under $20 USD GM1020 Digital Light Meter with USB data logging
47 posts / 0 new
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 29 min ago
Hey folks i found this item it seems legit. The quality is unknown but its cheap and it has data USB logging. Apparently it can use the USB as a power source while data logging sounds like a handy feature.
Here is the deal i know nothing about these light meters so maybe some one can chime in?
http://www.benetechco.com/en/products/digital-lux-meter-gm1020.html
This Ebay dealer has it for $29 Aussie dollars so its not to bad.
http://www.ebay.com.au/itm/High-Quailty-GM1020-Digital-Light-Meter-LCD-Lux-Luminometer-Photometer-Tester-/381460507949
Digital Lux Meter GM1020
*Measurable Objects: Illuminance and temperature ,illuminance
difference,naximum and minimum.
Illuminance and temperature,imtegrating illuminance and
integrating time,and average integrating illuminance
*Photoelectric element: Silicon diode
*Thermal Probe: NTC Thermistor
*Illuminance Measuring Range:
Total measuring range: 0~200000Lux
*Lux into four ranges:
x1 0~199.9Lux
x10 200~1999.9Lux
x100 2000~19999.9Lux
x1000 20000~199999.9Lux
*Temperature measuring range: 0~40℃
*Temperature accuracy:±1.0℃
*Illuminance accuracy:
±3%rdg(below 10000Lux) ±4%rdg(above 10000Lux)
Units of illuminance and temperature:
Four combinations of units are available.lux/℃ lux/℉ FC/℃ FC/℉
LCD Display up date frequency:Twice per second
Operating Temperature/humidity:0~40℃ 10~90%RH
Storage temperature/humidity:-20~50℃ 10~90%RH
Power supply: Two AAA batteries
Battery life:10 hours(continuous operation with a USB connection)
Auto shutdown: You can set an auto shutdown timer through LuxLAB
I think the supplied software would be horrible and hard to use.
Edited by: everydaysurvivalgear on 09/27/2016 - 06:14
Liber8
Last seen: 10 months 1 week ago
Agreed about the software. It also says on the disc that it’s for win xp/vista. Not sure how well it would run on newer OS. Seems like a neat idea in theory in though if you wanted to do some run time tests without having to babysit it.
You can run some apps as an older version of windows if that helps. When you right click on a program with windows 8 and up it has a compatibility tab. Even if it just powers from the USB but saves the data the machine it helps i guess.
Bc412
Last seen: 1 year 6 days ago
I bought one… I’ll report once I get it. Hopefully not a $20 paperweight.
Got mine of us eBay
maukka
maukka's picture
Last seen: 10 months 5 days ago
The GM1020 sample I have seems to be quite accurate with LEDs. At least compared to my spectrophotometer. But as always with these Chinese wonders YMMV.
Texlite
Last seen: 4 years 4 months ago
Nice find EDSG!
I’ve got an Extech that is data logging but can’t run the software because I need the OSX version, not Windows.
And on that note, if the bundled software turns out to be junk you might try running the Extech software and see if it would work with this meter. I have absolutely no idea if the protocol is the same, but might be worth a shot. The software and cable are around $70 so I wouldn’t suggest buying it, but you might have a fellow flashlight enthusiast in the states that would be willing to send you a copy of the Extech software to try Wink
-Michael
Bc412
Got mine today. Just gotta figure out how to run this bad boy. Instructions are sparse!
Bc412
Update.
Installed very easy. Had to update driver for Windows 10, but was super easy to do.
There is a hefty .PDF instruction book on the CD.
Its 2am so I only played for a few min.
Looks like you can export data to .xls for making charts. You can record to device, or record live on your computer via USB.
Software is very rudimentary. It shows a graph, but you can’t export or modify it.
I’m still messing with it, but I will update you more tomorrow. I need to log some data and see how it looks in spreadsheet.
My initial impression is that this is going to be a very good entry level meter. The software is pretty much just a way to record live or import the data to your computer
Cool mate thanks I will buy one soon.
freeme
freeme's picture
Last seen: 3 hours 10 min ago
Bought an UNI-T UT382 recently and their software doesn't support newer Windows.yell I'm thinking of giving this meter a chance.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
maukka
maukka's picture
Just a heads up that I haven’t been able to get this meter to work on any of my Windows 10 machines. Even with the newer drivers downloaded from Profilic.
freeme
freeme's picture
I just made my order... Facepalm
maukka wrote:
Just a heads up that I haven't been able to get this meter to work on any of my Windows 10 machines. Even with the newer drivers downloaded from Profilic.
