AWT 26650 Li-ion Battery - RED or YELLOW ???
AWT 26650 Li-ion Batteries at GearBest
RED 5200mAh 45A 3.7V IMR Protected…or…
YELLOW 4500mAh 75A 3.7V IMR Protected
I tried a search on these…sold via Gear Best. Anyone have any experience or knowledge re these?
The discharge voltage on the Yellow is rated at 75Amps vs the Red at 45Amps. Would the Yellow Protected be a good one to run in series in a Convoy L6 or L2? Battery length is listed as being 65mm.
Thanks.
Edit: Never mind, I finally found the mother lode of AMT tests. Case closed.
