Compact 15 degree XR-E/7070? reflector... ???
3 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 1 day 19 hours ago
Hi fellows, a tad bored as usual lately. Checking out eBay searching for XR-E lenses, as I presume they would also do good on 7070 emitters Question , just found this cute looking thingie:
10pcs 15° LED Reflector Collimator Lens Cup Base For Cree XR-E/XM-L/XM-L2 Q5 T6
Mmm, isn't it a tad fat opened for 5050s?
Well, would it pair nicely with quad-die emitters? Seems to have “texture” for it, right? It also has about the right height to be crowned with a 11mm focal distance aspheric, LoL!
Nice price. Smile
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
ImA4Wheelr
Very interesting idea indeed.  I don't like the idea of reflectors that step out like that.  Seems like there has to be a shadow cast after each step that wastes reflector surface.  With your multi-emitter idea, that might be a minimal impact.  Sure is low cost enough to try out.  Smile
kiriba-ru
kiriba-ru's picture
Last seen: 1 day 2 hours ago
Diamater:22mm
15-20 degrees seems to be hotspot angle. Full angle is much bigger.
