Test/review of Charger Olight UC
12 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 17 hours ago
Charger Olight UC
DSC_7721
Olight has made a very simple charger with no slots, but only magnets for battery connections. This is nothing new, except Olight has improved it significantly: Both LiIon and NiMH and no polarity.
DSC_7720
DSC_7718
The pack is very simple and contains only the charger.
DSC_7722
DSC_7723
The clear plastic around the wire has a red and green led behind it. This means it will be read while charging and green when done. The led will flash slowly red when not connection to any battery (Both with open and shorted connections).
The leds are fairly weak.
DSC_7725
In this block the wire split into two, one for each end of the battery.
DSC_7726
The two magnets.
DSC_7724
Here the magnets are connected to a battery.
supportedBatteryTypes
supportedBatterySizes
DSC_7728
DSC_7727
DSC_7729
DSC_7730
Only limit on battery size is charge current.
The current is a bit high for small cells, but some 14500 and 16340 will be acceptable because the current drops when voltage increase.
Measurements
  • Will discharge a LiIon battery with 1.1mA or 0.7mA (Depending on direction) when not powered
  • Will discharge a NiMH battery with 0.3mA or 0.2mA (Depending on direction) when not powered
  • Will charge a LiIon with 0.1mA with 4mA pulses when charging is finished.
  • Below 1 volt it will charge/discharge with 4mA
  • Between 1V and 1.7V the charger assumes NiMH
  • Between 1.7V and 3V it assumes LiIon and it will slow charge (0.3A)
  • Above 3V it will charge with full current
  • The charger will not restart if the voltage drops.
Olight%20UC%20%28SA18650-33%29
The charger uses CC/CV charging, but cannot deliver full current when the battery voltage is above 3.9V, termination is at 100mA.
This is a good charge curve.
Olight%20UC%20%28SA18650-26%29
This cell has higher charge voltage and the current will be a bit below maximum current.
Olight%20UC%20%28PA18650-31%29
Works fine.
Olight%20UC%20%28BE18650-26%29
This cell is old, again the charge voltage is high and the current drops a bit.
Olight%20UC%20%28KP14500-08%29
Olight%20UC%20%28AW18350-IMR%29
On paper the charger current is too high for these cells, but in praxis it is not that bad. A new cell would be charged with too high current at the start of charge and this is the time where the battery can best tolerate it.
Olight%20UC%200.5ohm%20%28SA18650-33%29
Here I have added a 0.5ohm resistor in series with the usb power to simulate a long cable or weak usb charger. The charger do not handle that well, it terminates at 4.1V and 400mA.
Temp3984
M1: 33,2°C, M2: 25,7°C, HS1: 43,0°C
The charger get a bit warm and the battery stays cool.
PowerOnLiIon
It takes a few second for the charger to initialize a LiIon charge.
NiMH batteries
Olight%20UC%20%28eneloop%29
The charger uses voltage detection for NiMH batteries and not any significant top-off or trickle charge. This means the batteries will be slightly below a full charge.
The charge current for NiMH is 500mA
Olight%20UC%20%28eneloopPro%29
Olight%20UC%20%28powerex%29
The eneloopPro and powerex are handled fine.
Olight%20UC%20%28eneloopXX%29
The charger cannot handle my old worn out eneloopXX (This battery is not really useable anymore).
Olight%20UC%20%28eneloopAAA%29
The AAA cell is handled fine.
Olight%20UC%20full%20%28eneloop%29
With voltage termination the charger is fairly fast at detecting a full cell
Temp3975
M1: 35,7°C, M2: 26,0°C, HS1: 47,5°C
The charger get a bit warm, but the battery stays cool.
PowerOnNiMH2
The power on sequence is a bit long when charging NiMH.
PowerOnNiMH
The charger is fairly fast to get into the precharge phase, but there are some strange pulses.
InitialPulseNiMH
I do not know the reason for these pulses, they do both look the same. They do not prevent the charger from trying to charge alkaline cells.
PulsingNiMH
As usual for a NiMH the current will be turned off when checking voltage.
Conclusion
This is a very compact usb charger and it is fairly useful for many cells, it works best with a good stable usb power.
Because the charger is isolated from the cells it will never heat them. I like the automatic polarity, but I would have like the charge indication leds to be a lot brighter.
I will call it a good charger and the best I have seen of this type (usb with magnetic clamps).
Notes
MILSPEC
thank you for the review. Amazing charger for the next vacation or business trip.
will34
will34's picture
Last seen: 2 hours 3 min ago
Thanks for the review, was waiting for this!
Seems like a great travel charger, and would be even better if charge rate was a bit higher.
HKJ
HKJ's picture
Charge rate can always be discussed. Usb has some current limits:
0.5A Standard current from a computer
0.9A Current from a computer with usb 3
1A Typical older charger or simple phone chargers.
2A or more: Many new chargers.
Looking at the table I believe 0.8A is a nice value.
Another way to go would be a switch on the charger that could select between 0.5A and 1.5A, it would make the charger more complicated, but also more versatile and faster (To really use 1.5A the circuit and cable would have to be optimized a bit).
GrayEd61
Last seen: 4 years 4 months ago
Thank you HKJ
This looks like something that would go well into a “bug out bag”.
-X3-
-X3-'s picture
Last seen: 2 days 19 hours ago
Anyone knows where to buy it for less than 10$ ?
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Lopan
Last seen: 6 hours 12 min ago
Fasttech for $ 9.99
And I think you can use the code BLF to save 5%
Amazon might be an option. In germany it’s 9,99€ including shipping for prime members. In France it’s 9,99€ + 1,99€ for shipping.
-X3-
-X3-'s picture
Lopan wrote:
Fasttech for $ 9.99
Thanks for the info, I saw it on Amazon but found it on ebay.fr without shipping fees.
So I bought it for 9,99€ free shipping and it comes from France so might be here in a few days.
Barkuti
Barkuti's picture
Last seen: 7 hours 31 min ago
I'm impressed. If not for the cable lenght, I'd have said “What the h1ll are those USB headphones?”. LoL!
Cheers Party
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
MascaratumB
MascaratumB's picture
Last seen: 3 hours 21 min ago
Any clue on how good can be this charger for a 21700 5000mAh cell?
I mean, for an “emergency” or travel situation, as example.
Or are there any better solutions in this format out there?
abgx1
I am using it exatly for this purpose, and its works, its not very fast, but battery will be charged without any problems
MascaratumB
Thank you very much for your input Wink
I’ve been thinking about getting one of these, but was in the doubt because of the high capacity cells!
I think I will get one now Wink
