Zooming Model List (2018 Updated) Tell us about your newest zoomie!
629 posts / 0 new
bcm00re
Last seen: 8 hours 13 min ago
MascaratumB wrote:
Nicron N81
Says it takes 1 AA or 1 18650 Flat Stare Weird…
Here’s the link anyway :
https://www.aliexpress.com/item/4000077606652.html?spm=a2g0o.productlist...
Anyone have this light? I am interested because it can run on several different sizes/types of batteries. So far I haven’t been able to find a review.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 7 hours 7 min ago
bcm00re wrote:
MascaratumB wrote:
Nicron N81 Says it takes 1 AA or 1 18650 Flat Stare Weird... Here's the link anyway : https://www.aliexpress.com/item/4000077606652.html?spm=a2g0o.productlist...
Anyone have this light? I am interested because it can run on several different sizes/types of batteries. So far I haven't been able to find a review.
It's on Amazon for $10 bucks. Reviews are positive (for what common Amazon reviews are worth). I could spring for one.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
bcm00re
Nachtfeuerzeug wrote:
It’s on Amazon for $10 bucks. Reviews are positive (for what common Amazon reviews are worth). I could spring for one.
Yeah, I saw it on Amazon last week — I finally sprung for it tonight. I’ll post my impressions once I get some time with it.
Nachtfeuerzeug
Yeah, I saw it on Amazon last week -- I finally sprung for it tonight. I'll post my impressions once I get some time with it.
Sounds good! I'd like to see inside of the tail and the pill if possible. Thank you!
EDC
Reviews:
MascaratumB
MascaratumB's picture
Last seen: 10 min 17 sec ago
Sounds good! I’d like to see inside of the tail and the pill if possible. Thank you!
There’s an overview in this video:
https://www.youtube.com/watch?v=7NbuXonqaZ4
Nachtfeuerzeug
Thank you!
EDC
Reviews:
MascaratumB
Thank you!
Thumbs Up
Another review (some more details) of the N81: https://www.youtube.com/watch?v=3IczhQMTxrE
Nachtfeuerzeug
That's an even better review!
I've been working with this: latest zoomie project
Looks every bit the same as the XANES 1123A
Tear down:
This is ok:
This, ugly, but ok outside:
The LED is a little higher on the DTP MCPCB so it doesn't focus but it throws just fine.
Update: I went for the harder driver, Convoy 6A, 4 mode, and despite the removable pill shelf, it transfers heat really well.  I am using a LH351D on DTP MCPCB and added thermal paste to the threads that hold the pill in place.  There's probably a way to fix it but once the stock driver is removed, the USB charging function doesn't. The built-in charger is not that good anyway.
EDC
Reviews:
bcm00re
That’s an even better review!
I’ve been working with this: latest zoomie project
My light arrived today. Let me know if you didn’t get all the info you needed from that second review.
LightObsession
Last seen: 3 days 13 hours ago
Anyone know of a pocket clip that works for the Nicron N81?
I probably wouldn’t use the light without a pocket clip.
It appears that you have to go through the blinky modes as part of the mode sequence and can’t avoid them without turning the light off for a moment before you get to them and then turning the light back on to get high mode again. Is that correct? At least you don’t have to go through the blinky modes to turn the light off.
Thanks.
Nachtfeuerzeug
My light arrived today. Let me know if you didn't get all the info you needed from that second review.
Thank you! I'd like to see the switch assembly and the pill, if possible without destroying your light.
EDC
Reviews:
Agro
Agro's picture
Last seen: 1 min 7 sec ago
A nice looking, fairly compact 18650 twisty zoomie:
https://www.aliexpress.com/item/32977647868.html
Agro
Agro's picture
A fairly small 18650 zoomie, 27×115mm.
https://www.aliexpress.com/item/32696321312.html
Agro
Agro's picture
And another, 117×25mm
This one comes with 2 LEDs, white and UV
https://www.aliexpress.com/item/32774685962.html
A seriously small 26650 zoomie, 106×30mm:
https://www.aliexpress.com/item/32792123759.html
For comparison, Emisar D4S is 105×39 mm.
I see a recommendation to avoid it I’m not sure if that’s a killer for someone looking for a modding host.
