Test/Review of AW IMR14500 650mAh (Red) 2016
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 56 min ago
DSC_5301
Official specifications:
  • Nominal Voltage: 3.7v
  • Capacity: 650mAh
  • Low Discharge Voltage: 2.50v
  • Maximum Discharge Rate: 5 amps
  • Maximum charge Rate: 1.5 amps
  • Operating Discharge Temp: -10 to 60°C
AW%20IMR14500%20650mAh%20(Red)%202016-info
A new generation high current cell from AW
DSC_5300
The two cells matches fairly well on capacity, but there is a voltage difference.
DSC_5302 DSC_5303
DSC_5304
DSC_5305
AW%20IMR14500%20650mAh%20(Red)%202016-Capacity
AW%20IMR14500%20650mAh%20(Red)%202016-Temp-7.0
AW%20IMR14500%20650mAh%20(Red)%202016-Temp-10.0
As usual with small cells the discharge is too fast to get high temperatures.
AW%20IMR14500%20650mAh%20(Red)%202016-CapacityTimeHours
AW%20IMR14500%20650mAh%20(Red)%202016-Energy
AW%20IMR14500%20650mAh%20(Red)%202016-PowerLoadTime
AW%20IMR14500%20650mAh%20(Red)%202016-TripCurrent
AW%20IMR14500%20650mAh%20(Red)%202016-Charge
Conclusion
I wonder about the difference in voltage between the two batteries, are they different age?
The capacity matches fine enough.
Notes and links
The batteries was supplied by aw-akku.de for review.
Comparison to other LiIon batteries
MG
Last seen: 8 months 1 day ago
Thanks for the review!
djozz
djozz's picture
Last seen: 58 min 3 sec ago
Henk4U2
Henk4U2's picture
Last seen: 4 min 15 sec ago
Thank you for this review. These cells have not the oomph to really fire up a Kronos X5.
But are better than most of the expensive rewraps with the big (flashlight) names on them.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
