Light Color - Tutorial
This is my attempt at proper and simple explanation of the light color subject. The confusion I have seen in this forum regarding light color is so widespread and so horrendous, that I simply couldn’t take it anymore.
Usually such explanations start with “color temperature” represented by values like 5000K, 3500K, etc. I happen to think this fact alone is the main reason for massive amount of confusion which exists in this area. So I am going to ask you to forget everything you think you know about “color temperature”. Forget the term itself. In fact, just forget everything you think you know about light color. Let’s start from the beginning.
The visible light consists of electro-magnetic waves with different wavelengths, each wavelength representing a different color:
Chart 1. Visible spectrum. (*)
If we take a theoretical light source which emits equal amount of energy at each wavelength in the visible spectrum, this is how it’s energy distribution chart would look like:
Chart 2. Illuminant E - equal-energy radiator.
But real life light sources around us do not emit equal amount of energy at each wavelength, they emit different amount of energy at different wavelengths, in other words - different amount of each color. So spectral energy distribution charts for real life light sources are very different from the chart above (called equal-energy radiator). Here, for example, is the chart for a typical noon sunlight:
Chart 3. Noon sunlight.
Although color characteristics of noon sunlight are not perfectly even, they are close enough – all colors are well represented. Let’s add a graph for typical sunset light:
Chart 4. Sunset.
As you can see, color characteristics of sunset light are greatly uneven. There is little green and even less blue. Now let’s add a chart for typical incandescent bulb:
Chart 5. Incandescent bulb.
Notice something? Incandescent bulb has light color properties similar to sunset light. Not exactly the same, but close enough. Now let’s add another theoretical light source – an incandescent bulb whose wire filament is made of non-melting metal heated up to higher temperature than regular incandescent bulb:
Chart 6. Non-melting high temp. incandescent bulb.
This one is similar to noon sunlight! If only we had non-melting metal, we could have this great light source! But alas, we don’t have non-melting metal. So we have to get by with LEDs. Let’s see how a typical “white” LED spectral energy distribution looks like:
Chart 7. LED.
What the hell is this?! Is this a joke?! This looks nothing like a proper light source! A lot of colors grossly underrepresented, some are grossly overrepresented, anyway you look at it – this is a mess! But LED manufactures have been straggling to produce more color accurate emitters, here is a graph for typical “warm high CRI” LED:
Chart 8. “warm high CRI” LED.
This is better. It somewhat accurately approximates sunset light, but remember – sunset light itself does not represent many colors sufficiently. Now the last graph for today, an attempt by LED manufacturers to approximate noon sunlight – typical “neutral high CRI” LED:
Chart 9. “neutral high CRI” LED.
Considering what we’ve been through, this is much better! Still has some way to go, but at least most colors are there, more or less.
Now that you understand how things actually work, we can look at industry standard parameters, like color temperature and CRI, which (in many cases very inaccurately) are used to describe color rendering properties of light sources.
I hope you understand by now, to accurately describe color rendering properties of a light source – you need a graph. The is no way to describe that crazy wave of irregular light sources like LEDs using a single magic number. But that doesn’t stop people from trying…
Correlated color temperature (CCT) tells us which of the following graphs the graph of our light source most closely resembles, while CRI tells us how closely it resembles the corresponding graph:
This leads us to a couple of amazing discoveries:
  1. Two light sources with EXACTLY the same CCT and CRI parameters could have WASTLY different color rendering properties. Their graphs could be NOTHING ALIKE, but still average out to EXACTLY the same CCT and CRI.
  2. When it comes to color rendering capabilities, 2000K CRI 100 and even 3000K CRI 100 – are pretty bad lights, they don’t cover a lot of colors properly. While 5000K CRI 100 and even 6000K CRI 100 are great lights, they cover all the colors very well.
I hope you found this explanation helpful. Questions, suggestions and donations in the form of flashlights are most welcome.
(*) All charts in this tutorial are gross approximations. If someone can create better charts for this tutorial (gnuplot?), that would be great.
Can you reduce the image size by about half? All too big for my 17” screen, likely worse for those using phones to browse.
If you check here, you’ll find previous attempts to explain this stuff, charts and all
https://www.google.com/search?q=site%3Abudgetlightforum.com+"color+temperature"+spectrum+spectra
click “images” and limit the time span on the results
example:
Done.
Hank, it’s screen resolution, not size, which makes the images appear too large. My phone and computer monitor both have a resolution of 2560x1440 pixels. These images look great on both of my devices.
