In a predicament, have to sell some lights* ALL SOLD THANK YOU! *
Hey flashaholic fambly!
I’ve gotten myself in a bit of a predicament (Volkswagen helped me!) and will have to sell off some flashlights from my collection. I’m asking here about interest, as in what type of light might be wanted most and whether or not to include the cells inside. As y’all know, I have a thing for modding. I have a thing for pushing the limits, reducing restrictions to get the most from a light. That said, the vast majority of my lights are tweaked in this fashion. I tend to build em, test em, and put em on the shelf where they collect dust. lol There are a few I use on a semi-regular basis and those I’ll be keeping, but I should be able to sort out some 100 lights to sell in order to keep my wife from moidarizing me over our recent car purchase. (yes, I jumped the gun. we will be participating in the VW buy-back program but that might drag out further than anticipated and I’ve already bought a new Toyota Camry, so we have double the car payments and double insurance in the interim! Yikes!)
Virtually all of the lights I will list are in like new condition, built and tested then shelved. On occasion, a name brand light is glued and may take extreme measures to break into which might result in a bit of a scratch or chuck mark from my lathe. (I have found that mounting the light in the big 5” jaws with an aluminum sleeve between the light and the steel works wondrously, nothing can stand up to it, even Red Loctite)
My plan is to essentially try to recover actual costs of these lights, not make a profit on them. As such, pricing will reflect the cost of the light and cost of the materials to modify it. (mostly, probably less in 99% of these… meaning I’m more willing to take a bit of a hit just to recover some of the monies spent, so I can keep my car!)
If y’all show me here that this will go over well, I’ll get busy and photograph, test, and list the lights I will be tearing from their place in my soul. :stuck_out_tongue:
Thanks for your help, really appreciate your input and the kindness shown on this forum.
Dale
Please PM me with your serious “I’ll take it” and for PayPal and shiping information. Thank you very much for your interest.
Ok, I have 25 lights set out, pictures taken, lumens on the highest setting measured in the light box. Lumens is with the cell that’s in it, at rest, some for longer periods than others. So none of these are fresh topped off cells output numbers, with fresh charged cells the numbers will be higher in most cases.
1. Sold $30 DQG Tiny (26650) Triple XP-G2 in WW, 1231.65 lumens
2. Sold - $25 Fenix E41 (4*AA) XM-L2 with a large defined hot spot, 489.9 lumens
3. Sold $30 Jet Beam RRT21 (18650) XM-L2 NW with a tail switch and a rotary dial, 500.25 lumens
4. Sold $40 MaxToch (2*18650) MT-G2 sliced, 2577 lumens
5. Sold -$45 Sunwayman T40CS (2*18650) LD-2 driver with XP-L emitter on 32mm Noctigon, 1248.9 lumens
6. Sold $45 Fenix TK22 (18650) LD-2 driver with XP-L V6 3D emitter, 817.65 lumens Military Grey (a clear anodized satin finish, sweet light)
7. Sold $50 ArmyTek Barracuda (2*18650) XP-L HI with hand polished reflector, very tight hot spot, 959.1 lumens and 198Kcd for 890M throw
8. Sold $40 Eagle Eye X6 (18650) XM-L2 U4 1C Triple with original Qlite converted large FET driver, 4 modes, 2677.2 lumens
9. Sold $25 Lucky Sun D80 BLF chopped (18350) XP-L HI emitter with A6 FET+1 driver, 855.6 lumens on a fairly low rested cell
10. Sold $45 MecArmy PT10 (10440) XP-G2 Triple, stock, 969.9 lumens
11. Sold $15 Romisen RC29 (14500) XP-G2 with Qlite driver and added chips, 514.05 lumens (no longer a zoomie, has 15mm reflector)
12. Sold $50 Olight M3XS UT (2*18500) XM-L2 de-domed, 1269.6 lumens (factory UI, bumped)
13. Sold $45 Lixada XML 3800 (1*18650 with a dummy) XM-L2 Triple, FET+1 driver, large copper heatsink (you can feel the weight of it!), 3356.85 lumens
14. Sold $35 Solarforce M7 (18650) XM-L2 NW Dual switch with ramping firmware on FET driver, 1187 lumens
15. Sold Olight M3X Triton (2*18650) MT-G2 at 3040 lumens
16. Sold $70 Fenix TK75 (4*18650) XM-L2 Triple, domed, 4309 lumens
