for 1 channel, not 2
fishinfool
Thanks fran, looks like the TR-001 is back on the top of my list but I am thinking about getting 2 chargers.  Maybe the TR-001 and the TR-002 so I have a back-up charger.  Smile
peteybaby
peteybaby's picture
Last seen: 1 week 2 days ago
Does anyone know of a charger that can accommodate three 18650s, and has selectable charge current so that I can charge 18650s at high current but 10440s at low current (not simultaneously)?
E1320
E1320's picture
Last seen: 9 months 5 days ago
This is the one I have it is the TR-001 with a tenergy sticker on it from amazon so you don't have to wait forever for DX to send it.
http://www.amazon.com/gp/product/B0026NA9GE
I am already visualizing the duct tape over your mouth.
peteybaby
peteybaby's picture
Thanks for the suggestion, but that accommodates only two cells.  Smile
fishmaniac
fishmaniac's picture
Last seen: 7 years 1 week ago
Personally, I would wait 2-3 weeks at that price. Wink
I use the TR-001 as well and all my cells come off the charger at 4.17v. It doesn't get hot while in use nor do my cells (slightest bit of "warm" though). But, it trickle charges if left in the charger after the green light. It adds about .01v every 60 min or so. I've accidently left a 17670 overnight and it was up to 4.25v by morning.
TR-001 link
