for the Convoy Nichia LED I would strongly advise to make a resistor parallel to the LED which eats up 200mA
R=U/I=3.8V/0,2A=19 Ohms
P=U*1=3.8V*0.2A=0.76W
mine on this star is dying, lost about half its output
I used that light more than 20 minutes continously some times and its not good at 700mA
Hate to revive an old thread… but anyone know where i can find a few of these boards for the Nichia 119? I have a couple dozen 119’s that i have a project form, but no boards to put them on.
Yes, the VirEnce VR16S1 board will fit the 119’s fine, but are a bit overkill at 4 dollar per board.
The boards from the OP were not cheap either and are unfortunately sold out, I had 200 of them made and sold most of them and have only a few leftover for own use. And it seems that you need many. I see no source for 119 boards on the internet atm
So sorry, that USD 4/pc is there for unlucky reasons. For anything below 10 watt it’s overkill. Any cheap non DTP board will do just fine. Try Digikey or Mouser.
Any cheap source for get them or similar at 1~2$ Piece, better if free shipping? need some
I’m behind in sending out stuff at the moment, and next week I’m away for work, so it will be next weekend before I will send the next boards.
link to djozz tests
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale]
Drivers: overview of sizes and types
DD+AMC based drivers Anduril or Bistro OTSM 12-24mm, S42, 24-30mm L6, Q8, MF01(S), MT03, TN42
Anduril or Bistro 8A buck driver for 20-30mm, MF01/02/04, TN40/42, Lumintop GT, MT09R
UVC and UVC+UVA drivers
programming key
Remote switch tail DD board with FET
Aux boards:
Emisar D1, D1S, D4, D4S, D18, Lumintop FW3A, Fireflies ROT66, Astrolux MF01, Tail boards like S2+
If you still have some to sell i will take 3 Boards.
Yes I do, 3 boards is fine, and thanks for the PM. I will reply this weekend because I’m not at home atm.
In general, I have so little boards leftover that at this point I stop the sale. Will update the OP and title.
link to djozz tests
These would be a nice addition to Clemenece’s new online shop I think.
Project Excalibur - Next Generation LED Thrower (UPDATE 2018-01-15: 1.7Mcd)
Portable Thrower Comparison
Clemence has a version in the pipeline if I’m correct that should perform better than this board.
link to djozz tests
I think the clemence PCB’s will work with the 119. I would contact him.
Texas Avenger Driver Series
My LED Test series - XP-L2 V5 - Nichia 219C 90+ CRI - Latticebright "XM-L" - XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5 - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
link to djozz tests
- Clemence
www.virence.com
Physical and thermal properties of solder alloy - Shooting Beamshots With HDR - Nichia E21A Tint Shots
Its Okay To Be Smart - SmarterEveryDay - Deep Look - Veritasium - Tech Ingredients
http://led-mounting-bases.com/en/led-mcpcb/359-mcpcb-star-pour-1-led-nic...
http://led-mounting-bases.com/en/led-mcpcb/278-star-mcpcb-for-3-leds-nic...
You should buy S2+ UV Nichia 276A very early, I changed the aluminum plate to copper plate for several years.
