warsun stepless hp50
any thoughts on this light?
https://www.aliexpress.com/item/flashlight/32666844363.html
The batteries might be more like 4500-5200mAh, who knows how good they perform under load
For a bit more money get two Lii 26650A the Lii 200 Charger and a Convoy L6
Wonder why then don’t just put XHP70 on it, it’s a nice looking light, probably built well too just like the rest of Warsuns light… I pretty much own almost all the lights they built except the camping light.
Built is comparable to Nitecore, no cheap lightweight feeling with the exception of their C8 which was meant to be built for somebody else( it was using Samsung LED )
I also saw this light on Ali and I wonder if it’s worth a try. Couldn’t find anything on the web so far…
The head looks ugly to me. Also, for the XHP-50, I think a larger reflector would be nice. It looks like it will be good enough for a general purpose flashlight, but a little larger would give more throw. Certainly, going to a XHP-70 with this size reflector would be a mistake, unless you’re going for a flood light only/mostly. The price looks reasonable for what it is.
Is that even an XHP50? It is a stock picture but still, that appears to be the latticebright version of it.
The LED in the head of light looks like a real, but the image showing comparism to other LED types is not a Cree
It looks like a copy of the XML2 Easy white
It nice looking but for that amount money I would go with a known performer like a Thorfire or Convoy. I’ll gamble $20 on a unknown light from AEx but not much more.
Thanks for posting.
I agree, for that price you can get an L6 that will blow the doors off this light.
I agree with everyone about the L6 comparison. I might bite if it was just the light without the extras for $30
x2… for that $$ I’d rather have the convoy L6, invest in known good cells and a known good charger.
Convoy L6 50.99 with coupon
2 Lii 26650A 11$
Lii 200 charger 6$
so 68$ for a really nice L6 package
2 Lii 26650A for $11 is not avail :frowning:
http://www.gearbest.com/batteries/pp_360841.html?wid=21
they went up in price a little
use Coupon CPF8OFF for 11.30$
Yes I know the CandlePowerForum coupons, shame on me
If the Lii 26650 from GB are the same as the ones I got from BG, then they won’t work in an L6 or any other light that stacks the batteries because they’re flat tops. Luckily, I had ordered the KP 26650 button tops as well, but they took their sweet time getting here.
KuoH
They work well in the L6, just add a solder blob or brass button
Just received my L6 three days ago. I’m using the Soshine 5500mah batteries and they work great with the L6. This flashlight is very impressive for the price. Tested it with the smooth reflector and did not care for the shamrock shadow.
