Your "go to" Flashlight
62 posts / 0 new
High beams
Last seen: 5 years 10 months ago
Hello, I’m new to the forum. I was searching Google for best budget flashlight and it somehow lead me here. I’m hoping you guys can help me. I know you can’t expect much quality for cheap but I’m looking for two things here. The first one is a small portable flashlight that I can carry in my pocket for around $20-30. I want it to be pretty bright but I don’t want to have to buy specialty batteries. Also I’m looking for a super bright flashlight to keep on my night stand. Size doesn’t matter and I would like to spend around the same. Thank you in advance.
Edited by: High beams on 11/23/2016 - 22:34
pilotdog68
pilotdog68's picture
So no special batteries for either? I take it that means AA’s?
High beams
What’s the advantage of using non traditional batteries? I mean I would be willing to use them if they aren’t too expensive.
Keron
Keron's picture
Thrunite Archer 2A V3
You’re not wining, you’re surviving.
RobertB
RobertB's picture
Last seen: 1 week 2 days ago
Depends on your idea of specialty batteries. Rechargeable lithium ion cells really aren’t considered specialty anymore, at least not around here or any other flashlight forum. Granted, you can’t buy them at your local Walgreen drug store, but available at 100’s of online sellers. 1000’s if you consider electronic cigarette stores and websites.
That said, the Jetbeam MK-I is a nice little AA light, that can accept a 14500 lithium if you decide you get tired of buying AA’s. 220lumen with Alkaline AA, and 480lumen with a 14500.
High beams
I guess I just have a bad taste in my mouth with non traditional batteries. A friend of mine had an underwater dive light that used some special battery that was like $15 but we would only get one dive out of the battery before it died. I just don’t want to spend a ton of money on batterys.
pilotdog68
Lithium ion cells will give you more options, but it’s not necessary if you don’t want it. It definitely does require an extra investment. $5-10 per battery + $5-20 for a charger. Obviously rechargeable a few hundred times, so in the cost may be worth it.
Enderman
Enderman's picture
Rechargeable batteries usually perform better and you don’t need to buy new ones every time?
pilotdog68
Lumintop ED25 seems like it might fit the bill
RobertB
RobertB's picture
The dive light probably had crap batteries, or an HID light with not enough battery, or just a cheap dive light.
An 18650 lithium ion can be charged 400 times if you take care of it, costs 5-10 dollars, and has 4 to 5 times the energy of a AA. You’re looking at about 1100 AA batteries for an equivalent. So which is more expensive?
Barkuti
Barkuti's picture
Last seen: 1 week 3 days ago
High beams, you just came to the right place. As with all of which we experience, the bad taste in your mouth is a consecuence of no other thing than your beliefs, thoughts, feelings, … ignorance & bad decisions. So shift into high gear with wisdom.
Li-ion is pretty affordable nowadays. Less than $10 can afford you a quality battery and a cool single bay charger. And that's not to say that there are some good lights with built in battery charging.
However, if you're unwilling to learn at least some tech basics with regards to li-ion handling & care, better stick with Ni-MHs and alkaleaks. Don't freak, though, it's accessible in reality.
There are some 4×AA great quality torches, too, which coupled with good Ni-MHs do very nice. Yet don't even think in alkalines, powerful torches can kill them faster than those digital cameras of the past, they're simply not suitable for anything other than low drain applications.
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
RobertB
RobertB's picture
If you decide you are interested in learning more about the lithium ion powered lights, hang around, ask questions, and you’ll get more information than you dreamed possible in regards to flashlights.
Basically, lithium ion cells are named in numbers. 18650, 18350, 14500, 16340, etc.. What this means is, an 18650 is 18mm in diameter and 65mm long. A 14500 is 14mm in diameter and 50mm long (same as a AA), and so on.
