XHP70 Living Room Light?
37 posts / 0 new
klrman
klrman's picture
Last seen: 1 day 10 hours ago
Anyone know if there is an indoor light that has an XHP70 in it at about the same watts as the turbo mode on the L6? Reason I ask is because I bounced my L6 in turbo off the ceiling and my wife was very impressed at how our living room glowed. She loved the 5000k and says that color and strength would be the perfect living room light for her if I can find one inverted so it points upward.  I guess I could attempt to build one myself with a decorative looking heatsink, etc but would be nice if someone did already.
Edited by: klrman on 12/04/2016 - 23:37
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 11 hours 41 min ago
How big is the room? 4000 lumens is a lot for a room? That would be equivalent to 5 60w incandescent bulbs? Generally speaking already made LED light bulbs are some what efficient compared to flashlight LEDS usually around 1w=80-100 lumen. So they do well not as good as flashlight but close.
You could retrofit a XHP70 into a bulb but it may be a bit hard to get the right beam pattern. You are more likely to find a COB LED inside a standard bulb. They can handle higher voltages.
mrheosuper
IT’S better to use many leds with smaller power than using A BIG LED
imagine sometime you accidentally look at the led, well, basically you are blind for a moment
Forgot my pen
Enderman
Enderman's picture
Last seen: 7 hours 8 min ago
He would probably use a diffuser or frosted lamp cover, not just the bare LED
mrheosuper
yeah, of course he will need to if he using XHP70, but using multi-led like XP-g3, the light will be more floody
i will use xp-g3 high cri in this case
Forgot my pen
Enderman
Enderman's picture
Yeah, running a XHP70 at high current to get 4000+lm will reduce it’s lifespan a lot and it produces a ton of heat.
I think the XP-G3 or new XP-L would work better for room lighting.
The XPG series are made for light fittings. I would still use a COB style LED. I might pull apart a LED bulb i have to check out what is inside.
Enderman
Enderman's picture
That’s true too, you can get COBs that run directly on 110v.
Although they usually cost a lot (or maybe it was just the ones I was looking at)
klrman
klrman's picture
Thanks for all the replies.  What my wife liked about the XHP70 was that it felt like the sun was shinning in the living room, but it is a small room, maybe 240sqft max.   Will look at the other LED options many of you mentioned here and see what might work.
Angler
Angler's picture
The main thing I take from your post is the attraction to how the light looked when bounced off the ceiling. I assume you had it setting on a table.
From such a low point such as on a table, a single floody light can light most of the ceiling of an average sized room. But this placement and point of emission is not ideal for a normal room light, as typically with up lights you want the source of the light to be above eye level, so that you don’t see the source of it when sitting or standing.
In my living room I have a pole uplamp that is 6ft tall.
It illuminates a portion of the room well but does not have the same moody effect as setting a flashlight on the coffee table in the middle of the room. Even though the lamp and flashlight make similar lumens.
You could just use a pole style uplamp with a bright LED bulb in it.
But the difference is it will likely be placed in a corner, and it’s light source will be closer to the ceiling than a flashlight ceiling bounce from a table. The effect is lost.
What style lights do you have now in the room?
How about downlights? Using LEDs.
I am more a functional person i hate down lights because of the maintenance but they do look nice. I think with LED technology downlights have come a long way.
klrman
klrman's picture
Angler wrote:
The main thing I take from your post is the attraction to how the light looked when bounced off the ceiling. I assume you had it setting on a table. From such a low point such as on a table, a single floody light can light most of the ceiling of an average sized room. But this placement and point of emission is not ideal for a normal room light, as typically with up lights you want the source of the light to be above eye level, so that you don't see the source of it when sitting or standing. In my living room I have a pole uplamp that is 6ft tall. It illuminates a portion of the room well but does not have the same moody effect as setting a flashlight on the coffee table in the middle of the room. Even though the lamp and flashlight make similar lumens. You could just use a pole style uplamp with a bright LED bulb in it. But the difference is it will likely be placed in a corner, and it's light source will be closer to the ceiling than a flashlight ceiling bounce from a table. The effect is lost.
Yes, I did place it unrealistically low right on the top of the coffee table.  That is why it looked so good bouncing of the ceiling and flowing down the walls.  Very sleuth of you to figure that out!  Bummer really as it would be quite difficult to re-create that effect.  Still going to play around with a few ideas to see if I can create that effect for her.
klrman
klrman's picture
everydaysurvivalgear wrote:
What style lights do you have now in the room? How about downlights? Using LEDs. I am more a functional person i hate down lights because of the maintenance but they do look nice. I think with LED technology downlights have come a long way.
