Zooming Model List (2018 Updated) Tell us about your newest zoomie!
629 posts / 0 new
beam0
beam0's picture
Last seen: 3 hours 25 min ago
kramer5150 wrote:
Cool… Curious its just a single aspheric optic correct? So OTF lumens decreases when the die image is brought into focus… correct?
Yes only one single convex lens. I don’t have a light meter, however in my “eyeball” ceiling bounce test it does appear to have less output when zoomed in to spot, compared to out wide at flood.
beam0
beam0's picture
Newlumen wrote:
Nice beam0, one guy from amazon reviewed a3s and he got 1500 lumen using sony vtc5a.. wow. I cant wait to see your beamshots.
Well, no beam shots yet… The first thing that struck me was it’s size, it’s is way smaller than it looked in the photos.
I don’t have a light meter but this thing is really bright on a 30Q. I had to use a magnet on the tail for the 30Q because of the battery length issue (it uses a USB charging type cell that is longer than usual, and the battery compartment was made longer to accommodate it, making it too long for usual cells)
…………….Battery size difference…………………………Magnet on battery negative end………………………Battery with magnet……………. . .
…………………..A few comparison pics……………………………………………and with Convoy 18350 tube………………………
I compared it with my low tech eyeball ceiling bounce test and it’s just as bright as my BLF A6 (no spring bypass, so probably around 1300lm) Also as bright as my new 1380lm Litesam PS16. I’d say it’s putting out at least 1300lm on the 30Q.
I love this light! The zooming action is sooooo smooth and “just right tight” the beam pattern is perfect, no rings, artifacts or dark spots throughout the entire zooming travel. The flood beam is great.. just a big smooth even perfect circle of light. The tint is on the cool end of neutral and it’s pure white. No yellow or blue at all. The UI is excellent. The switch is excellent, it has great knurling and feels nice and solid in the hand.
The only things I would have liked would be a flat stainless “Foy” bezel. (I’m not too fond of the crenelated bezels) Love the stainless bezels. Also the head could have been made a bit thinner, it’s way thick at the front surrounding the lens. At this size they could’ve put a bigger diameter optic in it.
I’m real happy with this light, it’s hands down my best zoomie right now, and really awesome with the Convoy 18350 tube and Aspire IMR 1100!
EDIT; this is actually the Jaxman tube, which is slightly longer than the Convoy.
Here it is with the Convoy tube:
SKV89
Last seen: 1 week 2 days ago
The new Warsun X80 looks pretty interesting.
beam0
beam0's picture
Wow, it does indeed! Thanks, I’ll add it to the list!
Although the price is quite high for Warsun…
The similar sized Jaxman Z1 is $1.00 less with choice of tint, better UI and confirmed to have high quality lens.
https://www.aliexpress.com/store/product/JAXMAN-Z1-Turning-Optical-Zoom-...CREE-XHP50-26650-LED/1812094_32480542912.html?spm=2114.12010615.0.0.3605790768dYdD
beam0
beam0's picture
Hard to resist trying this one for $21.80 right now.
BRETT confirmed the CCT is 5500K-5900K.
https://www.aliexpress.com/item/New-LED-Tactical-Flashlight-CREE-XHP50-XHP70-Highlight-5000Lumens-zoomable-Lanterna-LED-Aluminum-2-mode-LED/32853466606.html?spm=2114.search0104.3.16.720b2fa7ZgBr8z&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10546_10343_10340_10548_10341_10545_10084_10083_10618_10307_5711211_10313_10059_5722311_10534_100031_10103_10624_10623_10622_10621_10620_10142,searchweb201603_25,ppcSwitch_2&algo_expid=806080e9-37c2-4801-b11e-5858c4f9f86a-2&algo_pvid=806080e9-37c2-4801-b11e-5858c4f9f86a&transAbTest=ae803_5&priceBeautifyAB=0
Agro
Agro's picture
Last seen: 1 min 29 sec ago
Is there a good way to get Wowtacs to Europe?
djozz
djozz's picture
Last seen: 2 hours 13 min ago
But look at that huge zooming movement, they used a very shallow (long focal length) lens resulting in tons of light loss when zooming in (so a small hotspot). Not all is bad about that though, the flood will be very wide.
beam0
beam0's picture
The 30mm zooming travel in particular was something I thought to be an advantage for wide flood,thanks for confirming that!
What do you mean by shallow lens? Are you referring to the depth it sits down in the bezel?
In the front view showing the emitter it looks like the lens is not there for that photo.
In this photo it looks normal depth (maybe?):
Can’t see much else about the lens in the listing, but I was informed it’s a plastic lens.