Some flashlight examples, from left to right. 18650, 18350, 14500, 16340, and a standard AA. All the lithium ion’s charge to 4.2v
Yokiamy
Yokiamy's picture
Last seen: 4 hours 50 min ago
EDC, go for Jetbeam jet 1
150 Lm on AA, 450 on 14500.
Still waiting for my Jetbeam which i ordered 20 days ago from Gearbest…
Lexel
Lexel's picture
Jetbeam Jet-1 MK
Or Eagle Eye X2R
The X2R has a build in USB charger and costs you with a 18650B 22-25$
The light can run for almost 2 hours on high level
One 18650 battery equals 4 AA NiMh batteries
JockRobbins
JockRobbins's picture
Last seen: 5 years 9 months ago
Location: The slightly cooler end of a high powered torch
Once you go lithium ion, you’ll never go back.
Never.
Anthon
Last seen: 4 weeks 8 hours ago
My go to flashlight is the Olight S1A, with a Sanyo 14500 it reaches 600 lumens, and has the option to use AA’s
I know there are many other AA flashlights but for me this one has the best beam and user interface for daily use
Tangra
Last seen: 5 months 5 days ago
If you are looking for pocket flashlight it is good to: use one AA battery, have tail switch and not longer than 10 – 12 cm.
Neutral white light is also advantage.
Here is two options:
http://www.thrunite.com/thrunite-t10-xp-l-252-lumen-flashlight/
http://www.thrunite.com/thrunite-archer-1a-v3/
Bohemian
Bohemian's picture
Last seen: 4 years 3 days ago
Welcome from a fellow noob. I started coming here a few months ago with a similar question to yours. Now I have two chargers, four 18650s, two 14500s, and a bunch of Eneloops and Ikea Laddas, as well as a BLF A6, Convoy S2+, Crelant V4A, Astrolux A01, BLF 348, Lumintop Tool, Lumintop IYP 365 and Jetbeam Jet I MK to put them in.
If it were me I’d get a Jetbeam Jet I MK ($18-20) and a LiitoKala Lii-100 charger ($5) with a KeepPower 14500 840mAh ($7-8) for everyday carry. Or the Lumintop Tool ($13) which is in my pocket right now. The Lumintop Tool and the Jetbeam Jet I MK are my two favorite torches for EDC.
A note on prices: if you wait for a sale or look for a coupon, you can find all those items for much cheaper than what I listed. I got my Jetbeam Jet I MK for $13 shipped. I got the LiitoKala Lii-100 for $3.90. Etc.
Tomorrow (Nov. 25) is a big sale day; many prices at places like Banggood and GearBest will be low. Several members on this forum also offer coupon or deals threads. Groups buys can be a lot of fun.
Enjoy it.
The Miller
The Miller's picture
Thorfire TK4A
A small soda can light running on 4 AA batteries
Using a set of eneloops it is as bright as lotsof 18650/26650 flashlights I have, but safe.
It makes one smile to seethis much output from such a small light.
Oh and welcome to BLF!
Yokiamy
Yokiamy's picture
Well, that all depends of your opinion of Small i guess.
Personally, i think Soda can size is too big
-X3-
-X3-'s picture
Last seen: 1 week 19 hours ago
The Miller wrote:
Thorfire TK4A
And a Thorfire TG06 for the pocketable one, same AA batteries as well
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
SawMaster
Last seen: 2 years 11 months ago
I have a few “go-to” lights, the choice is based on the need of the situation, All are LiIon powered lights, though one accepts AAA cells too.
LiIon cells are like race-horses; you must have good ones and treat them properly to win. Not the cheapest initially but they’re well worth it in the long run. Investing say around $35 will get you a couple good cells and a good safe charger which will power your light under normal usage for several years; maybe as much as 10 years. In that time you’d spend more than that for primary cells. There’s also NiMh cells which are less potent but cheaper and safer that can give you equally long service. Incumbent with these is having a way to recharge them but there’s almost always a car or house nearby where you can plug in. Rechargeable makes good sense and good economy where you can use it Cool
Primary cells have their place and might be a better option for less-used lights and for where powering a charger is problematic. The main problems here are that you’ll have to keep replacing them as needed and that alkaline cells can (and often do) leak, destroying the light. Which is usually discovered only when you need the light the most Sad
So rather than recommending any lights, I’d recommend you do a bit of studying on what is available to power them and decide on which cell technology you want to go with before considering which light(s) to get. There are great lights for all technologies but each different one will be different lights recommended.
