[…]However, there are times I want the light very close to my line of sight: it’s a great way to spot animals (from eye shine), using low output. Creepy, but effective. Okay, sometimes too creepy.
It also all but eliminates shadows from your field of view.
All kidding aside, I hope such a device is subject to legal regulation. I wouldn’t want such a thing, and the thought that it could be used by terrorists gives me the shivers.
I hope not. There’re too many things already “regulated” by nanny-state governments. And you can find a nice powerful laser-diode in any blu-ray recorder.
I keep telling people who want to ban guns that when Terrorists™ start using bombs or even gasoline (anyone skeptical, look up the Happy Land Disco fire: ~80 lives snuffed out with a few gallons of gasoline) to do their nefarious deeds, they’ll be wishing that they’d go back to using guns. And all it takes is one idiot with keys to a truck to go plow through a crowd…
All that might do is to keep some idiot kid from shining a laser at a passing plane… oh, wait, they do that despite it being a federal crime with some serious jailtime attached.
I mean, c’mon, there’s been talk about banning or at least “regulating” 3D printers because of what someone might create. Or requiring any designs to go through some central clearinghouse for inspection first before allowing the object to be printed. (I can imagine the backlog on that… want to build a bike-light bracket, submit your design now, come back in 2021 when it gets approved.)
Too often “government” is the problem, so let’s not automatically look to it for “solutions”.
Burns holes in wood, for one thing. Causes INSTANT blindness even with the briefest reflection. Lights up its path in air just from dust and/or humidity.
Oh, but it’ll light up something miles downstream… or on the moon.
Seriously, that kind of laser is used to etch wood, and isn’t a toy by any means.
Lightbringer, perhaps this one is a “bit” more than 900mW…
As far as the tint questions, remember that in the same power binning a warmer tint makes much less lumens than a cool tint, so it would only be feasible that you would get more reflection from humidity from the brighter light…
Are you sure about that? I thought the binning was based on lumen output, not EM energy output.
As interesting as philosophy of governance is, it’s one of those topics which tends to get out of hand pretty easily.
Instead of responding with data on the effects of various governance strategies (data on this sort of thing tends to be counterproductive when humans are involved), I’m hoping we can stick to less fiery topics… like actually starting fires.
Dale, that is the laser you made for destroying wasp nests from a safe distance, no?
Can anyone tell me how long I can run the C8 at 100% in let’s say 25-30 degrees C ambient temps until the heat buildup is too much. There is a runtime chart floating around which shows a max temp of 66 at about 40 minutes in with an ambient temp of 25(?), is 66 too high?
I can’t say if that’s as hot as one gets, or if those numbers are accurate, but I can say that 66c is not “too high” for the electronics. That heat won’t hurt your light. It may hurt your hand though. How tough are you?
Bottom line — if you can stand to hold it, its not too hot.
If you’re holding your light, it doesn’t get that hot. Your hand draws a lot of heat from the light. I think those run-time temperature graphs are done with the light tail-standing.
Thanks! A grey C8 is calling my name… I see people get around 80,000 cd out of them in stock form – that would make for some impressive pocket thrower. My current go-to thrower is Thorfire VG-10, and that barely clocks in at around 12,000 cd.
You’ll be satisfied for sure. I have a C8 with a domed XM-L2 and an OP reflector, and it’s still easily my longest-reaching torch despite the throw-unfriendly setup. It laughs in the face of a 100m distance!
Yes, I have a stock C8 silver, and it’s a great pocket thrower. Jacket pocket, perhaps. Easily my go-to for an outdoor thrower, since it’s so light. I have the 7A and 3A, and I prefer the 7A tint. Though I might get a 4C, since it’s probably a good compromise.
If all you have now is 12k cd, you’ll notice a huge difference. But bring a flooded as your main light, because a C8 is bad up close.
Indeed. A C8 is far from a good pick for indoors even on its lowest non-moonlight mode.
Unless you’re tail-standing it. Throwers make great lights for tail-standing, since you don’t get much spill to catch your eyes when sitting near the flashlight. And, the C8 seems to have an AR coating, so you don’t get glare off the lens either.