If you have two LEDs with the same CCT (and tint), but with different CRI, would they look the same shined on a white wall?
Images look good now.
Very informative . I get annoyed (or more accurately, I chuckle) when someone says or implies that a warm tint = High CRI. All it means to me is a color. Even that may not be fundamentally correct, but the CCT values usually give a good idea of how a tint will be perceived. That’s just it though, a lot of people are merely looking for a tint (yes, tint/color/hue) that is pleasant to their eyes in use. They aren’t primarily concerned with the CRI or CCT or whatever term these wonderful graphs illustrate. I n the most recent light I built I first used a 4500k 90cri XP-G3. Normally I like tints that fall in the 4500k spectrum, but this one was just kinf of ugly. So I swapped it for a 70cri 4200k XP-L HI. Lower “CRI”, and who knows what its graph looks like, but it is simply more pleasant to my eyes, so that’s what I picked.
It’s even worse than that. Warm CCT with high CRI (even 100 CRI) - is still a bad light, when it comes to color rendering properties.
So maybe you should better define the term CRI. Does it not stand for color-rendering index?
Yes, but in practice only the hotspot will look the same. Cree is famous for the purplish/bluish spill and sometimes strong color artifacts around the hotspot (corona).
Thank you for the graphic charts and commentary.
The world view we perceive is just one view point.
Things we understand today such as Heliocentrism was literally a position that could have you imprisoned before it became understood. Even a better understanding of perceived reality can be further changed with better information. :slight_smile:
Be it as you like; I really love my bedroom E14 40W incandescent light.
Cheers ^:)
Me too. Light which closely resembles sunset, is exactly what I want before I go to sleep. This is a subject for another article - how different lights affect our mood. But the point still stands - “warm” CCT even at CRI 100 are quite bad as far as color rendering is concerned.
Yup. I’ve been keeping a collection of tidbits on that since 2007, courtesy of a very tolerant blogger, here:
http://psychcentral.com/blog/archives/2007/03/12/light-and-dark/
A classical black body emitter, would it not emit yellows and oranges (“warm”) when it is relatively cold? So don’t we actually mean cold when we say warm white? :stuck_out_tongue:
Good explanation, but there’s a bit more nuance going on on the human perception side.
Perhaps ‘colour rendering’ is not the correct term for explaining that a 3000K light source is ‘bad’. Colour rendering is how well a light source reproduces the colours compared to how certain (natural) reference light sources do that, while you refer to an absolute quality showing how well all possible colours can be distuinguished. (btw,I do like that too in a light source :slight_smile: )
There’s a reason for coupling CRI to colour temperature, our perception of what is good quality light is not just based on distuinguishing as many colours as possible, it is a biological thing too, we are used to all sorts of incandescent light sources (inluding the sun) and getting close to those gives the most appreciation.
Btw, funny enough, sources with very worrying looking spectra can do very well in both our perception and CRI, i.e. here’s a wavelength chart of a certain 5000K 98CRI CFL tube:
Also, the typical peaks and dips at certain wavelengths that leds show are not picked up very well by humans. In fact the perception system in our eyes is really primitive (we can not ‘see’ wavelengths), but luckily our brain does a wonderful thing processing the limited data and make the most of it. But the primitive perception makes that the brain can be tricked easily!
+1
Some even use complete isolation as a positive way to understand.
“In the province of the mind, what one believes to be true, is true or becomes true, within certain limits. to be found experientially and experimentally. These limits are further beliefs to be transcended. In the mind, there are no limits… In the province of connected minds, what the network believes to be true, either is true or becomes true within certain limits to be found experientially and experimentally. These limits are further beliefs to be transcended. In the network’s mind there are no limits.”
It does, unfortunately. But in reality it describes how close a particular light source is to the closest black body radiation curve. Which may not be the curve with particularly good color rendering capability.
That’s not true. A light source that is farther away from the bbrl can be higher CRI than a light that is right on top of it. Cree’s MT-G2 seem to be very near the radiator line but still aren’t very high CRI. Some Nichias are very strongly rosy and below the line and still have a CRI of over 94.
If you meant that in forum speak, people mean that a neutral tint equals high CRI, then that’s understandable. As you said, one shouldn’t mix up tint, CCT and CRI.
By “black body radiation curve” I think he meant the spectrum, not the black body radiation line on a chromaticity chart.
Well that makes a whole lot of more sense.