A 50w halogen bulb in a clear vertical glass cylinder.  Because it's nearly winter up here and we almost never see the sun for months, very often I turn on my 50W, 6500 lumen LED work light and that works for creating a very cheerful winter indoors, but the light itself is just that, a work light and I just have it sitting on the floor.
mdeni
mdeni's picture
Last seen: 1 day 21 hours ago
You would like to have better color rendering for a room light. See this thread: http://budgetlightforum.com/node/34123
If you want a cooler light of about ~4000k, with a high CRI I would recommend the Osrams 4000k 95CRI with high R9 value.
http://www.ebay.com/itm/1-Stuck-1piece-OSRAM-SOLERIQ-P9-LED-COB-4000K-NEUTRAL-WHITE-CRI-95-GW-MAFJB1-CM-/272334590628?hash=item3f686812a4:g:HLkAAOSwIgNXkILS
http://www.ebay.com/itm/1-piece-OSRAM-SOLERIQ-P-9-POWER-LED-COB-4000K-NEUTRAL-WHITE-CRI-95-GW-MAFJB1-CM-/272334589892?hash=item3f68680fc4:g:UKoAAOSwARZXj83w
Higher than 4000k is not good for living rooms, and lower than 90CRI is also not good for living rooms. So this is the closest you can get to a pleasant cool light that renders colors as it should. (You would need 3 of these with a 30-40w driver)
Mkduffer
Last seen: 2 months 3 days ago
4000 lumens really isn’t that much light for a living room. It would be in the same ballpark as 2 4’ LED strip lights. By comparison, fluorescent tubes (I understand you’re not interested in fluorescent) would put out slightly more but use quite a bit more energy.
I used to do electrical engineering work a long time ago. In computer rooms, etc… we would spec indirect lighting. Some times they would be inverted tube lighting systems suspended from the ceilings and/or bare lamp strip lights mounted in indirect wall mounted light soffits.
We have large 4 lamp 4’ fluorescent (retrofitted with LED tubes) fixtures in our living room for when guests are over. but generally, I prefer indirect lighting to direct lighting and to achieve this at home, I use LED bulbs in torchier style floor mounted lights. The bulbs I use output about 800 lumens and fit in standard screw sockets. The torchiers I use have opaque shades which allow some direct light. If you wanted to go completely indirect, I imagine you could fashion some sort of foil shield, but if you mounted it inside the bulb area, you’d need to be very careful of not creating anything which could possible cause a short. Then again, foil outside the shade would look pretty ugly. Painting the interior of the shade white would be a reasonable compromised in my opinion, but you’d look efficiency.
Perhaps you could retrofit some torchiers, convert for low voltage. This would reduce the risk should a short occur. If you could get the right tint, P60 drop-ins might not be a bad option.
People say I’m a flashaholic like it’s a bad thing…
Mkduffer
Sorry, didn’t see the 240 sqft size. 4k lumens might be overkill. Sometimes I ceiling bounce my BLF A6 and that produces very nice results (before it gets too hot). Another option if you are looking for an indirect solution are wall mounted sconces. To test results, I’ve used magnets to attach some of my lights to the dry wall screws.
BTW, one thing I really like about the Jetbeam Jet-1 MK is that the tail is threaded to match a tripod. This makes for an easy temporary floor mounted indirect light.
techieman33
Last seen: 1 year 6 months ago
What I did in the bedroom was to put up some crown molding with the top of it 6” from the ceiling. Then I just dropped some rgb + ww LED strips into it. It’s very nice indirect lighting and I have complete control over the intensity and color from my phone. You could also go with remote control or wall mounted options as well.
WalkIntoTheLight
Last seen: 2 days 19 hours ago
Yes, ceiling-bounced floody flashlights, from table-height, give a fantastic lighting effect. It practically eliminates shadows, and makes everything appear much softer under the light. It’s hard to get that effect with standard household lighting. You might be able to do something similar with wall-mounted lights directed upwards to bounce light off the ceiling at an angle. Kind of like you see in some movie theaters or museums.
I don’t find the flashlight distracting when I bounce it, as long as I’m not standing in the direct path of the spill.
mdeni
mdeni's picture
It is not hard at all. And the light type is very good:
All the lights that I have are ceiling bounce.
Jerommel
Jerommel's picture
It’s simply the best way to light a room.
You need white ceiling (and walls), but white is the obvious choice for a ceiling anyway.
