Olight X9 @ 25k Lumen
153 posts / 0 new
unknown00101
texas shooter wrote:
http://uploads.tapatalk-cdn.com/20170118/e2b336f4111ce32ee82462ee07aeb9f... Some more chum for the water.
http://uploads.tapatalk-cdn.com/20170118/bf177476aba9d9da07899259d12623b...
https://n2a.goexposoftware.com/events/ss17/goExpo/exhibitor/viewExhibito...
$400, dual fans, looks quite a bit different from the one they have on hand though. Man those 6 xhp70’s look really good. Smile
frigate
Last seen: 5 years 7 months ago
Anyone have a pic of the bottom of that light? Also, doesn’t look like it has a lanyard attachment. That’s a beast to have to hold for any significant amount of time.
Bort
Bort's picture
Last seen: 3 hours 41 min ago
But i can buy 25k lumen lights on ebay for $50 Big Smile
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
Lexel
Lexel's picture
You can buy 30k for 20$, just look again
Speed4goal
It would add weight to a light but would it be possible to make one with a water jacket in the head? Like the ww1/ww2 machine gun barrels. Can’t remember how long in between as long as the barrels stayed changed so often they could fire indefinitely. Unless something in the firing mechanism broke. By the time one barrel was to hot the other one would be cooled.
Now we don’t use water cooled but it was effective in the marines the saw gunners had two barrels. And a thick ass cow hide glove to change them. But no one ever changed them during a firefight. Unless they started glowing. You know its hot when the round fires off from the heat alone
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Enderman
Enderman's picture
Unless you are actively cooling the water, putting water in the head will just insulate it more.
Bort
Bort's picture
Indeed, but i do have standards Big Smile
Speed4goal
Was just curious because the machine gun barrels in water jackets arnt actively cooled. And thousands of rounds could be shot before a barrel change. But I guess a steel barrel can take a lot more heat few hundred degrees more then a flashlight can so that makes sense
Enderman
Enderman's picture
Maybe they were just using water as to collect the heat due to it’s high head capacity.
You would need many litres of water though…
Definitely not possible for a small flashlight like this.
leaftye
Last seen: 1 day 13 hours ago
I’m in if it comes with a clip that lets it fit almost completely in a pocket.
The low mode should be lower.
texas shooter
Last seen: 2 hours 24 min ago
Way off topic but you’ll are wondering. A few years ago went to a machine gun shoot at Tiger Valley gun range in Waco Tx. One of the collectors had Model 1910 Maxim Water Cooled Machine Gun. He used a little radiator fluid and lots of water. Belts are 200 rounds long made of canvas with brads. In 7.62×54r hr fired belt after belt, cyclic rate was rather slow. After awhile with the water cap open you could see boiling water erupt out. He’d pour another bottle of water in. Around 0:12 in you can hear the guns slow cyclic rate chugging along https://www.youtube.com/watch?v=c18W5fZ5lRw So it cools with lots of water mass. Properly working they are attached to a water can that pulls water into the jacket.
Texas_Ace
Texas_Ace's picture
Last seen: 11 hours 55 min ago
Interesting video, I have wanted to go to that shoot for some time.
The reason the water cooling works on that gun is not the water itself but the phase change that turns it into steam.
The phase change takes a LOT of energy which is absorbed heat, the steam then carries the heat away from the barrel.
If the water jacket was sealed, well first it would explode from the steam pressure, but it would also not keep the barrel cool, in fact a large hunk of metal would work better, fins would work even better.
Now you could make a water cooled flashlight and it would keep the light at 212F degrees (or 100C) as long as you kept the water jacket full. But adding water and having steam boiling out of it come with their own set of issues.
djozz
djozz's picture
Last seen: 3 days 7 hours ago
It would generate the deepest awe from the bystanders though (combined with 25+ Klumen of course)
Texas_Ace
Texas_Ace's picture
Very true, although if doing this I see no reason to go for anything less then 100k lumens. That should be around 1250-1500 watts of power and would boil water faster then your microwave. Run it off a lipo battery pack and have a 1L water resivor. You should be able to run the light till the battery dies with that, depending on how large of a battery you use.
It could work, it would only weigh 10lb and by the size of a toaster.
