Test/review of Charger LiitoKala Lii-202
39 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 4 days ago
DSC_6371
DSC_6374 DSC_6373
LiitoKala got known for a analyzing charger, but has since made many other chargers. This is a usb charger that can charge a wide selection of batteries and it can also work as a power bank.
DSC_6356
It arrived in a plastic bag
DSC_6369
But it did include a usb cable and an instruction sheet in addition to the charger.
DSC_6375
The charger has a micro usb input and a full size usb output for the power bank function.
The charger needs a 2A usb power supply/charger to work at full speed.
DSC_6372
The user interface is a couple of leds and a single button.
A fast press on the button will select battery type, when a battery has just been put into a slot.
A long press (2 seconds) will change current at any time.
DSC_6348
There is 4 blue leds for each slot, they are used to show charge state and when selecting battery type.
DSC_6349
One 3.7V LiIon (Charge to 4.2V) and one NiMH battery in the charger, ready to charge with 0.5A
DSC_6350
Charging, the blue leds are animated.
DSC_6376 DSC_6377
The slots uses the classical slider construction and it works fine.
The slots can work from 33 mm to 70mm. This means that very long protected 18650/26650 batteries will not fit in the slots.
supportedBatteryTypes
supportedBatterySizes DSC_6407 DSC_6408 DSC_6409
DSC_6410 DSC_6411 DSC_6413 DSC_6414 DSC_6415 DSC_6416
The charger can handle 70 mm long batteries including flat top cells.
Measurements
  • When not connected to power it will discharges with less than 0.1mA.
  • On the power bank slot it will discharge with about 0.15mA (45mA while indicating capacity).
  • When power is connected with a full battery, the charger will charge with 0.15mA
  • Below 0.1V the charger will not detect a battery, but will charger with about 3mA
  • Between 0.2A and 1.5V the charger assumes NiMH
  • Between 1.6V and 2,1V the charger will not recognize a battery, but charges with about 2mA
  • Above 2.2V the charger assumes LiIon
  • Charger will not restart when voltage drops.
  • It will restart charging on reinsertion of the battery or power cycling.
  • Usb input power consumptions when idle without batteries is 34mA, with batteries about 60mA
Charge LiIon 3.7V setting (4.2V charge voltage)
LiitoKala%20Lii-202%201A%20%28PA18650-31%29%20%231
The charger uses a CC/CV charge algorithm with about 50mA in termination current, this is a good charge.
LiitoKala%20Lii-202%201A%20%28PA18650-31%29%20%232
Second channel looks the same.
LiitoKala%20Lii-202%201A%20%28SA18650-26%29%20%231
LiitoKala%20Lii-202%201A%20%28PA18650-34%29%20%231
No real surprise with the low/high capacity cells. The 3400mAh cell charges a bit faster than the 3100mAh cell, because the CV phase is shorter (The length of the CV phase will depend how worn the battery is).
LiitoKala%20Lii-202%201A%20%28BE18650-26%29%20%231
This old battery needs a very long CV phase, and is charged fine.
LiitoKala%20Lii-202%200.5A%20%28PA18650-31%29%20%231
The charger profile is just as fine at 0.5A and the termination current is the same.
LiitoKala%20Lii-202%200.5A%20%28AW18350-IMR%29%20%231
LiitoKala%20Lii-202%200.5A%20%28KP14500-08%29%20%231
The two small cells are also charged fine, there is some sort of hick-up while charging the 18350, but it do not affect the final result.
LiitoKala%20Lii-202%201A%20%282xPA18650-31%29
Charging two cells at the same time means that the charger needs 2A from the usb input.
LiitoKala%20Lii-202%201A%200.5ohm%20%282xPA18650-31%29
Simulating a weak power supply by adding 0.5ohm in series with it slowed down the charging considerable, but did not prevent the charger from doing a good job.
Temp3603
M1: 36,9°C, M2: 36,7°C, M3: 42,8°C, M4: 42,9°C, HS1: 53,8°C
I can spot something warm in the charger, but not anything hot and the batteries is not very warm.
Temp3604
M1: 36,4°C, M2: 35,4°C, M3: 46,5°C, HS1: 57,3°C
PowerOnLiIon
The charger need some time to start, most of the time is used to wait the user to select another battery type.
