Test/review of Charger GyrFalcon All-44 (Enova)
17 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 2 days ago
DSC_6873
DSC_6874 DSC_6875
Enova makes many different chargers, this time I have got a 4 slot version of their largest universal charger (8 slot). The charger uses the same design, but there is some small changes.
DSC_6835 DSC_6837
DSC_6836
DSC_6838
DSC_6839
I got the charger in a cardboard box with specification on it.
DSC_6872
In the box was the charger, a power supply, a instruction sheet, the warranty card, two spacers and two terminal extensions.
DSC_6876
The DC input is the usual barrel connector and it is rated for 12V input.
DSC_6877
The full user interface with 4 readouts and 6 buttons, one for each slot and two special buttons. All buttons has a leds in them.
The slot buttons will show a blue led while charging and a red led when done.
DSC_7113
The display has many elements on it, because the charger can handle many types of cells.
Depending on mode not all the elements are used.
DSC_7114 DSC_7115
First image is manual mode and second image is automatic mode (No block or marker for VV line). Hold down Fn and CV for some seconds to change mode.
In automatic mode the slot buttons is only used to change current, selection of voltage and starting is automatic.
In manual mode some more button presses are needed:
Start a slot (Method 1):
Press button for slot to select it.
Press button for slot again to select voltage.
Press CV to select current setting.
Press button for slot to select current.
Press CV to select voltage setting again.
Hold button for slot down to start charging.
Start a slot (Method 2):
The above methods are rather long if you want to charge many cells, the charger has some shortcuts to handle that:
Hold button for charging slot down and tap button for other channel will copy the settings tio all slot in between and start charging on these channels.
Hold Fn down and press CV will select 1A and 4.2V charge voltage for all idle slots, pressing multiple times on CV will change voltage.
These short-cuts means that charging any number of (4.2V) 18650, 26650, 32650 can be started by holding Fn down and tapping once on CV.
Charging any number of AA can be starting by holding Fn down and tapping CV twice.
DSC_7116
DSC_7117
Here the charger is working with a couple of different cell, each with its own setting.
The C.A line shows selected current and is also used to select current when the “>>” marking is at this line.
The V.V line shows selected charge voltage and is also used to the select voltage when the “>>” marker is flashing at this line.
The battery icon is animated when the charger is charging.
DSC_6878 DSC_6881
The sliders work very smooth and can handle from 32.0mm to 72mm, up to ø26mm cells can be placed in each slot and it is possible to use ø32mm cells in the slots, but not in slots next to each other.
DSC_6879
Using this accessory 32650 cell can be charged.
DSC_6880
Using the spacer shorter cells can be charged, each spacer is about 8mm.
supportedBatteryTypes
supportedBatterySizes
DSC_7098 DSC_7099 DSC_7100
DSC_7101 DSC_7102 DSC_7103 DSC_7104
DSC_7105 DSC_7106 DSC_7107 DSC_7108
The charger can handle 72 mm long batteries including flat top cells.
With 10180 cell the 100mA charge current is on the high side, but because most 10180 are high current cell it will usual be acceptable.
Measurements on charger
  • Power consumption when idle is 0.7 watt
  • Will discharge a LiIon with 0.1mA when not powered.
  • Will discharge a LiIon with 0.7mA when not charging.
  • Will discharge a NiMH with 0.03mA when not powered.
  • Will not charge at 0 volt.
  • NiMH charging start at 0.6 volt with selected current.
  • LiIon charging start at 0.6 volt with a 50mA.
  • LiIon current will drop to 20mA as voltage increases, at 3.0V selected current will be used.
  • Meter starts working at 0.7 volt.
  • Meter is within 0.01 volt.
  • Meter stops updating when battery is full.
  • Meter will not reduce reading.
  • Charger will restart silent if LiIon battery voltage drops below 4.05 volt.
  • Power cycling and insertion of a battery requires button press to start charging in manual mode.
  • Power cycling and insertion of a battery will automatic select NIMH/LiIon and start charging in automatic mode.
  • Charger has a time limit of 10 hours, except NiMH at 1A where it is 5 hours.
Charging 4.20V LiIon cells
Enova%20All-44%201A%20(PA18650-31)%20%231
A good CC/CV charge curve with about 80mA termination current.
Enova%20All-44%201A%20(PA18650-31)%20%232
Enova%20All-44%201A%20(PA18650-31)%20%233
Enova%20All-44%201A%20(PA18650-31)%20%234
All the other slots look the same, but there is a small variation in charge voltage and a bit larger variation in charge current, but neither is a problem.
Enova%20All-44%201A%20(SA18650-26)%20%231
Enova%20All-44%201A%20(PA18650-34)%20%231
Different capacity means changes in charge time.
Enova%20All-44%201A%20(BE18650-26)%20%231
This old cell reaches CV phase fairly fast.
Enova%20All-44%200.5A%20(KP14500-08)%20%231
Enova%20All-44%200.5A%20(AW18350-IMR)%20%231
The 0.5A current is fine for 14500/18350 and other cells with 0.6Ah to about 1.3Ah and it works fine.
Enova%20All-44%200.1A%20(KP14500-08)%20%231
Here I tried lowest charge current, it works fine and has a low termination current (good).
Enova%20All-44%201A%20(4xPA18650-31)
The charger can charge 4 cells with 1A simultaneous.
Enova%20All-44%201A%2012V%20(4xPA18650-31)
Doing this requires about 2A from the power supply.
Temp3720
M1: 39,5°C, M2: 44,3°C, M3: 44,3°C, M4: 41,5°C, M5: 44,1°C, M6: 41,7°C, HS1: 74,1°C
The charger and batteries are about 44°C warm and inside the charger there is a hot electronic part, both are acceptable.
