Budget 2 x 26650 for modding (not zoomie) ?
10 posts / 0 new
bella-headlight
Last seen: 4 months 1 day ago
As above.
I know that I can get the L6 in host form but any suggestions for any other cheap 2 × 26650 lights to mod or hosts ?
Ian
will34
will34's picture
Last seen: 4 hours 17 min ago
Yezl Y3
bella-headlight
Thanks I will check it out Thumbs Up
Ian
will34
will34's picture
The driver even supports 6v emitters, you could double the output by just dropping a XHP50 in there. Mine has a MT-G2 making about 1,800lm. Not the best build quality or anodizing but cheap enough to play with.
Flashy Mike
Flashy Mike's picture
Have you thought about using 2× 26350 cells in single 26650 hosts?
bella-headlight
Not really as it would mean me specifically buying another sized cell, where as I have plenty of 26650 cells.
Ian
bella-headlight
The only place that I can find the Yetzl Y3 is Fasttech for $36 (with extension tube), is that about right ?
For a few dollars more ($40) I can buy an L6 host, which I would imagine is a better build quality.
Then again for $65 I can buy a complete L6 & with a code I can probably get it for $60 ?
No wonder the “S70” clone at $19 didn“t happen Facepalm
Ian
Flashy Mike
Even cheaper than 50$ with a code from M4D M4X:
http://budgetlightforum.com/node/37267
bella-headlight
That is very cheap for such a great light.
I wonder if M4D M4X could do a code for the clear L6 ?
Ian
Xandre
Xandre's picture
Last seen: 11 hours 11 min ago
The Convoy L2 is a great host,also.
Regards Xandre
