in the middle of getting an S2+ triple together. Want to get a FET +1 driver ordered. Kinda up in the air what to buy as far as FW. But if I do order something that requires a turbo timer, How long before I get burned? I am tolerant to heat but do not want to burn this up. I may order a couple FET+1’s, Bistro, Guppy Dual and A6. A6 needs to be set @ order.
So far I have the triple XP-l HI V2 5A2 on Noctigon, Soldered to the copper spacer which is also soldered to the S2+ pillar.
holes for the optic base pins are clear, not full of solder… Optical-dilusion…
Thanks, was hoping to hear 60sec. but figured it was 30.
May just try the Bistro w/ temp regulation on the S2+
And get the A6 no timer for the Astrolux SS to replace the wonk’d (heat intolerant) factory driver in that.
30 sec with FET 1 also works nicely for me in the S2. The S2+ is such a great platform for experimenting with various builds without breaking the bank….
Have several S2+ now but they all are Grey. Really like that color and finish. Finally put a Blue one in the cart because the metal SW I want to try. And my first S2… Grey of course.
Got the FET Fettish pretty bad. Mainly cause they are compact and fit into almost anything.
