I need a new power bank... could use some help picking it.
23 posts / 0 new
mattlward
mattlward's picture
Last seen: 12 hours 31 min ago
My old one finally died and I would like a new one. Reviews of the HJK style are slim on the the units with user installed 18650’s. I would like to use 18650 cells since they unit would not be used that often and I would be able to pull the batteries and cycle them thru lights to maintain a good cell.
I like the looks of the Tomo units, but it seems they may have issues with 2 amp output and balancing all the cells.
So, I am looking for suggestions. I have been using the Lii with a 26650 in a pinch, but not really all that portable with a battery just sitting in it…
Thanks Matt
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
Rufusbduck
Rufusbduck's picture
I just use an Xtar SP-1 charger/power bank. Single cell with micro in/USB cord out. Uses any cell over 2500mAHR capacity.
Scott
will34
will34's picture
Last seen: 1 day 2 hours ago
Miller ML-102 v8 or newer are good single 18650 powerbank/charger, but they only accept unprotected cells. It can handle up to 1.5A output with peak efficiency around 80% which is decent for single cell.
Although I would recommend getting a dedicated compact charger and a separated powerbank, I used to have a ML-102 in my car but realized it was not convenient having to charge it for almost 5 hours just to get 1.5 hour of operation. Since I do short commutes 5 hours of charge time equals to a whole week of driving just to fully charge 1 single cell.
Tomo “DIY powerbanks” have been proven to be very inefficient and unreliable, some people reporting different LVP for each of the cells. And they are not cheap either…
If you don’t mind building one yourself there are some high efficiency conversion boards, just add your own 18650 battery holder and charging module:
http://www.ebay.com/itm/TPS61088-QC3-0-Boost-Board-3V-L-5V-9V-12V-98-Hig...
Ronin42
Ronin42's picture
Last seen: 2 years 2 months ago
innogie alien 13400
used 3350 cells
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
tempo
Last seen: 1 day 18 hours ago
Usman wrote:
I highly recommend that you search for highly reputable Charging electronic companies that sell power banks and as well as other charging electronics like Wall and Car chargers. Most of the market that sells charging electronics don’t have their portable chargers up to standards where they’re supposed to be.
You can learn more about what charging electronics companies are best to trust here – Best Power Bank Brands
These companies that make power banks have repeatedly shown that they’re capable of continually improving on what they already have and pricing their power banks at a very reasonable price for what they’re capable of.
Thanks for the spam.
Marked.
Danglerb
We like our Blitzwolf, and when MicroCenter had the Tplink 10400 on sale gifted one to a happy getter.
Easy open, means not water proof. Lions should be happy with long intervals in charging.
Still a bit dim
Wrathbringer27
Wrathbringer27's picture
Last seen: 2 days 33 min ago
I’m currently using a rock 8000mAh powerbank. Comes with a nice feature of a variable dimmable floodlight Smile I love it so far…
Words can be broken,
so can bones.
Speed4goal
I have 3 tomo v8 power banks and have the new one the t4 on the way. Only had a issus with one. The soshine version. But imr exchanged it with no hassles. I take one to work everyday and leave two with my wife. The only complaint I really have is the 1 amp input for charging. But usually take the cells out and charge in my opus charger. For $12 I can’t complain about it. Easy to swap cells in and out if don’t have the time to charge them. With Panasonic 18650b I can charge my phone about 3 1/2 times phone has a 3000mah battery
Never heard of any battery balancing issues. Each slot is independent its not a series arrangement so there isn’t any balancing charging going on. Its a charger as well. I used it to charge my vape batteries and my edc while my daughter was being born in the hospital. Was easier to just bring it and use it as a power bank and charge the few cells I needed with me
Even with discharging it keeps the voltage the same. Even with different mah batteries. Like a 2000 next to a 3500. If I pull them half way down on the battery bar. All 4 batteries will be 3.8 and all 4 batteries are different brands when my wife changes them out. When I put them in the opus all the same voltages across all 4 bays
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
finges
Last seen: 4 hours 41 min ago
Have a look at Thrunite C2, there will be a new version (which is fixed so that it also works with low power devices) in around one month.
