LG 18650 HG2 3000mAh (Brown)
Official specifications:
- Nominal Capacity: 3000mAh
- Nominal voltage: 3.50V
- Standard charge: 1500mA, 4.2V, 50mA
- Max. charge voltage: 4.20V+/-0.05V
- Max. charge current: 4000mA
- Standard discharge: 600mA down to 2.5V
- Fast discharge: 10000mA, 20000mA down to 2.5V
- Max. continuous discharge: 20000mA
- Cycle life: 300 at 10A, 200 at 20A both with 4A charge, ramaning capacity minimum 70%
- Weight: 47.0g
- Operating temperature: charge 0°C ~ 50°C, discharge: -20°C ~ 75°C
- Storage temperature: 1 month: -20°C ~60°C, 3 month: -20°C ~ 45°C, 1 year: -20°C ~ 20°C
/LG%2018650%20HG2%203000mAh%20(Brown)-info.png)
A high current and high capacity cell, that is rated for high current use.
/DSC_7019.jpg)
/DSC_7021.jpg)
/DSC_7022.jpg)
/DSC_7023.jpg)
/DSC_7024.jpg)
/LG%2018650%20HG2%203000mAh%20(Brown)-Capacity.png)
The discharge curves tracks perfectly.
/LG%2018650%20HG2%203000mAh%20(Brown)-Temp-15.0.png)
/LG%2018650%20HG2%203000mAh%20(Brown)-Temp-20.0.png)
At 20A the cell reaches 81°C, but first after discharge has terminated.
/LG%2018650%20HG2%203000mAh%20(Brown)-Temp-30.0.png)
At 30A I terminated due to temperature, but the cell do reach 90°C after termination.
/LG%2018650%20HG2%203000mAh%20(Brown)-CapacityTimeHours.png)
/LG%2018650%20HG2%203000mAh%20(Brown)-CapacityTime.png)
/LG%2018650%20HG2%203000mAh%20(Brown)-Energy.png)
/LG%2018650%20HG2%203000mAh%20(Brown)-PowerLoadTime.png)
/LG%2018650%20HG2%203000mAh%20(Brown)-TripCurrent.png)
/LG%2018650%20HG2%203000mAh%20(Brown)-Charge.png)
Ignore the A charge curve, there was a glitch on my equipment.
Conclusion
This is a very good high current cell and it is rated to be used at high charge/discharge rates.
Notes and links
Compare to 18650 and other batteries
Thank you , I have a couple of these. Now I know how they stack up.
Yes, finally! Thanks a lot HKJ, gonna check this one out with other cells using your comparator
Thanks HKJ!
Your tests verify others! The VTC6 AND 30Q have less voltage sag than the LGHG2. I have all 3 of the batteries.
The 30Q is the best for the money and not far at all behind the VTC6 in terms of LEAST voltage sag. The HG2 comes in 3rd place in that category!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
WOLFDOG
What’s up with seemingly decent manufacturer rating 2800 mAh cell as 3000 mAh one? :/ Not something I’d expect from LG, to be honest.
Probably the difference between discharging to 2.8V and 2.5V.
I thought about that too, as you’ve mentioned before that you don’t test until 2.5V. However, if you extrapolate until 2.5V visually, it still doesn’t seem to have 3000 mAh. This is not the only occasion though. A good example is the Sanyo 2600 mAh that you have tested; it clearly shows that capacity is 2400 mAh, and no way it can be 2600 mAh. I suspect there has to be some kind of scientific tric/philosophy behind this phenomenon; I can’t imagine they’re just messing with us…
Edit: after checking again with the LG, it actually does seem to be feasible to have (close to) 3000 mAh. The Sanyo 2600 on the other hand…
Applauds!
Once again quite precise review, 10x m8!
And for the BLF interest i have to add that with bick drivers HG2 performs a bit better( only a bit, 100ma or something),
30q has been greatly improoved lately, nearly reaching 25r considering its int resistance
Hg2 can be used in series without modificatons, 30q need a magnet or a solder blob
Thanks for the review!
I’m surprised at how short is the CV phase, it takes almost 60 minutes less to charge this than your regular 3100 mah cell used in the charger tests.
