18650 Dated 2005 - Still has nearly full capacity
19 posts / 0 new
Zebretta
Last seen: 10 months 3 weeks ago
I found a TNL-ITR18650-2200 3.7v battery in one of my old tool boxes with a date stamp of 12.12.05
IIRC, it was inside a rechargeable device I disassembled that had broken. I forget exactly what it was in.
I’m amazed that at 12 years old it still has a discharge test capacity of 2100mAh
How can that be?
Tinderbox UK
Tinderbox UK's picture
I watched an utube video on extending the cycle count on li-ion cells, there is supposedly at least 7 different chemicals that can be added to the basic li-ion mix, and what ones are used can make the difference between 200 cycles to 2000 cycles and these recipients are closely guarded secrets.
They help to reduce damage from excess heat while charging/discharging or slow down the process where the anode/cathode gets blocked over time reducing the capacity.
I have some bluetooth headphones with li-ion built in that i have had for years and they still last a long time on a single charge.
John.
Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
X0R
X0R's picture
Last seen: 3 weeks 1 day ago
Recently i disassemble battery of old samsung laptop (bought in 2004) and got 6× 18650 cells 2200Mah.
Measured capacity is between 1930 – 1990 mah, near 87-90% of initial capacity
Zebretta
X0R wrote:
Recently i disassemble battery of old samsung laptop (bought in 2004) and got 6× 18650 cells 2200Mah. Measured capacity is between 1930 – 1990 mah, near 87-90% of initial capacity
Right?
Now I cringe when I think of all the laptop batteries I tossed with broken laptops : – (
X0R
X0R's picture
I used ZB206+ v1.3 Battery Tester from Fasttech
Zebretta
ZB206 review
Bort
Bort's picture
Last seen: 16 min 17 sec ago
What is its internal resistance?
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
X0R
X0R's picture
I haven’t 4-wire holder, to measure resistance.
Zebretta
Good question. I’ll check as soon as my hobby charger is available
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 4 weeks ago
There are plenty of appropriate ways to use them, as power outage back up cells for an SRK is one that comes to mind. That higher internal resistance can show benefits in terms of shelf storage. Just keep them in a safe place. I wouldn’t store new cells fully charged but don’t feel as protective of older cells, just concern over the higher risks they come with.
Scott
J-Dub74
J-Dub74's picture
Last seen: 3 hours 25 min ago
I don’t have a fancy charger or anything to test capacity but I’ve pulled cells out of old laptop battery packs that were still near 4.2v after sitting in a basement for 12 years and they probably sat for a few years before they made it to the basement. Many of the cells that old will be throw-aways but it amazes me that there are still good cells in those really old packs. The old Dell packs in particular have given me plenty of usable 18650s.
Zebretta
Measured with my Turnigy Accucell 6 the IR = 137milliohms
Zebretta
gauss163 wrote:
Zebretta wrote:
[…] I’m amazed that at 12 years old it still has a discharge test capacity of 2100mAh
At low discharge current? Typically old cells will have very high IR so they can only deliver decent capacity at very low rates. Older laptops with inefficient CPUs required higher currents, so the batteries typically were discarded when they could not deliver useful capacity at those higher rates. But they still might have decent capacity for medium-low current devices.
That makes sense. So what you’re saying is that while I measured 2000 mAh capacity, it will only deliver that at low discharge rates?
In fact, the discharge rate that I used WAS very low…like 300 milliamps.
So this battery would be good for something with a very low drain (say, under 500mA) but nothing high drain say over 500mA?
Again, that makes perfect sense to me.
Bort
Bort's picture
I don’t know what new batteries are but my 4 year old UR18650FM are about 50 milliohms on my Dragon VP4
Zebretta
This same battery showed a significantly lower IR on my other hobby charger.
Seems to me you have to do the “real” IR test to get an idea of the real IR
Chargers don’t seem to be accurate on that measurement imo
snakebite
snakebite's picture
Last seen: 6 days 8 hours ago
not only inaccurate but repeatability is poor.
i use a dick smith esr to test.
its meant for capacitors but is fine for batteries if you didnt install the protection diodes to protect it against charged caps.
LatticeBlight
LatticeBlight's picture
Last seen: 5 years 6 months ago
Have some dell pack and even older batteries that still do over 2000mah and have ok IR. Both panasonics and LGs. Using them for years now too.
I have: https://anatekinstruments.com/products/fully-assembled-anatek-blue-esr-m... but I don’t think it can measure cells. Lii-500 gives good enough readings for pass/fail.
snakebite
snakebite's picture
thats the new version.
mine is from 15 years back and was a kit.
and it does fine testing ir/esr of batteries.
in fact it tests exactly the way most li-ion mfr’s do.
Zebretta
Well,
I tested this 12 year old battery again today and put it against a discharge current of 500mA and it had 2028mAh capacity (rated at 2200mAh) so this 18650 dated Dec 12, 2005 still has 92% of it’s original claimed capacity and is that is at least under a 500mA load. Not bad Smile
I will probably test it under a 1A load next just to see.
Do you think you could get 12 years out of any 18650 you purchase today?
