Zooming Model List (2018 Updated) Tell us about your newest zoomie!
629 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 44 min 57 sec ago
luminarium iaculator
luminarium iaculator's picture
Last seen: 23 hours 44 min ago
MascaratumB wrote:
Add the On The Road Z803 https://www.aliexpress.com/item/1005001987629617.html
Big flashlight with a small lens…
Manufacturers should tend to have as large lens possible in as small host package possible but of course… Most China engineers can’t figure that out…
Tom E
Tom E's picture
Last seen: 2 hours 1 min ago
Ohhh, I see. The FT listing shows the lens size well: https://www.fasttech.com/product/4206303-on-the-road-z803-zooming-led-flashlight-gift-set
Yikes! Totally agree - wut were they think'n?
Of course I'm always interested in something different w/e-switch to mod. This SupFire F15-T looks interesting:
aliexpress.com - SupFire F15-T
It's got an LCD panel and it seems to match the display info of the Neal (no-name) LEP - must be a common design used and re-used, etc.
The F15 is the reflector version, while the F15-T is the aspheric zoom version - listing is confusing the two models.
Agro
Agro's picture
Last seen: 3 min 4 sec ago
Yikes! Totally agree – wut were they think’n?
Of course I’m always interested in something different w/e-switch to mod. This SupFire F15-T looks interesting:
aliexpress.com – SupFire F15-T
It’s got an LCD panel and it seems to match the display info of the Neal (no-name) LEP – must be a common design used and re-used, etc.
The F15 is the reflector version, while the F15-T is the aspheric zoom version – listing is confusing the two models.
I just noticed that it comes with a powerbank. Cool. What is your plan for it?
Tom E
Tom E's picture
Not sure if I'll order it. From the looks and features, it's possible the driver could be exactly the same, or same physically as the Neal no-name LEP, and if so, it's not an easy driver mod/upgrade. Lot depends on the switch - if it's driver mounted or separate round PCB in the housing.
Overall though, it looks decent - nice look'n design, SS bezel, relatively compact, simple push/pull zoom, etc. Someone here at work questions the heat effect on those LCD panels - not sure what they are typically rated it, specially if we crank up the amps. The no-name LEP is low power.
Agro
Agro's picture
10850 zoomie from warsun:
https://www.aliexpress.com/item/1005001864313976.html
I haven’t seen such battery used in flashlights before.
Agro
Agro's picture
Agro
Agro's picture
A nice looking zoomie family:
https://www.alibaba.com/product-detail/Patented-Waterproof-Zoomable-High-Power-LED_60272564051.html
Though some detailed images don’t looks so well:
What kind of lens does this have? TIR?
https://www.alibaba.com/product-detail/Aluminum-high-power-led-torch-lig...
Agro
Agro's picture
Oh, the C-star zoomies are available with USB at the tail (I assume the head-rechargable light doesn’t zoom).
And waterproofing of the port looks good.
https://www.alibaba.com/product-detail/High-Power-led-flashlight-recharg...
raccoon city
raccoon city's picture
Last seen: 1 hour 5 min ago
raccoon city wrote:
I was thinking about ordering this Skywolfeye E527 for my niece.
https://www.aliexpress.com/item/32732619540.html
skywolfeye_e527
Bad news for me.
The flashlight never arrived, though I did get my money back through AliExpress.
And now this flashlight isn't available from this seller anymore, and it's quite a bit more expensive elsewhere.
It's a shame, too, because I think it's a fairly handsome el cheapo flashlight.
JaredM
JaredM's picture
Last seen: 2 hours 52 min ago
Agro
Agro's picture
Looks interesting. Smile
Tom E
Tom E's picture
I'm thinking it's interesting as well, but not sure how the batteries are setup. If parallel and accessible/removable like a Sofirn SP36 than I'd buy one to play with and hope to mod.
Agro
Agro's picture
They look parallel on one rendering:
Though naturally this should be taken with a grain of salt.