I like that the battery is changeable but sits protected inside the powerbank. So it can double as a charger for 18650 cells. Also, high charge and discharge current.
http://budgetlightforum.com/node/51171
StandardBattery
Last seen: 3 years 2 weeks ago
If you just need a lower power bank, i’d go for this RavPower 6700mAh one unless you insist on 18650 replaceable. I have got it on sale for around $12 and it’s size/shape/weight and features are the best for < 8A backup.
https://www.amazon.com/dp/B01LW6BT21
mattlward
mattlward's picture
Thanks… I may pick up one of the new Tomo’s and the Thrunite’s for when a small one is needed.
I appreciate the input.
Matt
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
RobertB
RobertB's picture
Last seen: 2 days 1 hour ago
I have two ELE-Power Thunder 16,000 chargers. LG electronics. Uses Qualcomm 3.0 for charging input and output. The tests I ran (with help from Will34) turned out to be around 85% efficient. Not removable cells, but this thing is nice in the 34 dollar range.
firedome
The famous TOMO DIY… I bought one some time ago when it was on sale on GB, while it is easy to use and convenient if you have lots of 18650s lying around!
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
mattlward
mattlward's picture
I have tons of 18650’s and would like to cycle through them and not just put them in a light to run them dead and charge them… although that is fun also!
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
carmantl
Last seen: 7 min 56 sec ago
My tomo 4 cell is great!
gangstead
Last seen: 2 months 6 days ago
I got one of the 2 cell Tomo units. It was really stiff to remove the cover and the second time I opened it I cracked the LCD display. Needless to say I was disappointed. There don’t seem to be any good multi-cell powerbanks with replaceable cells.
Jerommel
Jerommel's picture
Last seen: 1 year 8 months ago
I have a TOMO 4-cell one too.
It doesn’t shut off at low current loads, which is nice.
It’s rather big though..
Jerommel
Jerommel's picture
These are said to be good too:
http://www.banggood.com/Original-Xiaomi-10000mAh-Both-way-Quick-Charge-3...
Nice looking slim design.
The Miller
The Miller's picture
+1
how large do you want to go?
I saw a case and electronics for $17 the other day, with space for up to 10 × 18650 cells in parallel (buyer was supposed to add)
I was like, “hmm, maybe a solar panel and 10 protected panasonics 3400 could make this a nice set, keep it in mind and when time comes talk about it on BLF Wink
MAD TM26
MAD TM26's picture
Xiaomi Mi power bank 10400mAh and 10000mAh are also good (non slim version). Just make sure to get the genuine one as there’s so many fake Mi powerbank out there. The fake ones are definitely crap. Can’t even fully charge an iPhone 5S.
we buy light for a brighter tomorrow
mattlward
mattlward's picture
I have stayed away from them because of fakes… I would not know a real one for sure unless it bit me on the butt. I would hate to wait on shipping for a fake that I would have the wait to return.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
MAD TM26
MAD TM26's picture
Worth watching if you’re into Mi pb.
dodge_911
dodge_911's picture
Last seen: 2 years 5 months ago
MAD TM26 wrote:
Xiaomi Mi power bank 10400mAh and 10000mAh are also good (non slim version). Just make sure to get the genuine one as there's so many fake Mi powerbank out there. The fake ones are definitely crap. Can't even fully charge an iPhone 5S.
The Xiaomi 10400mAh is EOL, has been for over a year.
The Xiaomi 10000mAh (18650-based) is about to be EOL, that's why the price have been steadily going up the last few months.
It's being replaced with a LiPo based 10000mAh, called powerbank 2. User will34 wrote an excellent review about it. Yes, it's a little more expensive than the 18650-based model it is replacing, but it also perfoms a lot better. They basically took the 10.000mAh Mi Pro (with usb-c) and gave it micro-usb instead.
I also have one for testing, but as I am battling legionnaire's disease right now, testing will have to wait.
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