CurrentChangeLiIon
When changing current the charger always start from a low current and slow increase it to the selected level.
Charge LiIon 3.8V setting (4.35V charge voltage)
LiitoKala%20Lii-202%201A%20%28LG18650-30%29%20%231
No surprise with the 4.35V charge, it looks fine.
Charge LiFe 3.2V setting (3.6V charge voltage)
LiitoKala%20Lii-202%200.5A%20%28SO14500-LiFePO4%29%20%231
LiitoKala%20Lii-202%201A%20%2818650-LiFePO4%29%20%231
The two LiFePO4 charges also looks fine.
Charge NiMH 1.2V
LiitoKala%20Lii-202%201A%20%28eneloop%29%20%231
With NiMH the charger turns off current to measure the voltage and will terminate on voltage without doing a top-off charge. This means the batteries will not be fully charged, but they are fairly close.
LiitoKala%20Lii-202%201A%20%28eneloop%29%20%232
The second channel looks the same.
LiitoKala%20Lii-202%201A%20%28eneloopPro%29%20%231
LiitoKala%20Lii-202%201A%20%28eneloopXX%29%20%231
LiitoKala%20Lii-202%201A%20%28powerex%29%20%231
On the 3 high capacity batteries there is a small temperature increase at the end, i.e. they are very close to being fully charged.
LiitoKala%20Lii-202%200.5A%20%28eneloop%29%20%231
Termination works fine at 0.5A
LiitoKala%20Lii-202%200.5A%20%28eneloopAAA%29%20%231
The AAA is charged fine.
LiitoKala%20Lii-202%201A%20full%20%28eneloop%29%20%231
As usual voltage termination is fast to stop when the cell is full.
LiitoKala%20Lii-202%201A%20%282xeneloop%29
The charger maintain the same charge current with two cells.
Temp3626
M1: 37,7°C, M2: 38,9°C, M3: 42,8°C, M4: 42,2°C, HS1: 56,0°C
PowerOnNiMH
NiMH needs the same time to start as LiIon, but it is not possible to select battery type.
CurrentChangeNiMH
With NiMH the current change is more abrupt.
Usb output
  • Usb output is coded as Apple 1A
  • Usb output will turn off after 10 seconds with less than 38mA load.
LiitoKala%20Lii-202%20load%20sweep
The usb output can deliver 1.2A before the voltage starts dropping, this is good for a 1A output.
LiitoKala%20Lii-202%20usb%20out%2010ohm%20%28PA18650-31%29
With a 0.5A load the usb output looks good for about 3 hours.
LiitoKala%20Lii-202%20usb%20out%205ohm%20%28PA18650-31%29
But at 1A load the usb output do not really work, the converter cannot handle a partically discharged battery.
10ohm
The noise is 266mV rms and 2285mVpp, this is bad.
5ohm
The noise is 269mV rms and 2197mVpp. The noise looks different but the actual noise level is about the same.
Conclusion
This charger is good at LiIon and fairly good at NiMH and the possibility to select multiple LiIon voltage makes it very versatile.
The power bank function is not very good, it uses an old coding and cannot deliver full current with a partial discharged battery, in addition to this the noise is very bad.
I.e. it is a good charger, but do not buy it for the power bank function.
Notes
The charger was supplied by Gearbest for review.
will34
will34's picture
Last seen: 21 hours 14 min ago
Thanks for the review HKJ! That is a very nice CC/CV curve and excellent termination current.
Since the powerbank function is not very useful, by removing the USB port and expanding the hole I think there is room for a voltmeter like we have done with the Li-100, and even a small switch to read between the two batteries.
MRsDNF
MRsDNF's picture
Thanks HKJ.
atbglenn
atbglenn's picture
Last seen: 3 years 5 months ago
Nice review as usual. Too bad the USB port kind of sucks. Everything else looks good.
Boycott Nike
Mitko
Mitko's picture
Last seen: 1 year 11 months ago
10x for your effort m8
Something that needs to be mentioned: the charger claims to charge 2 liions at 1 amp each but it doesnt, when 2 batteries are charged at once it charges them at 600ma each
Tested with both Blitzwolf 2.4a USB charger and PC USB 3.0 output, a total of 6 units so far
HKJ
HKJ's picture
Not in my test, as can be seen on my curves. It is more like 900mA.
