Review: 5-Mode UltraFire Cree XM-L/T6 Warm White from Manafont
42 posts / 0 new
Foy
Foy's picture
Last seen: 6 years 7 months ago
How Many Amps is Too Many Amps?
I finally decided to try a warm XM-L to see if the good ole' days yellow was really that good.
Bottom line:  It's a fun novelty but I don't think I'll be ordering another anytime soon.  I do like the colors appearing less aseptic than a normal LED makes things look but when I used it under a car at work, it didn't seem to reach into the nooks and crannies as well.  With my job, that's a deal killer even before I measured tail cap draw.
This one is a no go, folks.
UltraFire Cree T6 Warm White 5-Mode from Manafont
http://www.manafont.com/product_info.php/ultrafire-cree-t6-warm-white-5mode-memory-led-dropin-module-42v-max-p-7747
$16.00
ordered:   10-5-11
received: 10-29-11
4.2 volt max
5-mode: high, medium, low, fast strobe, SOS
mode memory
OP reflector
tail cap measurements:  readings taken in a 2011 version Solarforce L2 with a protected Solarforce 2400 18650 battery
high -       5.20 at start-up, settled down to about 5.0 amps
medium - 1.45
low -         .47
Being a relative beginer, I have to ask; just how much farking current is too dang much?  I'm as opened minded as the next guy but if I'm going to invest something north of 5 amps, I need some big time wow factor.  I haven't done any run-time test but my guess is; it ain't gonna be pretty.
They seem to have put this one together pretty good, I suppose.  It has worked every time and I've experienced no failure so far.
This black PCB cover was glued on and I cracked it on one side getting it off.  Just another hit Foy takes for the team.
Solder, emitter . . . no wow factor here.
This is the same L2/Solarforce battery setup taken at 1/4 second shutter speed @f2.8 at the relocated Foybezels research center.
This is the same L2 with a 3-mode UltraFire XM-L and unprotected Panasonic 2350.
Here they are side by side.  The 3-mode T6 we all know and love blows this warm white off the map.
So, in conclusion; this UltraFire warm white draws 2 more amps than the popular 3-mode XM-L while delivering less light.
WOW.
signmeupFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
Edited by: sb56637 on 08/26/2014 - 17:27
Langcjl
Langcjl's picture
Last seen: 3 years 8 months ago
I have/had this dropin. I like the color a lot and use it all the time while poking around in the back yard chasing dogs. I say I had this dropin because it burned up a solarforce L2i switch pretty quickly and I changed the driver to something much more sensible. Now it's great and I like it. It is really yellow though, probably a bit too much.
Piers said " ....but who wants enough light, when you have the option for far too much "
Foy
Foy's picture
Ohhh . . . so yours was drawing high current too.  So it's not just mine.  Interesting.  How long do I have before I loose a switch?
Foy
                      &nbsp
Langcjl
Langcjl's picture
Not long probably. There have been other reports of dangerously high current.
Foy
Foy's picture
After speaking to a trusted member here via PM, I became suspicious that perhaps my $40 DMM  reads high, especially since I got way high readings from my 980L too.  Then I remembered that when E1320 was fixing my F15, he said I was really going to be impressed with the beam at 3.5 amps on high.  When I got the light back it pulled 3.47 amps.  It may be a fluke that my Extech measured the same as E's Fluke, but I'm inclined to think my ugly orange DMM is right on the money.
                      &nbsp
janko.hrasko
janko.hrasko's picture
Last seen: 9 months 2 weeks ago
you should really replace the driver with 8amc one
and are these photos with the same white balance? it should be warmer, almost as an incan
2100
Last seen: 3 years 4 weeks ago
Foy, it is expected that WW gives you approx 25-30% less output as compared to CW.  Due to the phospor coating taking away the blues.
jacktheclipper
jacktheclipper's picture
Last seen: 4 hours 4 min ago
Thanks for the review , Foy .
What I do
Langcjl
Langcjl's picture
Not a great beamshot, just a quick phone snap of the WW dropin and an UF 3 mode. The UF manafont dropin was not on high as can be seen by the PWM. This pretty accurately compares color difference, dont use this to compare intensity.
kragmutt
From Langcjl's photo, that looks like a much more pleasing tint than the 3-mode.
tbenedict
Sounds like this one would be a good candidate for a 1 mode driver swap to go in a 6P to balance output/runtime.
Vectrex
Vectrex's picture
Last seen: 10 months 3 weeks ago
Isn't this a suitable driver replacement?
okwchin
okwchin's picture
Last seen: 7 months 4 days ago
it IS a warm white right? So its likely to represent a big hit in light output.
Putting it on a scale, Warm whites lose 25-40% output, while neutral whites lose 5-15% output. Our beloved 4C XP-Gs only really see a 5-10% hit in output, but the tint more than compensates, while warm whites really start to look alot dimmer.
And 5A draw is just crazy... Way too crazy. I wouldnt be buying one becasue its warm, and because its suicide.
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
brted
brted's picture
Last seen: 1 week 1 day ago
Now I want one of those brown and blue dogs . . .
5 amps is a pretty crazy current draw, but I think a lot of lights probably are direct drive on high and the only thing controlling the current is the resistance of the battery, voltage of the battery under load, resistance in the tailcap, etc.
old4570
Last seen: 3 weeks 4 days ago
5A   would not wish to part with that driver would you ?  Trade maybe ...  ?
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Foy
Foy's picture
I was seriously questioning my DMM but I told E1320 to give my F15 3.50 amps on high.  That's what he did and when I got the light, this is what I measured with a fesh charged Solarforce 2400:
This is my 980L with the same SF 2400:
And, you can tell by the tint reflection on the bottom of the keyboard, this is the warm white and same SF 2400 in an L2:
Mind you, this is what it settles down to.  Fresh off the charger on initial start-up I got 5.20.