Mkduffer
Those first two are torchier styles. I’ve seen cheap torchiers for under $10 at Walmart. That last one is a wall sconce.
WalkIntoTheLight
Yes, with a 300 or 500 watt halogen bulb, they give off a very nice light that is bright enough for almost any room. The only downside is that they’re usually only 6 feet tall, and so taller people can see the bulb which is very intense. Well, they also use a lot of electricity, but you don’t get CRI 100 any other way.
alpg88
Last seen: 8 hours 18 min ago
i do not think you’ll find any factory made light that has 1 led running on max current, they always use multiple leds running at 1\2 or less of max current.
so if you want 4000lm xhp70 room light, you’ll have to build your own.
i gutted my 600w halogen light in my bathroom and replaced bulbs with 9 xml leds 80+cri, running at 900ma, it is even brighter that halogen was. sure i could have used 2-3 mtg2 at max current to get same amount of light, but leds run more efficient and make less heat at lower current.
http://forum.fonarevka.ru/attachment.php?attachmentid=88646&d=1383016973
mdeni
mdeni's picture
Yes that is partly true.
That was the case. I have one 500w halogen in my home. I have converted it 4 years ago with 3xE27 bulbs. 13.5W led times 3 is 45W for 4000lumens. And now there are many of those with a E27 bulb that can fit a LED with no problems. It will be a lot dimmer, but they are really cheap. Ikea has one for 5euros. The led bulb is more expensive than the fixture. And you can put multiple fixtures, and distribute the lights better.
I have wired the sockets that have the floor and table lamps to be on a light switch, so you do not have to turn each one individually. With smart bulbs you can have a similar setup.
klrman
klrman's picture
Would like to thank everyone here for some really good info.  The idea I kind of like the most at the moment is the one where I can wrap the whole living room with a led strip up under the crown molding and connect it to a switch that can turn it on or off as well as change the color like this one I found on aliexpress On/off color switch
I will secretly purchase and plan the whole thing and build most of it at my relatives house and when my wife is with her friends for a couple of hours, I will have it all set up in our house without her knowing and surprise her when she comes back!
leaftye
Last seen: 5 days 20 hours ago
4000 lumens really isn’t a lot for a room that size, especially if you’re using lampshades. Every room in my home has over 4000 lumens. It’ll may seem like a lot because most homes are incredibly poorly lit compared to offices and produce departments. That said, you’ll probably like the lighting a lot better if that 4000 lumens is distributed around the room. The led strip you’re thinking about is one way to do that. If you have high ceilings and lighting with a ceiling bounce, 4000 lumens will get eaten up real quick.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
klrman
klrman's picture
Low ceilings actually, just under 8ft.  We never wear sunglasses, so bright lights bouncing of the ceiling look very good and not so bright at all for 4000 lumens.  We have white walls and ceilings which makes it much easier to create a nice effect, so I'm eager to make this happen.  Would you or anyone else know of good quality led lighting that can change color?  I purchased a few about a year ago for my pc and 30% of the lights are already gone, so would like something that is more reliable than the ones I got and that can be dimmed.
Yea i am running poverty pack in my rooms maybe 1000 lumens max lol Its still bright.
klrman
klrman's picture
1000 lumens is ok too, just depends on the mood.  That's where a dimmer works well if it's too bright.
Mkduffer
We used to run lighting level calcs that took into account ceiling height, ceiling, wall and floor reflectences, light fixture properties, etc… Results were giving in average foot candles at the work plane (30” above the floor, typical height of your average work desk). It’s been a long time since I’ve done anything like that, but I’d bet somewhere out there, you could find an app which would allow you to at least estimate the amount of FC that you could expect to have.
For comparison, typically for an office space (in the days before computer workstations), you would expect the design to be somewhere between 50-100 FC.
IIRC, hallways, breakrooms, water closets, etc… were designed more around 30 FC. Generally for homes. there wasn’t any recommended lighting levels because they weren’t works paces and home illumination levels are more of a personal taste item. Your average house, therefore, was normally lit up to pretty low levels, often with task lights being used to augment. If you go back 30-40 years, a lot of homes (especially bedrooms) weren’t even designed with permanent ceiling mounted fixtures. Lighting was often provided by lamps plugged half-switched duplex receptacles.
Quick google search, I found this page, which spells out how to estimate how many fixtures/lamps you’d need based on the above mentioned parameters. http://www.houseplanshelper.com/lighting-calculation.html
Sorry, don’t have to do an in-depth review of their page.
Mkduffer