JaredM
JaredM's picture
contactcr
Last seen: 4 hours 21 min ago
Quote:
- Suitable for 23mm driver board and 26mm LED
Strange choice
JaredM
JaredM's picture
Sari33
Last seen: 3 days 7 hours ago
Not best looking but seem decent built for be “Wasafire”
I would see a 14500 or 18650 version with brass pill and retainer driver ring
Firelight2
Firelight2's picture
Last seen: 1 hour 2 min ago
I have one of those JaredM. Or at least one that’s probably the same as I got it a few years ago. Some features of the one I have:
  • Tailcap electronic switch. Actually, I think the entire driver might be in the tail though I don’t recall if I removed the board at the top of the battery compartment to check whether it has components on it or is just a contact plate. This is very unusual for a cheapie zoomie.
  • Fairly easy to emitter swap.
  • UI is one press for high, second press for low, third press for off (ugh). And because it’s a tailcap driver with built-in electronic switch, this probably can’t be changed.
  • There is a red/green LED under the translucent black-tinted switchboot. The button lights up and starts flashing when voltage gets low. Or at least that is what is supposed to happen. Might lights up and flashes pretty much all the time the light is on.
  • The styling is modeled after Nitecore. However, as a zoomie, this light has different construction.
  • The heatsink fins are useless as they are mounted on the sliding bezel.
  • I only tried the light with 16340 and it works fine. I considered boring the battery compartment to fit 18350, but concluded it probably wouldn’t work as the neck of the light under the bezel wasn’t wide enough.
  • Fairly good matte black anodizing for a cheapie zoomie.
  • For those who don’t want to worry about a tailcap magnet catching on their keys or getting near their credit cards, the tailcap magnet can be demagnetized by holding the tip of a soldering iron to it. Just make sure to do this after you disassemble the tail and remove the rubber switch boot.
Agro
Agro's picture
I’ve been away for a while…are they any nice zoomies that appeared recently? Smile
JaredM
JaredM's picture
Nice to see you back Agro! Was worried about you.
Agro
Agro's picture
I went away because I feel that I hit the wall with this hobby.
To progress further I would have to either go into modding (I dipped my toes and I don’t enjoy it) or go into flashlight business (which I am not interested in). With nothing more to achieve I largely lost interest.
But not fully. I think I will stay here for a few days again (it feels good to be back) but then leave again….
Barkuti
Barkuti's picture
Last seen: 18 hours 34 min ago
Funner wrote:
I also ordered their 26650 "Fishing light Host" version, hopefully it's not as cheap.
Mmm, how did it go? Smile
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Barkuti
Barkuti's picture
Mmm, 0K. Here we go again:
Who among you tried Kaidomain's zoomable led fishing flashlight host? Is the MCPCB holder meant for 5050 leds? Hole diameter? Comments?
Thanks.
Josh V
Last seen: 2 weeks 2 days ago
luminarium iaculator wrote:
Guys,
Agro or anyone else with zoomie obsession needed here! Detective work…
I found a small gem of zoomie flashlights host!
It is no name zoomie or no OEM zoomie light with 850nm emitter.
I found a brand named ActiveFire Click on Aliexpress
I also found a flashlight that looks like a Convoy S2+ Zoomie version
Here is the link for the Zoomie S2+ style
It’s pretty hard nowdays to a find a cheap so-so 2xAA flashlight, there is just 1 seller that sells the Skywolfeye B17 and the B32 that each costs $4 and the shipping about $5 so around $9 in total which is almost a S2 host, so does not worth it.
JaredM
JaredM's picture
Here’s a ‘clean’ link to the S2+ style zoomy. https://www.aliexpress.com/item/1005003263133572.html
Josh V
Well I don’t receive a thing since I’m not an affiliate, just pasted the link from google images, so that’s why the id’s and values.
JaredM
JaredM's picture
I am not suggesting it was intentional or malicious. I just can’t stand these mile-long, tracker laiden links. All good Thumbs Up
