should I buy a hobby charger?
121 posts / 0 new
dekozn
RobertB wrote:
dekozn wrote:
The opus and liitokala both seem to have shortcomings and they are not able to charge to 4.3V.
I don’t know about the liitokala, but the Opus will definitely charge to 4.35v. I cut a circle hole in the bottom of my Opus so I didn’t have to remove the cover every time I wanted to switch it from 4.2v to 4.35
No I don’t have 4.35 cells but 4.30 icr 28 samsung sdi cells.
Idiot proofing something only creates improved idiots.
hellokittyhk
Last seen: 2 years 6 months ago
About the scroll wheel, yes it’s a high quality encoder.
Everything about the build is solid quality, even the IPS is quite nice and all functions are color coded, as well as charge complete screen.
All luxuries but nice to use.
alpg88
Last seen: 2 days 1 hour ago
you can still charge them to 4,2v it will not cause any harm to them, actually it would be even better as far as lifespan, but you will lose about 100-200mah in capacity by not charging them to 100%
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 2 hours ago
I use a Imax B6 for most of my charging needs with a 14X parallel cell holder with built in volt meter for quick voltage testing of cells, just toss it in for a second to get a reading.
It works great and I could not be happier. I do have a cheap nitecore single cell charger for times when I just have a single cell to charge (rare).
http://budgetlightforum.com/node/48703
Jinx
Jinx's picture
I went from B6 to SC-608 and no way would I buy the B6 over the SC. The rotary encoder is easy and feels decent quality.
Texas_Ace
Texas_Ace's picture
It is also almost 3X the price Wink
You can’t beat the bang for the buck on the Imax B6. Flash new firmware to it and it is a very nice unit indeed for $15.
Enderman
Enderman's picture
Last seen: 18 hours 47 min ago
I use an EZ peak 6 amp traxxas charger, although soon I will probably upgrade to a hitec or graupner or something similar.
The graupner is a bit expensive, about $400.
Jinx
Jinx's picture
That is a very fair point, although does that 1/3rd of the price B6 come from a reputable place as a genuine version?
Texas_Ace
Texas_Ace's picture
It is technically a clone but now days I think all B6 are “genuine” since while mine didn’t have any stickers to say it was genuine when I opened it up to flash the firmware it has the genuine hardward layout and needed the genuine firmware flashed for it to work.
In other words “clone” doesn’t really matter, they all work the same. Plus since it is off ebay you know you are 100% protected should there be a problem in the first 3 months.
I have a feeling they are all made on the same assembly line now days in massive bulk and some just get a sticker and some don’t. With the custom firmware mine is very accurate and works as good as I could ask for the price.
The stock firmware sucks because you can’t calibrate it, which I am guessing is on purpose with the clones. The genuine versions seem to have a better factory calibration, I would guess that the “genuine” models get a calibration step before leaving the factory and the clones do not.
hellokittyhk
If you add in a laptop power brick to both it’s only twice as much.
For an extra $20 you get perfect out of the box performance without needing any calibration or firmware. It also has 3 times the output power and is much nicer in general.
Texas_Ace
Texas_Ace's picture
Power brick = $1 at thrift store
hellokittyhk
I guess you are right.
But since the OP mentions large lead acid batteries and parallel charging 6 cells at 1A each the ISDT may save a lot of time.
Plus it is much cooler.
StandardBattery
Last seen: 3 years 1 week ago
I have a B6 Mini and the SC608. I like them both, but the SC608 is very nice design I just have not used it enough to give a strong recommendation on it yet. I like it enough that I’m buying their new model the Q6 Plus. If I was buying today, I’d wait until you can get a Q6 Plus and start with that, learn something about it and then you can make your own informed choice on your second charger if you need one.
Lexel
Lexel's picture
As hobby chargers those 15-40$ ones are good for common RC battery packs, small solar batteries, modded power tool packs or selfbuild e-bike battery
For analysing cylindrical cells there are good 2 and 4 slot chargers, using a RC charger is a lot more time consuming
To fast charge 18650 or 26650 there are some 2A chargers, I would not use a hobby charger
But if you want to get a good calibration or a high power discharge to refresh big lead batteries there are other professional chargers
RobertB
RobertB's picture
Last seen: 7 hours 44 min ago
Wouldn’t hurt them to charge to 4.35 either. Maybe lose a few life cycles out of 400, but whatever
dekozn
I think for now i’ll keep using my friends charger for the lead acid batterie, as I only need it once a year. If i can find an all in 1 solution great but I don’t think that will be possible.
I read the whole tread about isdt 608 and I might go for it (already asked for a code maybe I should ask one for the 620 also). Only thing bout 608is that it cant read Ri of single cells just from packs. Am i correct?
dekozn
Sorry i don t reply to everyone but i m on a phone and it s a pita. But i do apriciate the replies
hellokittyhk
I’m not on the latest firmware but yes seems like you must use the balance tab to get IR estimates.
Caleb
Caleb's picture
Last seen: 3 days 6 hours ago
What is a good charger or other device to test LiIon cells for capacity, internal resistance, and max current under load?
Enderman
Enderman's picture
You test the resistance with a multimeter, and the capacity with a hobby charger that has a discharge function which almost every good one does.
There is no max current under load, unless it’s protected. This is why they sometimes explode.
StandardBattery
Before buying a 608 make sure you look at the new Q6 Plus.
dekozn
I did but I can t seem to find much info on it, not like 608 on the rc forum.
tatasal
Last seen: 2 hours 43 min ago
From the op:
“My budget is around $50 but I wouldn’t mind paying more (even double that) if it’s really worth it.”