17. Sold -$30 MiniMag (14500), chopped (14500) XP-G2 triple, 711 lumens with fairly low cell
18. Sold $30 Eagle Eye A6 shorty, (18350) XP-G2 triple, 1263 lumens
19. Sold $20 Xeno E03 (14500, AA) XP-G2, 421 lumens on 14500, 97 lumens on rested NiMH Eneloop
20. Sold $30 Eagle Eye X6 (18650) LD-2 driver with XP-L HI emitter, 1059 lumens
21. Sold $40 EagTac TX25C2 (18650) XP-L V6 3D at 593.4 lumens
22. Sold $50 Courui D01 (3*18650) SBT-70 emitter in high CRI daylight white at 1045 lumens
23. Sold $60 Jax X6 Hunter (2*26650) MT-G2 with reflector fitted to the large emitter, surprisingly tight hotspot at closer ranges, 4388.4 lumens
24. Sold $60 Convoy L6 (2*26650) XP-G2 S2 0D de-domed with MTN Buck driver at 5.5A, side e-switch does not function with this driver, 1142 lumens and 439Kcd
25. Sold $70 Trustfire XM-L 12 emitter big boy, (6*18650) 12 of the XP-E2 Torch emitters on Noctigons, 2998.05 lumens (a surprisingly tight hot spot even for a single emitter light, crazy from 12 emitters!)
Dale… sounds interesting. I need a real thower! Something more than a good C8 (have plenty) and my build D01.
I’m definitely interested
Too bad shipping to Europe is so expensive from the US…would possibly be interested in buying a modded hot rod since I’m not able to mod myself…
K.
Triples and quads…
I will probably sell 2 Olight Javelot series, an M3XS with side switch and an M3 Triton with MT-G2. Probably the Fenix TK75 as well, it’s making some 4200 lumens with domes on the XM-L2’s and has a nice throw, especially for a triple. I don’t have a lot of larger lights, leaning towards single 18650 or even smaller. So the majority will be pocketable lights with large output. (I tend to like the surprise factor, seeing the look on someone’s face when they see a small light make big light output)
All of my ~170 lights have cells in them, standing by waiting to be used. I really don’t need to keep the cells and have 100 plus extra cells around, these cells have been used to test the lights but in virtually every case, not used since then with a rare exception to a short walk.
Probably the longest throw of a light I’ll sell is the L6 with de-domed XP-G2 and Buck driver from Richard, at some 439Kcd. With the big TN42 a keeper, I don’t really need anything else in the throw dept. (I’ll probably keep my modified M2X-UT Javelot, cause it’s so small)
The plan is to put all my lights on the table, sort out what I just can’t part with, then go from there.
I do have a couple of XHP-35 lights I built, and the big BTU Shocker with XHP-70’s and large TIR’s glued into the reflector cups to smooth the beam, that one makes some 12-14,000 lumens, depending on cells/carrier used. :wink:
Edit: I think I’ll also sell the behemoth Nitecore TM36 Lite with it’s SBT-70. Even at “steal prices” it won’t exactly be cheap as they’re very proud of these.
I would be interested in any of your smaller lights, can’t think of any one specific I am looking for though… Will be waiting to see a list.
Interested in pocket burners. :slight_smile:
Was going to get in on the S41S but those are… Yikes.
I would be interested in the L6
Interested in the L6 as well!
I see I need to go ahead and start making a list with pics and specs…
interest in all things NOT Aluminum. :smiley:
I am lucky enough to currently own one Dale light, and I’ve been needing (wanting) another for a while now. I am definitely interested in bright (which is a given) single 18650 lights, throwy, triples, quads, even single emitter. Whatever I can afford I’d get, maybe a few of them.
I don’t have much cash laying around, but I’ll be watching closely for entertainment value. This could be a feeding frenzy :smiley:
Perfect, my in-laws just asked me to look for a bright light… that really doesn’t give me much info.
A hot-rodded Convoy S series triple or quad .
Just landed a new job and waiting to spend some money.
I might be interested in small e-switch lights. Ideal would be modded or not, if modded, maybe not modded up with latest/greatest - I could always to that myself.. It might help you out. I'll wait and see what you got.
Interested!! Triples and quads!!