PowerOnLiIonAutomaticMode
The charger will start automatic after about 1.5 to 2 seconds.
CurrentChangeLiIon
It is possible to change current during charge. In automatic mode just press the slot button. In manual mode first press the slot button, then the CV button, now the slot button can be used to change current.
Charging 4.35V LiIon cells
Enova%20All-44%201A%20(LG18650-30)%20%231
The charger supports both 4.30V and 4.35V cells, I only did a test with 4.35V and it looks fine.
Charging 3.6V LiFePO4 cells
Enova%20All-44%200.5A%20(SO14500-LiFePO4)%20%231
Enova%20All-44%201A%20(18650-LiFePO4)%20%231
The charger works fine with LiFePO4 cells. The charger uses a low current until the cell reaches 3V, then it will switch to selected current. For fully discharged LiFePO4 cells it can mean that charging takes an extra hour.
Charging NiMH cells
In manual mode it is possible to start a NiMH cell on a LiIon program, but it is not dangerous. Charge current will be low and the charger will stop after a few hours.
Enova%20All-44%201A%20(eneloop)%20%231
The NiMH charging stops on -dv/dt and looks fine.
Enova%20All-44%201A%20(eneloop)%20%232
Enova%20All-44%201A%20(eneloop)%20%233
Enova%20All-44%201A%20(eneloop)%20%234
On all slots, there is a small difference in current, but that is not important.
Enova%20All-44%201A%20(eneloopXX)%20%231
Enova%20All-44%201A%20(eneloopPro)%20%231
Enova%20All-44%201A%20(powerex)%20%231
The 3 high capacity cells are also terminated perfectly.
Enova%20All-44%200.5A%20(eneloopAAA)%20%231
No problem with an AAA cell.
Enova%20All-44%200.1A%20(eneloop)%20%231
Even at 0.1A the charger will terminate. This test would terminate earlier in the release version due to the 10 hours timeout (This timeout is missing in my test version).
Enova%20All-44%201A%20full%20(eneloop)%20%231
As usual -dv/dt is some time to terminate on a full cell, about 10 minutes is a fairly good time.
Enova%20All-44%201A%20(4xeneloop)
The charger has no problems with charging 4 cells at full current.
Enova%20All-44%201A%2012V%20(4xeneloop)
With NiMH it uses about 1A from 12 volt.
Temp3730
M1: 46,0°C, M2: 50,3°C, M3: 51,0°C, M4: 47,1°C, M5: 41,4°C, M6: 65,4°C, HS1: 77,9°C
The charger heats the NiMH cells and the temperature is at the limit.
PowerOnNiMHAutomaticMode
Starting is exactly the same as for LiIon.
ChargingNiMH
With NiMH the charger stops every 20 seconds to check the voltage of the cells.
CurrentChangeNiMH
Current change also works the same as for LiIon.
Testing the transformer with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
In automatic mode the charger works like any other good charger and will charge 4.2V LiIon and NiMH cells with a default current of 1A (A press on a button will change the current). Switching to manual mode the charger can charge most round cells on the market, at the cost of some more button presses.
I do not like the slot extension, I doubt I can find them when I need them. A longer bar on the plus side would have been much better (This is only relevant if you need to charger 32xxx cells).
I will rated this charger as a very good charger, especially if you have many different types of cells.
Notes
The charger was supplied by Enova for review.
khas
Last seen: 2 days 17 hours ago
Great review as always thanks, I was looking at this charger, but ended up with the MC3000 for more versatility and better control of the charging process.
This looks like a very good charger for the price if you don’t need to charge 32xxx cells.
specialk
Last seen: 3 months 16 hours ago
Thanks the great review. Does anybody know where I can get one with a north american plug?
khas
HKJ
HKJ's picture
You can charge 32xxx on it (If you can remember where you put the extensions last time you used them).
specialk
Thanks for the link.
will34
will34's picture
Last seen: 3 hours 46 min ago
Thanks for the review!
khas
Sorry didn’t come out right Facepalm
What I meant was, those small extensions would easily get lost on my desk so it would no longer be a 32xxx charger
stephenk
stephenk's picture
Last seen: 11 hours 26 min ago
Great review as always!
enova18650.com
Last seen: 9 months 1 day ago
Thanks HKJ for your great work.
ENOVA
Dep668
Last seen: 1 year 3 days ago
Thanks for the review, looks like a nice charger.
patchythepirate
patchythepirate's picture
Last seen: 1 year 4 days ago
Damn, after not being able to find a decent charger that does 4.3 AND 4.35 I settled on an Opus BT-C3100. Now I’m thinking about this guy.
Terry Oregon
Terry Oregon's picture
Last seen: 2 hours 21 min ago
You won't find many chargers that do both 10180 and LifePO4.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
Richwouldnt
Richwouldnt's picture
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Looking around it is currently listed by Mountain Electronics and imrbatteries.com as USA sources. Surprised that so few sources are available.
Rich Wood
Reno, NV
sovereignknight
sovereignknight's picture
Last seen: 1 year 4 months ago
I already own the All 88, so I think I’ll pick up an All 44 to deal with smaller jobs.
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x2 Sk68 modded 1 Nichia 319AT, 1 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x2 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - x1 Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d - x2 Lumintop Tool AA 2.0 Ti - x1 Olight I3T EOS
Richwouldnt
Even the All-44 is a wide charger due to being one of the few with slots wide enough to handle four 26650 batteries at once. I have the original Enova All-80 8 slot charger too, another wide one.
Rich Wood
Reno, NV
nick779
nick779's picture
I know this is a bit dated, but I grabbed one of these from mtn last month and just noticed that cells straight off the charger are always around 4.13v and that the readings are about 0.05 v high on the charger in advance mode before charging begins.
Anyone else notice this?
