Finally the XHP70.2 emerges!
347 posts / 0 new
Thom2022
An inline resistor is not a bad shout. So quick maths: if your drawing 20A then assuming batteries are powering at 8.4v then total circuit resistance is ~0.42ohm. To get ~13A total resistance should be ~0.64ohms meaning you need to add a resistance value of ~0.22ohm.
Just an idiot with a soldering iron.
Texas_Ace
Texas_Ace's picture
Last seen: 7 hours 47 min ago
Lexel wrote:
instead using thin wires it may be useful to add a resistor to limit the current
!http://www.mouser.de/images/ohmite/lrg/TNP10_Series_DSL.JPG!
The issue is that the resistor could need to dissipate as much as 5-10W. I don’t know of many that can do that and fit inside the flashlight body. The ones that do exist are expensive. Wire on the other hand is cheap and easy and can dissipate a fair amount of heat if it is silicone and long enough.
The best option is to use a regulated driver obviously. The stock L6 driver should be able to work as long as you don’t want more then 7-8A.
Tom E
Tom E's picture
Wow! Nah, I don't believe in limits or thin wires smile.
Ok, here's some details. It's a TA Convoy L6 triple channel using a SIR800DP, 20 AWG wires, 20 AWG spring bypass. It's got the Simon SMO reflector.
On 2 LK 5000's at 4.17V, I got 18.0 amps on the clamp meter.
Lumens: 8,940 @start, 8,090 @30 secs. Throw at 5m: 186 kcd (862 meters)
There is no black hole, well under 1 foot to a white wall there is, but nothing further away than 1 foot. It's got the usual new LED yellow around the hot spot. Could be the 3B tint, or just the nature of the LED's with our typical reflector designs.
The thing gets hot, maybe the hottest I ever felt after 30 secs. I didn't let it cool down much before getting the throw readings, and it was getting darn uncomfortable holding it for the 30-40 secs or so.
Is this thing usable? Well for a few moments, yes. I had two EVVA unprotected 4000K cells I tried. They were at 4.05V and I got about 11A on the clamp meter, and maybe about 6,800 lumens at start.
Surprisingly, ramping seemed to be working ok, but as has been pointed out, there's not many steps in the ramping table at the high levels, so it jumps bright fairly quick at the end.
Lexel
Lexel's picture
Last seen: 2 years 4 weeks ago
That resistor is compact it is build to be mounted on a heatsink with a screw
Tom E
Tom E's picture
Just tried it outside - too much power to point around the block, so just hit top of telephone poles and tree tops, and down on the lawn. Even outdoors at 68F it's hot quick. Funny, it seems so much brighter than a 9,000 lumens flooder like the MT03. Even off the ceiling, the hot spot is extremely bright, or shining it down on grass, it's blinding.
Texas_Ace
Texas_Ace's picture
Impressive, since it seems to survive at that current you could limit the power by simply adjusting the max pwm in the firmware (ideal would be to add some voltage compensation as was discussed before).
Tom E
Tom E's picture
I was think'n, well hoping, these new LED's can handle the amps, but I think it's a nice "feature" the heat keeps you from running it too long anyway. I just got an MT03 and measured it at 9,010 lumens @30 secs, but even though the head diameters are about the same, the MT03 seems to handle the heat pretty well. Of course it's got to be more efficient because of the 3 XHP70's - guess that's the big difference. I'm not sure what the MT03 does in amps though.
KawiBoy1428
KawiBoy1428's picture
Last seen: 14 hours 52 min ago
XHP70.2 P2-1A 17.15amps 8.2v with a BLF-FETDDSIR800 20awg driver spring bypass with 1.2’‘ long 20awg Leads 2 ×26650 Basens in a Jaxman X6 Hunter with a L6 smooth reflector.
8000+ lumens Tom? It’s a really Big Bright Floody Freaking BEAM!! Steve Thumbs Up
I Wonder How Long it will live at 17-18 amps!!! Big Smile
KB1428 “Live Life WOT
Speed4goal
Last seen: 2 years 3 weeks ago
What do your neighbors think about shining all those massive lights in that direction for your beamshots?
I think mine are use to it by now, only had one person at the end of the road say enough with the flashlight. And I wasn’t even shining it towards his house. The next door neighbor doesn’t care he knows I’m keeping the raccoons away from his rabbit pen. I think k the people across the street think I’m crazy probably but they have never said anything. She’s always outside smoking or talking in the phone so they definitely see them.
I was just curious I see beam shots from members in the area they have and wonder if their neighbors ever say anything
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
KawiBoy1428
My neighbors, never a peep, not even when I fire up one of the drag bikes and do burn outs in the middle of the night, but I would only do that on weekends Friday/Saturday nights, most of them would be right there, drinking my beer, my neighbors are COOL! Wink
The Miller
The Miller's picture
heheh you need cool neighbors with the wicked mods you do kawi Big Smile
JasonWW
JasonWW's picture
Last seen: 4 days 19 hours ago
8 and 9 thousand lumens! Woo boy, that’s sounds good to me.
I didn’t care for the xhp50.2 I tried in my L6 at 9-10 amps or so. It wasn’t any brighter than the sliced dome xhp70 at 7 amps. I think the 5000k color temp was not to my liking, as well.
But a P2 bin in 6000k sounds like something I need to try.
Tom E
Tom E's picture
With the amp readings, my first measurement was 17.25 A, but the 2nd readings was actually higher at 18 A. I attributed it to the hold I had on the wire to the top edge of the battery tube (14 AWG I think), or some how the amps go up with the heat, not sure.
KawiBoy1428
I have seen just over 22amps with the SD75 board on the sink directly hooked up to a 2S2P battery carrier with 4 VTC5a’s, and it still works, so a 2S set up might be the way to go, until somebody tests it, no sense running it past it’s useful out put. The heat this thing throws off is amazing, the host might be getting hot fast, wonder how hot the board is getting?
Notice I kapton taped the heck out of it, wasn’t worried about shorting off the reflector, machined the reflector so I have plenty of clearance, just that red wire de-soldering itself Facepalm
Better to error on the side of safety, I guess, it is a beast of an emitter that’s for sure!
It is also the only thing stopping me (2S2P carrier) from putting this emitter in this thing, Beast Light needs a Beast emitter! Sad
Wieselflinkpro
Wieselflinkpro's picture
Is someone able to mod a Acebeam K60 with driver mod and XHP70.2.
And has someone a power supply witH 20A to test the LED and measure Lumens.
Texas_Ace
Texas_Ace's picture
I have been wanting to test the 50.2 and 70.2 for awhile but just have not been able to free up the funds to get my hands on them. I think djozz mentioned he was thinking about testing them, don’t remember if he is or not though.
KawiBoy1428
I got bored so I did a few non scientific/ professional tests.Checked a few 2S 26650 and 20700 battery set’s in the JX6Hunter 70.2 P2-1A
All straight off the charger at 4.20v
KP26650 15.15a
Basen I 16.20a
PEfest 4200 16.65a
Basen II 16.70a
Sanyo 2700A 19.70a
IJoy 2700 20.20a
Topped them off again, and I measured LUX at 2M just to see “IF” it made a difference in LUX readings, just to check the out put in my light with bypassed tail cap. And to see if LUX topped out in between? It didn’t, not from my very rough checks!
KP’s measured 38,000lux
Basen II/ Purple Efest4200’s 44,400lux
IJoy’s measured 51,500lux
Even at 20 amps the LED did not turn blue, pretty amazing! Facepalm
Texas_Ace
Texas_Ace's picture
20 amps is basically the same as 10 amps to an XP-L2, which from my own testing, it can handle.
So the real issue is heat, at over 125W worth of heat, it is pretty insane for almost any host. Particularly for the amount of light you get. An XHP70 can make around 6500-7000 lumens and only needs about 80W to do it.
The real benefit is the higher efficiency at lower outputs. It should work great with buck drivers, although they will most likely need to be run in 12V mode to keep the amperage down. For example the GT driver should work great with the xhp70.2 in 12V mode (or 50.2 for that matter)
Tom E
Tom E's picture
The "lux" numbers are all directly off the meter at 2m? So x4 for converting to candela, so 44,400 lux is 178 kcd. Think that's about right compared to mine. You have an L6 SMO reflector in that light, I believe what you said earlier?
This is good cause it indicates at 18A to 20A, throw, and therefore lumens, is still rising, at least initially assuming you are taking readings at 30 secs or so.
Enderman
Enderman's picture
KP26650 15.15a
Basen I 16.20a
PEfest 4200 16.65a
Basen II 16.70a
Sanyo 2700A 19.70a
IJoy 2700 20.20a
Thanks for the info!
I assume this was in a flashlight host, right? No big heatsink and fan cooling?
If so, these lux measurements you took were probably within a few seconds of turning it on right?
Unless you had the LED cooled extremely well, the output will drop dramatically the hotter it gets, because a flashlight host sucks for dissipating heat.
Most people wait for the output and heat to stabilize before recording the numbers, which usually takes ~30sec.
KawiBoy1428
Tom E wrote:
The “lux” numbers are all directly off the meter at 2m? So x4 for converting to candela, so 44,400 lux is 178 kcd. Think that’s about right compared to mine. You have an L6 SMO reflector in that light, I believe what you said earlier?
Correct Tom, on all counts, Same light I posted. Reflector on the board no centering ring, the L6 smooth reflector center’s up nicely in the X6.
I was just looking to see where this LED might plane or stabilize. I moved it around till I got the best/highest LUX reading, just off center, then held it there, plus what it took for my eyes to adjust to the initial blast at 2m, to see the meter, then my normal count of 10 seconds more or less? I wasn’t concerned with ANSI testing, just give it some time to stabilize.
Bottom Line from what I witnessed, is the emitter IS making more Lumens/LUX at 20AMPS then at 15amps. Regardless of anything else, I’m not that Highly Testicle when it comes to flashlights, I’m happy as hell if it turns on! Big Smile
That is T/A’s and Djozz’s GIG! Thumbs Up
I did change the reflector out to the L6 OP reflector tonight and the beam is rather quite nice, very smooth, and floody, I personally prefer it over the smooth.
JasonWW
JasonWW's picture
It sounds like a 26mm or 30mm copper DTP star combined with machining the flashlight head to match might be a good option with this emitter.
Also Narsil, so you can ramp it down just slightly for more practical usage and longer run times (thermally limited).
KawiBoy1428
KP26650 15.15a
Basen I 16.20a
PEfest 4200 16.65a
Basen II 16.70a
Sanyo 2700A 19.70a
IJoy 2700 20.20a
Your welcome! Thumbs Up
Yep, the X6 has a brass pill, I bored it out and pressed a copper plug into it, machine the surface flat and then soldered the 32mm Maxtoch DTP board on it. Not much room for the driver. Soldered up the threads on the pill and used the host to re-cut them, it’s a pretty tight pitch now.
I’m not most people and I could give less then a shit what anybody else thinks, my test were not for techies,pros or gurus, just for my own experience and out of boredom! So I thought I would post it, that’s all. It’s just a hobby to me! And it sure beats the hell out of doing nothing, at all! Wink
Texas_Ace
Texas_Ace's picture
Hey, the test was a heck of a lot better then anything else that has been posted so far and I don’t think djozz has one to test and I know I don’t so most likely the best results we will have for awhile.
Interestingly the results are virtually exactly what you would expect from 4x XP-L2’s put together from my own tests. They also peaked at 10A (which is what each die is getting in the XHP70.2 @ 20A).
Enderman
Enderman's picture
KawiBoy1428 wrote:
p. I’m not most people and I could give less then a shit what anybody else thinks, my test were not for techies,pros or gurus, just for my own experience and out of boredom! So I thought I would post it, that’s all. It’s just a hobby to me! And it sure beats the hell out of doing nothing, at all! Wink
I wasn’t saying that those tests should have been made with proper testing standards for everyone to see.
I was just wondering how long it was on when you took the measurement and what cooling you used so that I could guesstimate how well it would perform for me if I used a big heatsink.
The_Driver
The_Driver's picture
Last seen: 2 weeks 1 day ago
Something to think about:
Every LED has a thermal resistance, the XHP-70.2 has an Rth of 0.9°C/W, so maybe 1°C/W to the solder joint. This means that for every Watt of heat converted power the LED is 1°C hotter compared to the solder joint. In addition to this you have the heat path to the outside of the flashlight.
At 20A and maybe a Vf of 7.5V (I’m guessing here) the LED gets 150W! EDIT: of which around ~80% is converted to heat (see posts below).
So the LED will be 120°C hotter than the the solder joint on the PCB is.
So if your lights are too hot to hold (pain threshold is at 60°C), the LED is at least 170°C hot.
At this temperature, which is outside the range of the datasheet, the LED loses around 25% of it’s output. Basically a big part of it’s high efficiency is wasted at this point.
EasyB
Last seen: 1 month 4 weeks ago
Every LED has a thermal resistance, the XHP-70.2 has an Rth of 0.9°C/W, so maybe 1°C/W to the solder joint. This means that for every Watt of consumed power the LED is 1°C hotter compared to the solder joint. In addition to this you have the heat path to the outside of the flashlight.
So the LED will be 150°C hotter than the the solder joint on the PCB is.
So if your lights are too hot to hold (pain threshold is at 60°C), the LED is at least 200°C hot.
A this temperature, which is outside the range of the datasheet, the LED loses around 30% of it’s output. Basically a big part of it’s high efficiency is wasted at this point.
The relevant power when considering the thermal resistance is the thermal power. Some of the input power leaves as light and so doesn’t contribute to the heating of the die. So only roughly 50-80% of the input power heats the die.
The_Driver
Right, forgot about that.
At these power levels it might be 20%.
So it’s “only” 120°C more.
I have corrected my post.
djozz
djozz's picture
Last seen: 1 day 1 hour ago
I think I have one on order from KD but it has not arrived. But I’m not sure anymore now, I have never made an account there so I can not see an order history, and KD does not send order confirmation emails with details of the items.
If it arrives after all I will do a test, but my power supply does not go over 20A and, as I read above in Kawiboy’s posts, that that is not enough, it is quite a performer!! Big Smile
Texas_Ace
Texas_Ace's picture
If you have a 12V mcpcb then you can run it in 12V mode which would only need 10A to max it out.
Although while it may survive that high I can guess that running it above ~15A is going to be a matter of quickly diminishing returns to the point of silliness when you factor in the heat it will produce.