Front view: (looks like lens is removed):
There is this photo of the die image where appears to be fully zoomed in, (but probably pretty close to the wall):
Also the price went up today about $1, now $22.84
beam0
beam0's picture
Underwater (Diving) Zoomies:
Black:
https://www.aliexpress.com/item/ARCHON-D10U-Aluminum-alloy-Waterproof-XM...LED-Flashlight-Torch/32855019618.html?spm=2114.search0104.3.78.4d746f32jsou3P&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10344_10068_10130_5722815_10324_10342_10547_10325_10343_10546_10340_10341_10548_5722915_10698_10545_10697_5722615_10696_10084_10083_10618_10307_5722715_5711215_10059_5723015_10534_308_100031_10103_441_10624_10623_10622_5711315_5722515_10621_10620,searchweb201603_28,ppcSwitch_2&algo_expid=31bbc72a-7ca9-42e2-a641-077376b77ac5-12&algo_pvid=31bbc72a-7ca9-42e2-a641-077376b77ac5&priceBeautifyAB=0
https://www.banggood.com/ARCHON-D10U-XM-L-U2-860LM-60M-Diving-LED-Flashlight-p-919799.html?rmmds=search&cur_warehouse=CN
(Pink) Rose Gold: https://www.aliexpress.com/item/ARCHON-D10U-W16G-LED-860-Lumens-Underwater-zoomable-Diving-Light-underwater-photographing-light-100m-With-Hand/32855242693.html?spm=2114.search0104.3.60.4d746f32jsou3P&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10344_10068_10130_5722815_10324_10342_10547_10325_10343_10546_10340_10341_10548_5722915_10698_10545_10697_5722615_10696_10084_10083_10618_10307_5722715_5711215_10059_5723015_10534_308_100031_10103_441_10624_10623_10622_5711315_5722515_10621_10620,searchweb201603_28,ppcSwitch_2&algo_expid=31bbc72a-7ca9-42e2-a641-077376b77ac5-9&algo_pvid=31bbc72a-7ca9-42e2-a641-077376b77ac5&priceBeautifyAB=0
beam0
beam0's picture
Countryman CREE XPL 1000 Lumen 18650 mechanical Zoom Flashlight
From Enogear
  • CW 6500K or NW 5C 4000K
  • XP-L on Copper
  • Brass pill
  • Glass lens
  • HAIII
Looks pretty nice for only $36.00 Anyone have one or know about it?
http://www.enogear.com/pd.jsp?id=168#_pp=0_455_5
Mike C
Mike C's picture
Last seen: 1 week 1 day ago
Interesting design on those Archon’s. Looks a twist zoom that can be operated with one hand.
djozz
djozz's picture
I did a review on the Archon D10U in 2014: http://budgetlightforum.com/node/30931
Mike C
Mike C's picture
Ahh, it’s been around for some time I see. Thanks.
djozz
djozz's picture
But pink is new! Party
beam0
beam0's picture
You’ve got me curious now how that might work? I’m not seeing what’s different from any twist zoomie.
beam0
beam0's picture
Thanks, I usually look for those first to include the link, guess I forgot, but it looks like it didn’t do so well.
Yes! It was the pink one that caught my eye and decided to post it here, then I found it in black too.
beam0
beam0's picture
Mike C
Mike C's picture
Sorry about that I was wrong. I thought those flaps sticking out on each side under the head was for twist operation with your thumb, but now with closer inspection I see that isn’t the case. It’s just a normal twisty.
robertkoa
Last seen: 1 year 1 month ago
beam0 wrote:
mmalive wrote:
Ooh the model number is XR8. Not even listed on Sam’s website. It does list XR7
XR7 does not run on Li-ion battery, and XR8 still only 400Lm Flat Stare
While searching on line for those I did find something that was VERY exciting…for a minute (before I found out it’s discontinued Angry )
The Tasco XR9r
This apparently was a pretty awesome flashlight from about a year ago! With so many great features I have no idea why it was discontinued.
  • 800 Lumen!
  • Zooming focus
  • Lighted tail switch!
  • Magnetic Tail Cap!
  • Runs on 18650 Li-ion!
  • Built in USB charging
  • Hidden USB port under a knurled stainless ring!
  • USB Powerbank feature!
  • Stainless steel bezel ring
  • Round spot beam instead of square!
I guess these were selling for under $30 at Sams Club, but they were also on Amazon a while back (sold out now):
https://www.amazon.com/Tasco-XR9r-Rechargeable-LED-Flashlight/dp/B01JGN38BE/ref=cm_cr_arp_d_product_top?ie=UTF8
Amazon reviews were all 5 star, one reviewer commented:
“This light isnt being made anymore. I called Tasco (Bushnell) to ask where I could get another and they said it was a one time deal with that Big Box store. No plans to make them again. I don’t understand that but that’s what they said.”
Bummer.
Here’s a youtube video on it: https://www.youtube.com/watch?v=VSusAIf1_1E
After an extensive online search I was only able to find it showing available at one store…..
But when I tried to buy it (just to check) it shows; “Our shopping cart is undergoing maintenance.” LOL
http://www.tacticalsuppliesexpress.com/item/13837047/
Price was a little high anyway: $59.97 Sams Club did show it on their auctions site from a while back, they were probably a great deal in the auction.
Now all the zoomies at Sams are all low output and run on Alka-leaks, nothing nearly as nice as the XR9r was.
Yes…$60 is a little high for this.
For $60 I want a great twist Zoom with 200 to 400 KCD for very long throw and decent flood.
Has BLF done anything like this ?