USB power meter/tester thread
That’s my main reason for using high-current 18650’s everywhere, even in low-powered lights. They are surprisingly quick to charge with a 2A charger.
Still like the he2 best
With an amazing price/quality ratio as I see it, I agree without a doubt.
Cheers
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
You should try the new 25r m8, its nearly as vtc5 considering int resistance and fet dd drivers performance
Cyan or green wrapper?
Cheers
Cyan arent produced anymore, if someone has those on stock they are old
Speaking of greens ofc, they constantly make new revisions, the last one is 12 afaik
The upper one is from the last batch
Its also 1.6grams heavier
Mmm, I was suspecting that already but, check this out: http://www.gearbest.com/25r-_gear/
Are you running some sort of battery retailer/distributor business, Mitko? LoL!
Cheers
Well those are pictures only m8, Gb sells alot, they prolly have from those too: aint sure though, those are local EU breeds – Poland
Haha nope, just a hard BLFer m8
HG2/HE2 has been changed too , they were performing better than 30q when annoyced
As always, nice test HKJ,
now if only our resourceful chinese suppliers could find a was to ship li-ion cells to Europe that would be bliss.
I only managed to get 4 of this cells before new shipping regulations screwed everything.
I have to dig this out because of reasons.
I read somewhere, that the HG2 age pretty badly and that they lose capacity fairly fast compared to the 30Q.
Since GB offers them for €14.02 I would like to know if this is true or not.
I would use them in the Utorch UT03 so I need some good High Current Cells
You may want to check here L4M4: https://liitokalahongkong.aliexpress.com/store/217753
Can buy a 4-pack of INR18650-30Qs for ≈€14.
Shipping: US $3.68 to Germany via Turkey Post
-> $19.86
meh
I’ll just wait until GB fixes their 30Q Code and buy them there. Let’s play it safe
But very interesting Store, just like the Colaier one. I read somewhere that Liitokala and Colaier are basically the same company, they just rebrand all their products to Colaier. I like the name Liitokala more.
Recently I received a pack of 4 30Q and they were all charged at 3.41 volts.
Were they old stock or stored incorrectly?
Happened to me too, a pair from the Colaier store.
It's within tolerance margin, nothing to worry.
Helo to all
Did someone tested batteries from Liitokala aliexpress shop. They say that bateries are genuine…
Are realy genuine?? reated capacity??
svicar1, discerning the authenticity of a cell is more than just a matter of measuring capacity, discharge performance also matters, along with looks and shape of the cell.
While I am not going to say there's no chance to find AliExpress sellers trying to sell fake cells, certainly a bit of common sense matters. The AliExpress way of doing things encourages honest sellers, they don't see a dime until the customer has received and checked their packages. The ubiquity of customer reviews helps too.
Got a pair of 30Q cells from what was known as the Colaier Direct Sales Store months ago. Flawless performance in a Sofirn C8T FET flashlight.
Cheers
I only ask if someone tested some liitokala batteries that are rated as 100% original LG or Samsung or Sanyo or Panasonic…If this store is trustable…
Just checked them out. They are selling a set of 5 30Qs for $20, only $57 shipping to S.A.
Sign……
Beam me up!
In regards to this LGHG2.I am not impressed at all. I have had two of them. One of them was 15 months old and the capacity dropped to under 2400 mAh. In addition it got so hot on the charger that I decided to recycle it. I’m not home or I would post the photo from my opus. My VTC5 which was a year older and had many more Cycles actually had more capacity.
WOLFDOG
The VTC6 ended up losing the most capacity in Mooch's accelerated aging test. What a shame is, in my opinion, to pay a price premium and perform like the worst (or worse) after a few months.
Yes Samsung INR 30 Q is the best in long term use.
Personally I’m not convinced. Charging with 4A is not exactly standard procedure. Surely this “accelerates” wear, but does not necessarily result in a realistic comparison of different cells. Perhaps with a normal 0.5A or 1A charge rate the VTC6 may have maintained more capacity than other cells. We also don’t know what will happen after 50 cycles. Perhaps the VTC6 stabilises more than the other cells.
Of course, I’d rather see better performance of the VTC6 myself the way the test was conducted, but like I said, I’m not convinced to make a final judgment.