Try a short thick usb cable from the usb power supply to the charger.
Mitko
Mitko's picture
Hm…have to try that out- was using their default cables , as long as they provide those its usualy means they should be working as intended
Barkuti
Barkuti's picture
Last seen: 1 day 6 hours ago
Those default cables are usually pretty lame. Remembered me of this example of “premium” lameness: BlitzWolf® BW-CB6 2.1A Reversible Micro USB 6.56ft/2m Charging Data Cable @Banggood
Sorry fellows, 2,1A through 2 meters of AWG22 wire “round trip” means a whopping 457,28mV drop in the cable itself, and I haven't included plug resistance losses. In no way such a cable can live up to those deceitful claims at 5+V nominal PSU voltage.
That's the reason I built for myself a custom 5' data/power USB cord out of some spare Cat 5e cable.
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
brjones
Last seen: 4 years 3 months ago
I bought one of these from Gearbest, and it won’t even pull 1 ampere — even with two 18650 cells! I think the best I ever pulled was around 0.75A, but usually it’s actually only about 1/3 amp!
It also decides that cells are charged prematurely. Especially if a cell gets moved a bit (I often have to reset it then), but it will only charge to about 4.08V even if I don’t touch it.
My single-cell version of this charger actually draws more power! (Works properly and charges fully.) With that one (the 101?), I can draw a full amp.
I’ve even taken apart my Lii-202, looking for connection problems, or anything I might notice. No change. Any ideas? I had a bad experience dealing a very resistant customer service email rep at Gearbest, so I haven’t been enthused about trying to contact them.
By the way: yes, I used good power sources, and specially-selected (and multiple) high-quality USB cables. I have USB power monitoring devices, and compared it with several other working chargers, using the same equipment. It’s definitely the Lii-202.
- Circumcision, regardless gender, by definition causes sensation loss, and thereby usually causes difficulty later in life. Oppose amputation of children's genitals. ALL children. http://tinyurl.com/haszs6o
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 5 hours 21 min ago
Thanks HKJ! Looks like a good charger to give to a beginner!
mapache
mapache's picture
I ordered a Lii-202 for my parents and it too ceases charging early, though not as bad as yours. Right bay stops at 4.12V and left stops at 4.14V.
Barkuti
Barkuti's picture
Maybe quality issues in this early revision? What's up with all of that noise on the USB supply and the inability to deliver full power at low input battery voltage? It worked well on the smaller sibling, you know, so…
Stick with the known good and easily moddable Lii-100, comrades. I myself have plenty of 2+A 5V PSUs, including a vintage 4-port USB v1.1 hub fed with a 6V 2A linear “brick”.
Cheers Party
HKJ
HKJ's picture
A usb meter may be the reason it will not charge with full current.
Barkuti
Barkuti's picture
Mmm, just took a quick peek at some old school linear supply smoothing capacitor calculations, and I'd say that a 4700μF capacitor (mod) at the USB output should be plenty to keep the noise under 500mVpp at all times, doesn't it?
Yes, I already know this may sound sort of “wtf” to most end users, but learning is fun.
Cheers Party
HKJ
HKJ's picture
Barkuti wrote:
Mmm, just took a quick peek at some old school linear supply smoothing capacitor calculations, and I’d say that a 4700μF capacitor (mod) at the USB output should be plenty to keep the noise under 500mVpp at all times, doesn’t it?
Cheers Party
Maybe, but you cannot use the old style calculations.
The frequency is much higher, this means smaller capacitor.
You need a capacitors with low ESR at the relevant frequency, i.e. a type with low ESR at 100kHz will do.
It will not increase the power of the boost converter, i.e. you will still have problems when the battery voltage is low.
HarleyQuin
HarleyQuin's picture
Thanks for the testing, HKJ! Great review as always.
I’m very happy with this charger, bought from Gearbest 2 months ago. Never used the powerbank function, though. But charging it does great.
I took pics of the internals, will upload them soon.
Mitko wrote:
the charger claims to charge 2 liions at 1 amp each but it doesn’t…
Mine does 2 × 1A very nicely, but it was difficult to find out.
