Workshop and machinery mods and tips,
131 posts / 0 new
lostheplot
lostheplot's picture
Last seen: 9 months 1 day ago
is there enough wall thickness for a grub screw with a nylon slug under it so you don’t destroy the threads,,
then again its been like that for 36 yrs.
sorry all images down
thanks photobucket
MRsDNF
MRsDNF's picture
Yep. I still remember picking it up in the blue ute. I’m sure you were there with me at the time. Need pictures. Smile
pinkpanda3310
pinkpanda3310's picture
Last seen: 6 hours 27 min ago
I cut the corners off the end of the compound slide so I can swivel the QCTP without interference
MRsDNF
MRsDNF's picture
Wow. That is one drastic mod. Your a braver guy than I. Beer
lostheplot
pp how do you find the quick change toolpost?
thanks photobucket
MRsDNF
MRsDNF's picture
He probably looked for it. Facepalm
pinkpanda3310
Lol, “brave”….??? All I did was nick the corners. Nothing detrimental.
Do I like the qctp? Yes. I did have to turn down and thread the end of the hold down bolt as it was too large for the compound slide. Luckily I have a lathe for that Innocent The one major gripe would be the kit I bought had a limited number of tool holders and to buy more individually is a lot more pricey.
Tool holders I have – 4x standard 1x boring bar holder 1x knurler (which holds a tool on the backside) 1x parting tool holder plus the original tool holder that came on the lathe. Since I part off with the lathe in reverse I don’t use the quick change parting tool holder, I use the original tool holder for that. Still now and then I’m changing bits in the holders but for changing between commonly used bits it’s great.
I guess a pic could’ve explained that in less words but I’m on the phone.
And just because I’m looking for something doesn’t mean I always find it LOL Facepalm
lostheplot
another basic tip profile your tool,,no I;m not being rude.
need to make a intricate shape grind up some high speed steel
small cuts and slow speed gently gently
and you will be rewarded.
new reflector loosely based on the c8 reflector
thanks photobucket
MRsDNF
MRsDNF's picture
Nice. Are you planning on using this?
lostheplot
yes might shove a xml and blf driver in it.
more of a test run to see how it would go
see how many cree rings it has.
might try polishing some more with dremmel
thanks photobucket
Turningbluechips
Turningbluechips's picture
Last seen: 4 months 22 hours ago
If you can get in touch with someone that does electro polishing that would probably work quite well. Lot fees are pricey, we pay $120USD. But you might be able to talk someone into tossing it in with some other stuff since it’s a small part. Also an hour or two in a vibratory tumbler with plastic abrasive before will work wonders. The rings from polishing on the lathe will be gone.
lostheplot
thanks haave been thinking about a tumbler..
thanks photobucket
MRsDNF
MRsDNF's picture
You need to build two. No need to guess why. Theres plenty of videos on YouTube to help you. Thanks in advance. Smile
lostheplot
interesting you should say that I watched a 20 min video of a guy building one .then he went and bought one as the one he made was junk
if I make one you will be first inline to receive my rejects.
hopefully i will have the funds to step it up a bit soon..
thanks photobucket
fritz15
fritz15's picture
Last seen: 3 months 5 days ago
Michael (RC-Drehteile) from the taschenlampen-forum made one and it seems to work pretty well. You can see his build and some results in this topic: http://www.taschenlampen-forum.de/threads/zu-faul-zum-selbst-polieren.47...
What seems to be the most important as well as most expensive thing is the abrasive.
lostheplot
looks fairly easy to build thanks fritz..
thanks photobucket
pinkpanda3310
I made up a spindle stop for the lathe. 2 parts – wheel and stop. I printed off a 24 section circle from the net and stuck it to the wheel and scored the wheel for future clarity. I don’t think it’s super strong but should enough for this little lathe and what I do. Also I can’t fit the gear cover while this is attached Crying
JamesB
Last seen: 2 weeks 4 days ago
Thx for the idea , this could come in handy Thumbs Up
MRsDNF
MRsDNF's picture
You made that quick or you had it hidden. Very nice. Thumbs Up
lostheplot
Thanks pp a clamping degree wheel.
Ive ground marks on my chuck about every 15 degrees wich i have used for drilling or running grooves along the side of pieces. It doesnt clamp though.
I see in your picture a rpm sensor laying at the back how is that incorporated.
Is this for the beginning of or compleetion of a project?
thanks photobucket
pinkpanda3310
I don’t have a specific build in mind. I have wanted something like this on my lathe but only got around to it the other day. I initially had the idea of using a bicycle chainring but put it in the too hard basket. I like the simplicity of this idea as well as the increments are not fixed.
The RPM DRO is okay but usually don’t use it when working with aluminium. It’s a simple add-on that can be had fairly cheap You just need to supply your own power and magnet for the hall sensor.
MRsDNF
MRsDNF's picture
Any particular sort of magnet for the hall sensor?
pinkpanda3310
Sorry Moose I missed your post. I used a small neodymium magnet (about 10mm x 2mm) on the back end of the spindle. It was strong enough to hold itself on without being flung off.
But that’s all in the past. I sold the little lathe and bought a slightly bigger one. It doesn’t have electronically variable speed (yet) but so far I haven’t missed it much. I don’t know why but I’m having trouble posting pics tonight so a link to the album will have to suffice https://photos.app.goo.gl/1S5J81STWIDgyewD2 My brother helped me set it up on Saturday. I did a test cut on a piece of aluminium and ended up making a spindle handle out of it. My drill press got pushed off the bench so I need to do a little reorganising. All in all happy with the upgrade.
lostheplot
Nice one pp..Looks a bit like a hare and forbes ?
Hope to see some trick projects soon
thanks photobucket
pinkpanda3310
Yep, Hafco (H are A nd F orbes Co .) AL-250g
Is it a trick project when I make scrap? LOL
lostheplot
https://www.machineryhouse.com.au/l149
This one great addition to the cave.
No such thing as scrap .it was a lesson.
And usually there a piece left over fo later use
Enjoy..pp
thanks photobucket
MRsDNF
MRsDNF's picture
New lathe. I’m lathe envy. Smile When do we see end results? Silly
pinkpanda3310
This was meant to be a result but turned out to be a lesson. Was attempting to make a part for a tail switch, ended up removing too much so the diameter was too small. This lathe removes the material faster. Since I screwed it up I put one knurling wheel on it for shits and giggles.
https://photos.app.goo.gl/pToFacIj0nEhUI4s2
I do have a scratch build in mind. The led I want to use will need to be ordered. Just need to come up with a map (quality blue prints LTP style) and then put some blinkers on so as not to get distracted.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 55 min ago
Hey lads i have been meaning to head to Hare and Forbes to check out a drill press. Would any one know if they are any good? They make there own brand press its either i buy a cheap one like a Ozito or i go more expensive by a bit no middle ground.
Its all the way out west and only open half day Saturday so i am waiting till i am free.
I was also looking at the smaller model Lathe to this model it looks good for the price.
MRsDNF
MRsDNF's picture
You could also look at second hand drill presses Chris. Mine is old but slightly better quality than the cheap Chinese ones on the market now.