I don't mean to belabor this but some time ago (before my period of absense) a person I won't name PM'd me saying he did not believe my 980L was really pulling over 4 amps.  This was after I pointed him to the thread with E1320's picture of his 980L in front of a Fluke pulling 4.somethinginsane.  If anything, my Extech reads a little low and that's probably because the leads on a cheapo DMM are usually where they start cutting manufacturing costs. (mine are already bending)
On the internet, all you have sometimes is your word and my credibility here is something I get touchy about, I'll admit.  Erik knows my F15 did 3.50 when he built it so, I'm feeling a little better about Mr. Extech.
I'm also going to buy a Fluke here in the next few weeks.
Foy
                      &nbsp
Foy
Foy's picture
old4570 -
You really want this driver?
Foy
                      &nbsp
old4570
Foy , I would love to have that driver , I have a SST 50 that might enjoy it immensely , as well my Dual XM-L U2 P60 drop in which is in need of more current ..
As Tim the Toolman used to say , More Power !
I just wish those Ultrafire Drivers were available for the DIY crowd ...
I just wonder about efficiency ?  , even so , it sounds BOSS !
Have you checked for sag on the emitter ?
I have some new drivers if you want to trade , 8x7135 , and another that's 5 mode  from KD [ XM_L , MC-E , SSC P7 ] I think its the one they [ KD ] Rate 2A , but the one I have does more like 2.4A  ..  or 4x7135  [ if mem serves , I should have 2 left ] or maybe just some PP
Foy
Foy's picture
Tell me how to test for sag and I'll give it a try.  Leme get back to you on the driver.
I'm going to turn it on and see how long before it kills a battery.
Foy
                      &nbsp
old4570
Foy
Light meter + light box ...
Yep , need a light meter , then make a light box , turn the light on to measure Lux , and if there is sag , the output will drop [ light meter read out ]
My other 3 mode pulls 3.8A , but I potted the emitter and glued the reflector down to the emitter base for another thermal path .
No LEGO on that one any more .
Hmmm , some SLR cameras have light meters , and doing a ceiling bounce , with the camera light meter might work [ never done it myself ]
Its very hard to detect by eye , as when the light sags , your eyes adjust , unless its terminal sag [ thermal run away ]
Emitter turns blue , severe output sag [ 90% or more ] and the emitter begins to emit smoke [ cos its cooking ]
Yeah = Been there !
Foy
Foy's picture
I've got a light meter.  I bought it on Match's recommendation so I could build a light box, sphere or whatever.
Heres some more fun with this drop-in . . .
This is with a fresh charged Solarforce 2400, installed in the light 10 minutes after it came off the charger.
Medium on the left and low on the right.
And this is what happens @ 5 amps after six or seven minutes.  Ever tried to pick something up that is 160 degrees?  I don't know why I find this kind of stuff so fascinating.
butIdoFoy
                      &nbsp
Ian2381
Ian2381's picture
Last seen: 4 years 5 months ago
Will this driver be a good swap to my Trustfire X9 driver or C8? or is the current too much? Thanks
Foy
Foy's picture
I'm not sure what to think about this driver.  I have an underwhelming SST-50 and I'm wondering how it would do with this bad boy behind it.  I guess I don't understand why they would make a drop-in like this.  Is it because they thought the warm tint looked dimmer, so they drove it harder?  When you look at Match's chart thing he did a while back, 5 amps over 3 amps doesn't net you many more lumens.  But, it does give you more heat and less run time.
This noob just doesn't get it.
Foy
                      &nbsp
old4570
Not design , luck of the draw .....
benckie
benckie's picture
Last seen: 8 years 8 months ago
yeah i would stick that driver in your 2.5 amp SST-50 and the driver from that in this. as 5 amps is nuts, but with my luck if i brought the same drop in and the same batteries i would be lucky to get 2 amps lolls but i rather under driven for run time and heat and i dont like the warmer tints im crazy like that.
p,s nice pic,s as always
janko.hrasko
the vf of that warm white xml has to be really low so voltage sag of the battery isn't enough
it actually hurts the lumen output because of the heat in p60
i bet you would get more flux with 8amc driver
CheapThrills
CheapThrills's picture
Last seen: 2 weeks 4 days ago
If a phospr coating is taking the "wrong" tint away from a regular emitter, why not use just a basic lens-filter to get tint right?
Does anyone use them?
M3TAL_L0RD
M3TAL_L0RD's picture
Last seen: 7 months 2 weeks ago
I use Lee Filter in my UF-2100.
janko.hrasko
more photosphor doesn't just remove the blue spike but converts it to lower frequency light so it does improve the color rendering too
2100
oldbobk wrote:
2100,
       I've been fooling around with XP-G R5 4Cs, and the difference between them and a cool white is not that high, as measure by my luxmeter. At 72" I got 625 lux with a C8 cool white, and 600 lux with the 4C tint.
        Bob K
My experience with the DRY and 1A, 5A3 tints is pretty noticeable.  Like 16%.  So WW is pretty significant.
My Balder BD-2 WW, actually it's the higher range of the WW I believe it's like 3500K (Should get the cam out to test)...it takes in 3A at the tail and gets me only approx 500L OTF initial lumens.  Ric listed it as NW, but it is pretty warm.  Luckily i am sort of a "I Like warm lights" kinda guy.   My Yezl M7X CW easily gives me 650 OTF lumens initally same form factor but of course slightly different drive levels.
2100
Yeah...guess so.  I am putting it too simply.
Same thing at work for the fluorescent tubes?