Phil
Lexel
Lexel's picture
a good charger and quality cell is less than 10$ on Banggood, Gearbest or other chinesse store
an original Panasonic 18650B protected cell costs below 5$
http://www.gearbest.com/batteries/pp_187046.html?wid=21
http://www.gearbest.com/chargers/pp_272183.html
chadvone
chadvone's picture
Last seen: 3 days 19 hours ago
Yokiamy wrote:
Well, that all depends of your opinion of Small i guess. Personally, i think Soda can size is too big
Too big for a Nightstand ???
RobertB
RobertB's picture
Lexel wrote:
a good charger and quality cell is less than 10$ on Banggood, Gearbest or other chinesse store an original Panasonic 18650B protected cell costs below 5$ http://www.gearbest.com/batteries/pp_187046.html?wid=21 http://www.gearbest.com/chargers/pp_272183.html
Gearbest and Banggood won’t ship lithium ion cells to the US. The good news is, there is no shortage of places to buy them in the US with the largest selection anywhere. So shipping is only a few days, vs 3 weeks to a month.
mrheosuper
Last seen: 1 year 3 months ago
Blf a6 would be a good EDC
and the “super bright” flashlight depend on your budget, olight X7 if you have a wide budget
Forgot my pen
chadvone
chadvone's picture
I have read your 1st post and I am getting this from you.
Your looking for 2 lights.
Your budget is around $60 total.
You do not want to use special batteries.
Now I have a few questions.
What lights have you been using?
How do you like the lights you have used?
What are some bright lights to you?
What distance do you plan on using your pocket light?
Comfortable size for a pocket light?
Are these lights , just in case lights, or are they required in daily life ?
In your 2nd post I am getting that you may be open to special cells.
Do you want to impress your friends?
Do you feel this could be a hobby for you?
Do you like taking care of things?
In your 3rd post I am getting you had bad experience with special cells.
Do you like learning new things?
Do you like pushing the limits?
Do you like online communities ?
Answering these will give us all a better chance of recommending lights.
Chad
The Miller
Nice post Chad!
And TS read li ion safety 101 (link in my sig)
Lightbringer
Lightbringer's picture
Last seen: 9 hours 57 min ago
At the risk of pissing off a lot of people here Big Smile , considering your requirements and mindset, I’d recommend just going to your local Work Bench and getting a set of LED Maglites. 2×AA for carrying, 2×D for the nightstand.
They’re slick lights, simple to use, take conventional alkies, and will last pretty much forever. Lifetime guarantee.
Never used any of their newer lights with the crazy UIs, but the simple on/off twisties are a classic.
Me personally? My EDC is a ’502 host, 5000K XP-L emitter, 1-mode on/off, Panny-B protected 18650 cell. Simple, bright, great runtime, works flawlessly.
In my bag, I carry a Convoy S2+ with ~4000K emitter and 3/5-mode driver, 30Q unprotected 18650 cell. Goes low/med/high if I want less light than the ’501. Lots floodier than the ’501, more for close-in work than “reaching out”.
Other recs?
Jetbeam Jet-1 for small concealed-carry, 1×AA, twistie.
XTAR WK50, ditto, except rear tailswitch.
Convoy C8, 18650 cell, nice thrower for longer distances.
Used to EDC my Quark 2AA-X or whatever, but I got too tint-snobby to deal with the greenish-tint it put out, even though I love the light itself and the UI.
keithd
keithd's picture
My go to?
Olight S1 since it hangs magnetically from my fridge and I’m often near there. It’s not the brightest, but it’s very convenient.
What was my go to in Afghanistan?
BLF A6. Hands down. Compact, powerful, and hung easily from molle gear. Fell several times onto concrete and gravel, still using it today.
Go to nightstand light?
Zebralight right-angle AA light. Forgot the model, but the ultra low moonlight mode is great when SWMBO is asleep.
texas shooter
Last seen: 23 min 49 sec ago
P60 is still my do everything light. Solarforce host and these dropins for max performance. http://www.mtnelectronics.com/index.php?route=product/product&path=86&pr... These dropins for battery flexibility 2.7-9v range Sportaclight.com
