Davx
(Davx)
October 19, 2011, 5:32pm
1
I start using an Imaxb6 to charge/test my cell... I know that someone in the forum has the same charger.What "setting" you use?
- Max runtime
- Charging current
- Discharging current
- etc...
Any other suggestion about the value of other setting?
fran82
(fran82)
October 19, 2011, 5:44pm
2
IMAX B6 multi-battery type charger
Reviewer's Overall Rating: ★★★★★
[image]
Summary:
Batteries supported to charge:
Li-ion, Li-po, LiFePo4, Ni-Cd, Ni-Mh, Pb...
Input voltage range:
From 10v to 18v DC
Max number cells:
Ni-Mh 15 cells - Li-ion 6 cells
Discharge function:
Yes
Power supply:
EXTERNAL (included)
Temperature monitoring:
Yes
Price Payed:
36,20 USD
DealExtreme
Date Ordered:
Aug 2011
Pros:
Charges almost all chemistries (the most co…
I can help you. What do you need exactly?
-Charging current, depending on the chemistry and capacity of the bateries you want to charge.
For example, Li-Ion, is safe/good maximun 1C or less. NiMh, 0.5C or less (except fast charge)
-Discharge current, depending also on chemistry and capacity. This charger has a maximun discharge rate of 1A.
Li-Ion, let´s say 1C or 2C. NiMh.... 0.5C 1C...
kbark
(kbark)
October 19, 2011, 5:51pm
3
Turn the max runtime OFF. If you set it for 120 mins. and it takes 130mins to discharge you will have to charge it and start over.
I only charge and discharge at 0.5a/1.0a
Davx
(Davx)
October 19, 2011, 6:31pm
4
Ok, thanks for help. I will turn max runtime off.
Fran can you tell me Charging current, discharging current and time needed (approximately) for Nimh (2000 mah eneloop) and Li-ion (TF flames 2400 mah or XTAR 2400mah)?
When you set voltage the value "AUTO" can really understand if i am charging one battery or a pack (without balancing cable obviously)?
fran82
(fran82)
October 19, 2011, 7:00pm
5
Eneloop, I suggest 500mA charging and discharging current for better capacity (5,6 hours)
TF Flames 2400mAh, suggest to charge anything from 0,5A to 1A. Discharge max 1A
I dont use AUTO, I use man
Davx
(Davx)
October 19, 2011, 7:24pm
6
Ok. Got it. Thanks again!
fran82
(fran82)
October 19, 2011, 7:27pm
7
If you have any other problem or question, feel free to ask. However, the imax b6 manual is veery well explained. At least mine...
Stippier
(Stippier)
October 19, 2011, 8:00pm
8
From what I heard you should use the lipo (till 4,2 volt) option instead of the lion (till 4,1 volt) selection.
When would you want to discharge a battery? I never used this option. Do you need manual set the cut-off for this? And if so how high is it.
willie
(willie)
October 19, 2011, 8:21pm
9
Stippier:
I discharge/charge my new batteries to make sure they are good. Discharging batteries tests capacity and strength. If they don't measure up the retailer gets a call/email and return/refund process starts.
fran82
(fran82)
October 19, 2011, 9:43pm
10
Stippier:
Yes, for 4.2 volt batteries you have to select the Lipo option.
For discharging, I use Li-ion option too
