Build: Stainless Steel KSH-S12024 Host from Kaidomain
I kinda did this on the cheap.
Parts list
Generic ebay driver 7135*8 soldered 3rd star for H, M, L
Cree XM-L2 U2-3C 4700-5000K LED Emitter on a 16mm copper base Soldered to pill
Stainless Steel LED FlashligKSH-S12024ht Host from Kaidomain
Did some polishing to the host body. Just wanted to smooth the machining but it went a bit further than just smoothing.
Threads look pretty nice and fit well.
Bypassed the spring on the driver and tail. grounded 3rd star for H, M, L
Emitter base soldered to pill.
Front and Back shots.
Not real happy with the design. Parts are stuffed in through the lens retaining ring. No head to remove. Pill has bad thermo conductivity to shell. Pill, reflector and lens are pushed up to lens with a large diameter spring similar to P60. But overall I a m OK with the end result, till it burns out. And only getting 2.4A at the tail. I did not change the stock wires on driver. I did try, but ruined a driver when the + solder pad broke off my first attempted driver. But it’s a Sub $20 stainless build.
I’ve noticed this one before. The pill design is unfortunate though.
I bought one of these i am yet to use it. Its a P60 style light i think?
Well it sure looks fantastic!
Lots of elbow grease!
Not really P60. Reflector and pill are separate. Only P60 similarity is the way the large spring pushes pill, reflector and lens into the lens retainer from the inside. Diameter inside head area is 22mm. Uses 16mm emitter base and 17mm driver.
But I couldn’t find much in a Host that is not Aluminum so I just bought it knowing the design flaws.
Yeah it was done by hand. Wet sand, 220, 400 and just went to 1500 and 2000. After the 2000 the Mothers Mag Aluminum did not do much more. Aluminum would still have visible scratches at 2000. Machine finish was kinda rough too. Could be felt with a fingernail.
If its Aluminum or Stainless… I will polish it.
So you got a bit carried away with the polishing. :slight_smile:
Can I send some parts your way that just need a little touch up with the polishing cloth?
Yeah, I was going to stop after the 400 & red scotchbrite. Kinda wanted to heat color it too.
But it’s shiny like chrome. May change it up later.
I have a Few polished aluminum lights. If I have multiples, one is polished up. A polished UF C8 looks pretty nice.
I gotta ask… Moose in Australia?
Sure, next time you are in the area you can drop them off.
I haven’t seen any Moose in Aus. Plenty of Kangaroos if your interested. :wink:
