Tiny high powered led for lighting sculpture - any ideas?
36 posts / 0 new
Joshk
Joshk's picture
Last seen: 38 min 25 sec ago
Here you go:
CREE XP-L HI V3 3C LED on Noctigon 16mm MCPCB
Now you need a heat-sink though since you don’t have a flashlight tube…
Malarky
Last seen: 3 years 10 months ago
Thanks for the comment.
That or the XPL – HI seem like 2 pretty good options to look in to. 700 lumen from such a small size sounds phenomenal.
When this thing is made on has good heatsinking, is there anything that you think might cause problems if I put it into an IP67 enclosure? Could it overheat and cause me problems?
born to dabble.
Lexel
Lexel's picture
Last seen: 3 weeks 3 days ago
I am from Germany I could do it for you.
I would go away from flashlight and build the star on a heatsink and seal the solder joints with acryl or epoxy, then it is IP68, no need to add a case with AR glass and heat problems.
Pretty much the star mounted on a heatsink,
cables to the PSU and buck driver that are in a case.
It is easy to get 700-1000 lumens from a XPL HI on DTP star.
Malarky
Cheers Lexel. Have sent PM.
I’m off for now.
Cheers all. What an amazing forum! Smile
born to dabble.
Lexel
Lexel's picture
Ok a lot was going on by PMs and Emails
I will compress it a little bit
concept pictures
http://www.metronixlaser.de/bilder/flashlight/Kenfig%20doodles.pdf
hes quite an very interesting artist
check here: https://goo.gl/photos/Bbi8jZ3ba6XALyCFA
I suck on concepts pictures!
parts for his custom light sculpture:
12V 1.25A power supply
5A buck converters
waterproof boxes for powering the LEDs
!https://ae01.alicdn.com/kf/HTB1NqKlOVXXXXbVXFXXq6xXFXXXa/Kunststoff-Wass... !
nylon starin relief for cables
heat sinks 100×60×11mm
tunable resistors for brightness regulation
XPL HI V3-3C on noctigon DTP Star
28mm AR coated glass
5m cable for conection LED to power box
small heatsings for buck regulator
arctic silver ceramique 2 heatpaste
first tests with the buck converter
to get the brightness adjustment realized
test with different LEDs
result of XPL-Hi
first parts arrived today.
sent him also some pics of my bengal cats