I like the 7A tint on the C8 for indoor tail-standing. Nice incandescent-like light.
True. Ceiling bounce with them is a dream, especially in 7A tint. I have an M1 in that and love it to death – when I’m in bed, I set it to 0.1% or 1% depending on what I want to do, tailstand it on the nightstand then put a Thrunite T10 diffuser on top of the lens. Best lamp ever.
Well, I have a Haikelite MT02 that measures around 60k cd, but it’s just too heavy to carry around on my long nightly walks. It’s a good exercise though.
Yes sir. I’ve got an OTR M3 clipped to my cap visor, and this one’s pretty floody. I just need something throwy and not too heavy in my jacket pocket to occasionally light up something further in the distance, which is what I’m using the VG-10 for, currently.
Hello long time to read the thread returned to ask something if someone has the answer. Is that pouch good for the flashlight? http://www.military1st.eu/ma48-008-condor-flashlight-pouch-multicam.html
as i can read the dimension of the flashlight is:
Diameter of head : 44.5mm
Length : 143mm
Diameter of body : 25.6mm
and the pouch Dimensions: 5.3”×2”×0.8” (13.5×5×2cm)
Thank you in advance.
Length : 143mm
I have the second one and has a very cheap feeling, i have the first one for convoy s2 it’s very good quality and sturdy built. thank you for the info.
Anyone here done some mod with this C8?
I put XHP50 with Noctigon, but the result, got some ring spot in the center.
Put the reflector several times, thinking it might loose, but seems not.
Any suggestion?
+1 for your answer Lightbringer!
Sorry, no brighter moon.
Here are the numbers explained from xkcd:
https://what-if.xkcd.com/13/
He made a joke. Not serious.
Click this to go to signature links. I'm still around, just not reading many new threads.
But, but, they said they were here to help!?
I can’t agree with you more Lightbringer.
Lazy-R-us
I know of at least one patented (I suppose) “laser turret” designed to eliminate mosquitos.
Also, hi-power laser + hoover = dead insect nest. Also works for those nasty spider webs inside the house.
66°C is not at all a problem, especially with XML LEDs,
lights with XPL footprint and DD should have a DTP star, or the emitter itself gets too hot
[Reviews] Miboxer C4-12, C2-4k+6k, C2, C4 / Astrolux K1, MF01, MF02, S42, K01, TI3A / BLF Q8 / Kalrus G35, XT11GT / Nitefox UT20 / Niwalker BK-FA30S / Sofirn SF36, SP35 / Imalent DM21TW / Wuben I333 / Ravemen PR1200 / CL06 lantern / Xanes headlamp
[Mods] Skilhunt H03 short / Klarus XT11GT, XT12GTS / Zebralight SC50+ / Imalent DM21TW / colorful anodisation
[Sale]
Drivers: overview of sizes and types
DD+AMC based drivers Anduril or Bistro OTSM 12-24mm, S42, 24-30mm L6, Q8, MF01(S), MT03, TN42
Anduril or Bistro 8A buck driver for 20-30mm, MF01/02/04, TN40/42, Lumintop GT, MT09R
UVC and UVC+UVA drivers
programming key
Remote switch tail DD board with FET
Aux boards:
Emisar D1, D1S, D4, D4S, D18, Lumintop FW3A, Fireflies ROT66, Astrolux MF01, Tail boards like S2+
Sorry if this was already answered, but does Simon make this new C8 xpl hi available in colors other than silver?
Yes. Message him on AE to request it.
3tronics does some beautiful powder coatings too.
I put an LD-25 driver in my black C8 and i really like it.
https://www.aliexpress.com/store/product/Free-shipping-LD25-Flashlight-c...
It’s a 3 mode (plus hidden strobe) 3 Amperes regulated FET driver. No PWM.
Length : 143mm
Wow, fascinating, and looks build quality
Can’t tell about that, but you have some specific holsters for C8 from Convoy Store
https://www.aliexpress.com/store/product/New-holster-for-C8-high-quality...
https://www.aliexpress.com/store/product/Flashlight-holster-175-61mm-sui...
MY REVIEWS THREAD /// My Flashlight Collection ///
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2
Any suggestion?