I suggest you get a hobby charger (for charging six or more cells as you mentioned, individual cell analyzing, 4.30v and some lead-acid batteries, etc.)
however, this thing can only charge/discharge, in parallel or series more than one cell but of the same capacity always and Mode, which is not optimum for salvaged cells. (major disadvantage of a hobby charger: you can only analyze one cell at any given time)
AND
an Opus BT-C3100 v2.2 (for analyzing salvaged cells 4 at a time without the hassle of cables and holders, charge up 4.35v, do almost everything the hobby charger can do but can do this in any combination of modes(charge/discharge/refresh) and/or cell chemistries at the same time, etc. with individual read-out for each bay.
These two can be had for less than $100..
I have both and couldn’t be more happy. I used to scour around for laptop batts all over town too.
dekozn
That’s what I was planning to do cheers.
How important is Ri measurement for determening a cells’ quality?
tatasal
It’s a nice feature for salvaged cells, of which a majority of them has undergone a long, hard life and would surely have high ir values already. This can be very helpful to salvaged cells for though some of them might charge near 4.2v volts, it cannot tell you the real health of the cell until you try it in high-drain lights (it cannot sustain prolonged turbo mode, sometimes jumping down in mode in less than a minute to the next lower mode , this happens from cells with high Ir)
Edit: After re-reading your op and your succeeding posts, and perhaps the joy of analyzing salvaged cells are your more important concern, a hobby charger has indeed very little appeal because it can only analyze cells singly thereby very time-consuming. (I have gone through this route before)
Perhaps getting two analyzing chargers like the Opus has the better suitability to your needs (plus the added feature of no more wires to connect, no battery cases to buy or fabricate, analyze up to 8 cells at once, etc., etc., though it was a great experience having gone through it all)
dekozn
Thanks for the tip but after reading the test on the opus I m not convinced. Tbh i don’t understand it all to wel but i don’t like the current spikes it takes from the ps. And at $40 i would expect something better. If i would cash out €80 for 2 i think I would be better off going for the mc3000 instead and take my time for testing. But now I m thinking a hobby charger for charging and an opus or liitokala for discharge testing multiple cells at a time. But as I understand it the lii doesn’t do discharge test, it gives capacity after recharge or did I mis something.
Edit: keep in mind that I ll hook em up to a 12v batt most of the time and I don’t know how they will handle the current spikes. These are NOT car batteries which can handle a high initial current draw.
tatasal
dekozn wrote:
Thanks for the tip but after reading the test on the opus I m not convinced. Tbh i don’t understand it all to wel but i don’t like the current spikes it takes from the ps. .
That current spikes was only present in the earliest version of the v2.0.
The 2.0 version had initially inflated ‘Charge’ figures (not in the more important Discharge figures), and was initially ‘cured’ by a higher amperage ps, but a resistor was added to the succeeding versions (middle production run of the 2.0, then the 2.1, that even with the same 12v, 3A since the beginning, good accuracy was attained, up to now with the 2.2 version.
And by the way, I also have the MC3000.
bella-headlight
Last seen: 5 months 4 weeks ago
“ But as I understand it the lii doesn’t do discharge test, it gives capacity after recharge or did I mis something.”
The Liitokala Lii_500 engineer has 2 capacity tests “Fast” & “NOR” (normal).
In “NOR” mode it fully charges the cell, fully discharges it measuring capacity then fully recharges the cell.
In “FAST” mode it discharges the cell then charges it measuring the ma required to fully charge the cell as the capacity.
The “NOR” test is more accurate than the “FAST” test as the “NOR” test is measuring the ma the cell can discharge from fully charged where as the “FAST” test is measuring the ma the cell takes to become fully charged which will be more than the actual ma the cell can discharge.
I have several analysing chargers for cylindrical Li-ions including the Lii-500 & Opus & the Lii-500 is my preferred charger.
Ian
Texas_Ace
Texas_Ace's picture
I have found a far more useful “Internal resistance” test for me to be very simple.
I have a load (in my case an old dust buster that pulls a hefty amount of current). I then put the cells in my cell holders with built in volt meter and connect them to the load.
I watch the voltage and then sort them according to how much voltage they are able to maintain under load. This applies very well to flashlight use.
For example a 30Q might hold 3.5V and HE2 3.6v and a GA something like 3.3v.
Most salvaged cells end up in the 2.6-2.8V range with a few getting close to 3V and a lot under 2.6V (where the volt meter doesn’t work anymore.
Anything over 2.6V I keep around, over 2.8V I put into regular use as long as they do not get warm when charging or self-discharge.
Under 2.6V goes into my “wait and see box”. They all go in fully charged (already tossed the one that got hot during charging). After say 6 months any that are still holding a good charge with minimal self discharge get saved for low drain projects, all the ones that self discharged significantly get recycled.
I have ended up with something like a 10-15% success rate for usable cells, 20% low drain reserve cells and the rest are bad in my experience. Overall if you have to pay much at all for used battery packs, it is best to pass. Now new old stock is great on the other hand.
Now I have been waiting to get a constant load source so I can test the cells a bit more precisely but have not had the funds to get one.
tatasal
Texas_Ace wrote:
sort them according to how much voltage they are able to maintain under load. .
Yes, I do this too, but instead of the cell holders with a volt meter, I use my Zebralight SC600, put in Turbo mode. This light, with a ‘healthy’ cell will go on Turbo for exactly 5 minutes then steps down to High.
Tired cells (meaning high ir) steps down the Zebralight a lot less than 5 minutes, really tired cells just for seconds.