I measured with aluminum foil, cardboard and DMM first, and got very low values. The foil had a strangely high resistance and the DMM added to it. Then I soldered a 10mOhm shunt in both channels and measured the voltage drop: slightly over 1A per channel simultaneously. PSU is the HKJ-approved Enerpower Flypower 2A.
So my charger does a fine Job.
Will start looking into making the target voltage selectable.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Barkuti
Barkuti's picture
From the article, C = Iload / (f × Vpk-pk). After peeking at the graphs, I decided to go with Iload = 1,2A, f = 500Hz and Vpk-pk = 0,5V. This results in… 4800μF. Of course, these calculations may not mean much here and such capacitor may still be oversized, in practical terms. And of course, that won't fix de boost converter design/quality control failure. Facepalm
Are classic (cheapo?) electrolytic caps low ESR in nature? I believe so, or at least should be more than good enough for this and/or fixing noisy driver outputs, doesn't it?
Cheers Party
HKJ
HKJ's picture
The switcher frequency is probably about 50kHz.
For best result you need a capacitors specified for switcher usage, i.e. low ESR specified at 100kHz. Capacitors designed for 50/60Hz bridge rectifiers or audio applications are not really low ESR types and are not designed for 100kHz.
HarleyQuin
LiitoKala Lii-202 PCB
Oshpark Boards:
UDO
Last seen: 1 year 6 months ago
Pass through charging is not working on Lii-202. So usb output is not working if usb input is connected (with or without batteries inserted). Any way to fix this? Like manually connecting usb input contacts (+ and -) with usb output? Any concerns why I should not do that?
kostasb
Last seen: 11 months 1 week ago
Lii202-V7 pcb
10/28/2016
Lii202pcb_1 Lii202pcb_2
angerdan
angerdan's picture
Last seen: 5 days 13 hours ago
kostasb wrote:
Lii202-V7 pcb
10/28/2016
WHat’re the changes to the version v3 ?
vidramon
Last seen: 1 year 4 months ago
Hmm, new ones have problem with low voltage charging in one slot.
One slot is 4.17-4.18V and other is 4.11-4.13V tested on three samples. So they mess something in this new ones in whole batch, does someone else notice this ?
SIGShooter
SIGShooter's picture
Last seen: 1 hour 34 min ago
I bought one several years ago where 1 slot charged around 4.20 and the other around 4.17 so it’s not a new issue.
vidramon
Yep, but now it is eaven lower Facepalm
What cells are you charging, I try with 30Q and get that results, right now I charging on one sample that I have from 1-1.5 years ago and will report about half hour what I get on it..
SIGShooter
I was charging Panasonic 18650B’s at the time. I threw the charger into my earthquake supplies so I haven’t used it since then.
vidramon
Yep, it is not about different cells.
This older one that I test now, I get after rest in right slot 4.21V and in left 4.17V, new ones are like I said right 4.17-4.18V, and left 4.11-4.13V..
Does anyone warn them about this, do they have account here so we can ask them to repair this ?
Macka17
Last seen: 1 year 9 months ago
I bought one just for 4 x Li-Po4 AAA’s I bought.
It works fine for them.
Battery’s read even when checked on Multi. Plus evenly charges any 18650/26650’s I’ve had in there.
Everything else I do with Xtar VC 4 and VC 2.
I also use a NIKON 3.5A cable for all my chargers.
I use Panasonic B’s, Samsung 30Q in 18650,
With Soshine 26650, 14500, and Li-Po4 10440’s.
Those Soshine are cheapies that seem to give constant output and lots of reserve for the price. Can’t complain so far.
teacher
teacher's picture
Last seen: 3 years 4 months ago
Does anyone know if there is a fairly simple way to fix this so both bays end up at about 4.19V – 4.20V??
If so, what is it??
Any guidance appreciated….. Thumbs Up
Barkuti
Barkuti's picture
teacher wrote:
Does anyone know if there is a fairly simple way to fix this so both bays end up at about 4.19V - 4.20V??
Maybe enjoy your dual output voltage setup? Innocent
Cheers Smile
teacher
teacher's picture
Cheers Smile
I got no idea what your talking about. Facepalm
So, if you don’t mind…….
……IF there is anything to explain… please explain it. Wink
Otherwise…. I’ll just assume it was a BS comment. Wink .. Innocent