18650, 117×23 mm
https://www.aliexpress.com/item/2050936588.html
Agro
Agro's picture
I am proud of the latest finding.
Some may remember Aleto N8. With 108×24 mm size it was one of the smallest 18650 zoomies ever manufactured.
Firelight2 modded one to create probably the smallest 18650 zoomie ever made.
Aleto N8 was availabe for sale only for a while and disappeared years ago.
Now I found a Yaoming light that appears very similar but, a sign of the times, comes with a USB port under the bezel.
Sadly, so far I found 0 information about it outside of what is on the sale page. Among others – I don’t know the size.
It is not present on Yaoming website and I failed to find other sellers. I asked Yaoming about it.
https://www.aliexpress.com/item/32468838297.html
luminarium iaculator
luminarium iaculator's picture
Last seen: 16 hours 34 min ago
Anyone managed to find small zoomie host with glass aspherical lens, 18650 cell only (1”, 25mm tube), andodized threads as very important lock out safety feature, without redundant parts like usb charging port?
Only 1 light with everything mentioned is On the Road Z821 which seems discontinued…
Agro
Agro's picture
I found a cheap clone of On The Road Z821:
http://www.aliexpress.com/item/33020880233.html
SKV89
Last seen: 7 hours 4 min ago
This Yaoming brand does have a bunch of very interesting looking lights. Too bad no information of how they perform or modability.
Agro
Agro's picture
I purchased it…the seller didn’t ship. I messaged them to find out whether the failure to ship was some temporary or permanent issue but got no response. Sad
SKV89
That sucks but with ocassional sellers on Aliexpress, it sometimes takes a Loooooonggg time to ship. But good news is you will get your refund if you open a dispute against the seller.
Agro
Agro's picture
Since the seller didn’t claim it was shipped, I got an immediate refund.
SKV89
Yea that’s the good thing with Aliexpress. Their buyer’s protection is much better than Banggood. I’ve disputed with BG several times and although I got what I wanted each time, it took more effort and a longer process. I just wish the prices on Ali could match BG.
Firelight2
Firelight2's picture
Last seen: 6 hours 2 min ago
Well at least you got your refund.
I’m curious as to whether that is really 18650 or if it is actually AA/14500. From the picture the cut of the lens and heatsink fins looks closer to the standard AA version than the Aleto N8’s 18650 version.
Serlite
Last seen: 8 hours 22 min ago
Thanks.
Yeah, I got the Nicron N81 because I saw it here and liked the look of it – and the blinky modes are part of the main sequence.
However, I’m okay with that since it doesn’t have mode memory, and also doesn’t have a lot of brightness modes – if I missed the one I wanted, it’s simple enough to turn the light off and try again.
SKV89
Anyone used the Wuben L60, which will be on sale for $25.83 on 11/11 and could be even cheaper with coupons
The Wuben LT35 Pro looks interesting too but is not on sale.
The reflector is painted white instead of black. I’m guessing it minimize lumen loss.
flightless22
flightless22's picture
Last seen: 22 min ago
The L60 is on sale for ~$18 at amazon
There’s not much search results for L60 but The LT35 (not pro) looks remarkably similar to L60
SKV89
I was going to order it for that price but turns out the code doesn’t work. Guess it is expired. The LT35 Pro looks like a smaller head version of the L60.
Agro
Agro's picture
Cheap 18650 light with side switch and USB port:
http://www.aliexpress.com/item/32920225673.html
Agro
Agro's picture
This seems to be one of the smallest AA zoomies, 20×90 mm:
http://www.aliexpress.com/item/32949995829.html
https://www.alibaba.com/product-detail/Most-popular-sexy-design-logo-fla...
Would like to get one but a little cheaper. Wink
Mike C
Mike C's picture
Last seen: 2 hours 58 min ago
First of all, thanks for updating this thread when you find stuff like this.
This particular light (host) has my interest indeed. I’ve been on the lookout for a E-switch zoomie with a USB port on the side. I’ve seen a few with the USB port on the tailcap but I want it on the side in direct contact with the driver as I’ve developed drivers with support for flashing by USB port. It’s probably a junk host as it is but with luck maybe it can be modded.