Jack Kellar
Jack Kellar's picture
Last seen: 9 hours 4 min ago
That’s acceptable to me. We once lived in a time when this was the norm for a portable flood/spot light, and we survived. Big Smile
frigate
Anyway, back to the thread topic. Someone at SHOT Show please finagle a release date, run-times, and step-downs for this light from their reps. Thanks.
Nvm. Someone posted this on another forum.
http://imgur.com/ZZIdNGP
maukka
maukka's picture
Last seen: 1 month 1 week ago
Hikelite wrote:
How many cells are in the X9, 6pcs like in the previous Olight products from the Intimidator series?
I’d estimate 12 cells (in a 3×4 carrier/pack), since the total output on low is 17500 lumen hours (35 h * 500 lm) and one 3500 mAh 18650 cell can total about 1450 lumen hours with a Cree emitter and an efficient driver.
will34
will34's picture
Last seen: 23 hours 10 min ago
Interesting way to measure output “energy”, like watts hours but with lumens Smile Would be nice to integrate this to flashlight specs to measure total efficiency but this is dependent on which cell is being used.
I feel that 6,000lm mode should be more than 100 minutes, each XHP-70 is putting about just 1,000lm which is in a very high efficiency range.
Hikelite
Last seen: 2 days 20 hours ago
Haven’t see that runtime label before. Yeah it make sense, probably the head is very large for the body to look so thin/normal, almost like the Indimidator series with the 9x, which were 6*18650, reason why I asked.
Now seeing the video of the X9, the dude says 8*18650 3500mAh.
I see a rating of 370meters of throw that means around 34Kcd, so a big flooder, without any exaggeration.
unknown00101
Sounds like those fans really work if it holds 25000lm for 5 minutes before stepdown. That is awesome! I hope I get to hold one of these beasts.
M4D M4X
M4D M4X's picture
Last seen: 1 year 1 month ago
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
KawiBoy1428
KawiBoy1428's picture
Last seen: 22 hours 32 min ago
Oh yeah I’m in… gota get me that X9! Beer
KB1428 “Live Life WOT
DayLighter
DayLighter's picture
Last seen: 5 years 4 months ago
Damn it.. I knew coming back to BLF is bad news for my wallet, just as I thought I got the brightest 4 XH-P70 light, then this one come out Facepalm ,
I’m not surprised it cost $400, if Nitecore TM36 find buyers, this one will too, I’m not surprise if some of us here on BLF willing to spend that kind of money,Althought there’s nothing Budget about it.
I’ll bite if there’s GB with the price around $2xx Big Smile
The only way to do a great work is to love what you do.
frigate
Has anyone seen a lanyard attachment for the X9? Would be nice to sling that over a shoulder than needing one hand dedicated to holding that big honking club of a light.
maukka
maukka's picture
Hikelite wrote:
Haven’t see that runtime label before. Yeah it make sense, probably the head is very large for the body to look so thin/normal, almost like the Indimidator series with the 9x, which were 6*18650, reason why I asked. Now seeing the video of the X9, the dude says 8*18650 3500mAh.
That’s pretty good if they manage 17500 lm*h with 8 cells. I just did a runtime test on the Olight X7 (which has 4 cells) on medium (1120 lumens) to test an XHP70 light and it totaled 7400 lumen hours. This means, if the numbers on the X9 are right, it would be almost 20 % more efficient. I don’t think Olight would do an unregulated light, which would be more efficient, so it has to be something else.
Hikelite
Would imply X7 is not efficient (under 80%), which I doubt is less than 90% efficiency right now, you don’t get massive numbers and good runtimes on that massive Turbo with low efficiency.
djozz
djozz's picture
And the new X7R is 12 klumen, in the same size package..
unknown00101
Integrated Recharge with a cleverly hidden USB port too. The finger grooves on the side of the tube opposite the switch are interesting. I’m not sure if I’ll like that more than the uniform block knurling on the X7.
Lexel
Lexel's picture
If they go for a custom battery they can increase the Wh density by at least 50-60% compared to 18650 cells
adirondackdestroyer
Last seen: 3 months 3 days ago
Honestly, $400 isn’t too bad considering what you’re getting. Also, nothing else on the market that even comes close to this beast, other than the custom stuff being made on CPF, and what is that 40,000 lumen light selling for anyway? Way more than $400 I’m guessing.