Or is there something already ,not too large like the Cometa should have been …
cia212
Last seen: 2 weeks 4 days ago
This is at $23.88 including shipping with a tracking number – looks like an okay deal. Has anyone tried it out?
beam0
beam0's picture
Total is $22.84 on the link I posted, is it extra for the tracking?
cia212
Yeah, it’s a little more for tracking info. I don’t have any experience with the store so I thought it was worth it.
robertkoa
From Enogear
  • XP-L on Copper
  • Brass pill
  • Glass lens
  • HAIII
That does look nice .
Can BLF (OR has this been done)
or someone know a way we can get factory modded versions of something like it with a Turbo Mode …?
And choice of LED for either brightness or throw ?
I would pay $40 for this if it had a Turbo Mode that pushes the LED a bit .
Not a Tech or Modder but woukd be cool to have a light like this with 300KCD..
And some would prefer high lumens over high Candela ..
So a C Model ( optimised for High Candela – Throw )
And an L Model ( optimized for Lumens, Color ).
beam0
beam0's picture
robertkoa, I have only seen this particular light from enogear and I’ve not seen them do any customs specials that I’m aware of. I’m still hoping someone has feedback for the Countryman, I’m going to bump it in my next post.
If Enogear did offer a modded version it probably would be more than $40 since that’s only $4 more than stock one costs.
Check out the Jaxman Z1 they offer different LED choices/tints etc. but they usually don’t drive them too hard. Skylumen offers a modded one but it’s VERY expensive: https://skylumen.com/collections/v54-lights/products/zi-seriesvn-need-spec
You could also start a topic or WTB thread and ask on the forum, there’s quite a few members here that offer services/modded lights.
Mtn electronics sells a modded zoomie but when you select it shows “out of stock” so I’m not sure how long for them to build one, you could email them about it. http://www.mtnelectronics.com/index.php?route=product/product&path=80&pr...
beam0
beam0's picture
Bumping this for feedback, anyone have one or know about it?
From Enogear
  • XP-L on Copper
  • Brass pill
  • Glass lens
  • HAIII
DBSS
Last seen: 1 day 18 hours ago
Ok so this is a looong thread so I am just going to ask….really good but budget zoomie that uses AAs?
Any suggestions?
My dad bought that super junk “military grade” chinese junk light and loved the zoomie feature, but dropped it just once and its a pile of pieces. So I wanted to get him a better quality one. ANy help is appreciated.
beam0
beam0's picture
Any suggestions?
Here’s a few:
These two for smaller single AA:
https://www.amazon.com/Coast-HP1-Focusing-Lumen-Flashlight/dp/B00IEMUOWU...
https://www.amazon.com/gp/product/B00TNOSF3I/ref%3Dox_sc_act_title_1?smi...
Although these can run on a regular AA, the’re brighter on a 14500 Li-ion
This one’s a larger size like the that “super junk military grade” but better quality, also runs on 3xAAA like the military grade one.
https://www.aliexpress.com/store/product/Zoom-able-LED-flashlight-Powerful-LED-Flashlight-Cree-500LM-Torcia-High-Powered-Torch-Linternas-18650-Battery/2933049_32796780777.html?spm=2114.12010612.0.0.5bdadf47QHFmf6
It can run on a 18560 Li-ion and would also be brighter (like the military grade one)
beam0
beam0's picture
Any suggestions?
Sounds like you don’t want him to deal with recharging batteries, but honestly regular batteries are more of a PIA, gotta keep buyin them, and they can leak and ruin the light, and in some models have a lower brightness output. You might want to look into one with Li-ion and USB charging. Of course the cost will be higher.
The ones with a magnetic docking base are the easiest to deal with, really convenient, just set it/keep it on the base, no removing batteries or plugging in wires, and never buy batteries again.
Here’s a few lower cost ones with charging dock:
https://www.amazon.com/gp/product/B01CKAUTQ2/ref=ask_ql_qh_dp_hza
http://www2.nebotools.com/RedlineRCMagDock
https://www.homedepot.com/p/iProtec-500-Lumen-Rechargeable-LED-Flashlight-Light-with-Magnetic-Recharging-Dock-6491/300663776?cm_mmc=Shopping|THD|google|D29B+Bath+Vanities&mid=s9JnGEXSz|dc_mtid_8903syd25186_pcrid_41293307497_pkw__pmt__product_300663776_slid_&gclid=CjwKCAiA3JrQBRBtEiwAN7cEGsCP5U0QyZb5aoeLatUDKh8d5m9n2yUcBS2tbbEwMDpntyZSdAw7xxoCPk4QAvD_BwE
beam0
beam0's picture
An interesting zoomie with TIR optic I found today:
WARSUN A7
I wonder if it has the “Donut hole” effect in-between flood and throw positions, like the Fitorch/Litesam E11Z (post #171)
These is a beam shot at mid-zoom and it doesn’t look too bad. It’s only $15.35 on sale for 6 more days.
(click on any photo)
SKV89
Xiaomi FZ101 looks like a pretty nice zoomie. Hopefully it is moddable.
From the picture, I wonder what is the thing underneath the aspheric lense? Is that a wavien collar? If so that would be awesome.