I would be expecting the drivers to be bad like when i programmed my Baofeng radios so many driver issues
Bc412
Is the usb to serial device showing up in your devices?
My first install attempt It didn’t work and I went into my devices and the usb to serial wasn’t there.
Used the driver app to “uninstall completely” then tried again and it worked. Had to restart windows for the software to pick it up and connect.
Also it looks like the last driver update was 2 months ago
maukka
maukka's picture
Here’s what mine does.
Tried everything with the newest driver and having the meter on when plugging in etc.
Bc412
That’s exactly what mine did.
Use the driver again. Do the complete uninstall. Restart comp. Install driver again. Then restart comp again before you try.
Very important to restart comp before and aftrr
Liber8
Where did you d/l the latest drivers from
maukka
maukka's picture
http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41
No amount of uninstalling or restarting helps mine.
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 9 hours ago
Nice find! I will follow this thread and order one if it will have positive feedback from you guys.
Texlite
Has anyone tried using the Python script linked in the CPF thread?
-Michael
Bc412
Ok. Update.
The driver software is definitely a prob. I’ve had to reinstall it a few times.
What seems to work is leaving the meter plugged into usb but power off when you install. It looks like the auto play when you connect it has the ability to corrupt the driver.
Either way. Its a huge pain! Fyi.
I ran a test run on the lumintop tool and exported to xls. The light curve was the same shape as my previous method and other reviews so the meter is somewhat accurate.
Problem is it only exports lux data, and since the sampling rate is 2x per second you can’t make a chart with a push of a button.
Also seems like the first few recorded lux values are always wrong.
So the driver is definitely buggy, and your data set is going to be in 1/2 seconds.
Which can be a huge pain if your doing a 7 hour run. Which can mean like 40,000 data points.
Also finding runtime means doing some light math
tek-0
Last seen: 8 months 3 weeks ago
I got one of these too.. and there’s two problems:
- After recording 7200 values (about an hour) the supplied pc software just deletes all recorded data and starts over! I didn’t find any options to change this so I guess it’s a bug in the software. So I just use the device memory.
- Quite a lot of noise in the signal. Big noise over 20k lux, and smaller noise over 2000 lux.
Here is graph I recorded from my Olight S20, just moving it further and closer to my diy integrating sphere.
!imagebam.com!
Here’s a closeup of the moment when the light intensity goes below 2000 lux (=41 lumens in my sphere)
!imagebam.com!
The above kind of transition would be hard to average out. If somebody knows how to get rid of this “noise”, I’m listening.
Here’s a finalized runtime graph, from google spreadsheet. you can see the bigger noise component, which disappears below 20 000 lux.
!imagebam.com!
Bc412
How long does your device memory last? Mine shows full after 15 minutes. It only stores 1900 readings in the device for me
I also have alot of noise in my readings.
Pretty close to giving up on this. Its so buggy and the driver keeps corrupting and having to reinstall.
Has one one tried to make this work with different drivers? Or a different program what about a name brand lux meter that uses the same internals that may work?
tek-0
You can only set the interval in the supplied Luxlab software. In setup, there’s “auto store period x seconds” where you input the desired interval. Then click upload.
Nisei
This thing doesn’t use a hardware level driver because it has a serial interface. It uses a prolific USB to serial chip which needs a driver. There are many different chips so perhaps you could try a different one. I came across this page, perhaps there’s something that may be of any use.
http://www.serialgear.com/usb-serial-adapter-drivers-windows-mac-linux.cfm
Bc412
Any trick to getting it to upload. I click and nothing happens. The interval doesn’t change.
Bc412
So I went on the link Nisei posted. I tried the 2009 “get all drivers link” and it fixed my driver problem. It connects flawlessly now.
Budda
Budda's picture
I got mine without any software.
I looked for it on the internet without any luck. I contacted benetech and I’m waiting their answer.
Any chance any of you could share his copy? Thanks.
Here are all my reviews on BLF
maukka
maukka's picture
Budda wrote:
I got mine without any software. I looked for it on the internet without any luck. I contacted benetech and I’m waiting their answer. Any chance any of you could share his copy? Thanks.
Sent you a PM.
freeme
freeme's picture
Driver does't work with my Windows 8. Luckily, I have an old notebook with Windows 7 loaded. Installation was pretty straightforward. Somehow I am able to measure beyond 1900 mark. Will monitor if it will auto reset at one hour mark like what tek-0 has mentioned.
Up till this point, I would not recommend GM1020 to the rest yet.
