Well first you were talking of a 21700 flashlight, a battery which almost nobody has, and now 21350 which doesn’t even exist.
Why would people buy a 21700 flashlight if they have plenty of 18650s and 26650s already, which are still better (power density) than any 21700 batteries that are available atm.
Stuff like dedomed LEDs, unibodies, magnetic chargers, etc. manufacturers simply won’t do for multiple reasons, the first often being cost.
Unless there is something special about the light, like super low cost, extreme throw, high lumen output, etc. it’s not going to draw in the thousands of buyers needed to create a new flashlight from scratch.
It needs to stand out in order for a manufacturer to jump on board with the idea.
It’s not cheap to bring a new product into production.
There is far more work involved than making a drawing a couple pixels big, and all the work needs to be paid off in sales.
If it can’t make the sales for whatever reason then you’re left with either building it yourself (like I do with my lights) or paying someone a lot of money for a one-off.
Just an off topic note:
Power density of current 21700’s is the same as the 18650 since it’s just a bigger version of it. The 26650 has lower power density since it’s not made by a major battery company.
The highest I’ve seen available is 4800mAh, which is lower power density than a 3500mAh 18650.
Also 26650s still have much more capacity than a 21700, so unless the goal is a super compact flashlight, if you care about runtime you will go with 26650 over 21700.
If you care about power density more than runtime then you would get an 18650.
I looked for 2 fairly new cells with the same continous discharge rates in order to make it as comparable as possible. Apples to apples, so to speak.
Samsung 48G – 4800mah 10A
This 21700 cell has a volume of 24.25mm3.
This equates to 198mah/mm3
LG MJ1 – 3400mah 10A
This 18650 cell has a volume of 16.54mm3.
This equates to 205mah/mm3
So they are pretty much the same – power density wise. The 21700 is about 47% bigger and has about 41% higher capacify. It’s not an exact scale up, but almost.
It seems Tesla is predicting their new 21700 will have a capacity of 5700-6000mah! I have not seen any batteries with that much capacity. Not yet, at least.
If this turns out to be true, then the power density will definetly exceed the 18650.
So far, I really like this quote from John Peterson.
“Batteries are chemistry in a can and changing the size of the can does not change the energy density or cost of the chemistry inside the can.”
In looking at my older quote above, I checked HKJ’s review of the MJ1 3500mah and it seems it’s capacity is closer to 3200mah and it’s max continous discharge is 7A.
His test of the 48G shows a capacity of around 4650mah and 10A continous.
These may not be the ideal batteries for comparison, but the power density is pretty much the same.
48G – 192mah/mm3
MJ1 – 193mah/mm3
OK. I see that these proposals were not taken quite like I meant them to be.
They were meant to serve 2 purposes:
act as showcase of a certain construction
be actual, direct proposals
I see that they are seen only as the latter. I’d like to explain the former now.
My main driver when drawing those lights was the goal of having lights that are high-quality, small, powerful, efficient, feature-rich. And cheap.
Do these lights deliver?
Yes and no.
Efficient? They won’t chase Zebras.
Cheap? Not. But not expensive either.
Feature rich? Smart-light makers beg to differ.
Powerful? A mere pop can light delivers way more.
Small? 10180 collectors will laugh.
High quality? BLF has a good track record so far.
Each of the qualities mentioned is relative. But I believe their combination is unprecedented.
Efficient? A bit more than the current BLF lights.
Cheap? There is nothing inherently expensive in those lights. Though features do add cost. Still, I believe the costliest part is R&D. Which is a part of the reason why I drew a family of lights – some costs are shared.
Feature-rich? Charging becomes common. Powerbank is a natural extension, but still rare. Firmware features? BLF shines here.
Powerful? There is literally nothing on the market to challenge them on performance-to-size.
Small? Few lights offer better battery-to-body-size. And all of them sacrifice both features and performance for that.
The key reason why they can pack so much is so little space is a combination of:
1. LD4/TC style driver
delivers lots of current
delivers lots of regulated current
takes little board space
has no high components
is fairly inexpensive
is slightly more efficient than other linear/linear+FET drivers. Little less than induction based ones. High-vf LEDs help efficiency.
2. Driver integrated with LEDMCPCB
3. Button and magnetic charging port in the front part of the head
That’s it. Every other decision I made when drawing those lights is not a key one.
Though some further decisions seem to come naturally from this:
1. Unibody….better heat transfer. Why not?
2. You need quite large MCPCB to fit all the components. This means that the head will have much larger diameter than 18650 battery. Therefore I believe going smaller than 21 mm diameter doesn’t really make sense. But going up, to 26650, to 32650, to 4*18650 is just as fine with me.
I simply picked the smallest that I believe was good.
But you said 21700 is not so good at the moment. Is it really?
The top of the line 18650 are actually like 3200 mAh at reasonable current (3A to be precise).
The top of the line 21700 are actually like 4600 mAh at reasonable current (3A to be precise).
The top of the line 26650 are actually like 5600 mAh at reasonable current (3A to be precise).
Yes, I do view them as good. Add to that high-current cells like 30T or 40T for those wanting more fun and it becomes very good. By the time the project is done, they should improve further (f.e. Sony is out of the game still).
21350? It is also a bit of why-not decision meant to increase the potential market to include people who want to go smaller. Anyway, it’s not a key choice.
Dedoming? Shaving domes by the thousand is not really expensive. Shaved LH351D shouldn’t cost more than stock XP-L HI. In fact I expect it to cost significantly less. And anyway, it’s not a key choice.
Magnetic connector? Does add some cost. It is a key choice unless we go further up in size.
Yes. But what I started with was the concept of the light engine and I validated it with noone but the highest expert on LD4/TC drivers we have on BLF. Led4Power. Only then I started having ideas of making BLF lights with them.
I assume it can be done to work.
JasonWW wrote:
Plus, how can I swap in a new driver with NarsilM on it? Lol
Indeed, modifiability is severely reduced with such technique. You can flash different firmware. You can swap LEDs to others with same or very similar pad layout. That’s largely it.
All of that to improve size.
Is it worth it? For me – definitely. But I’m not surprised to see a different opinion. Actually I would be shocked if everyone agreed.
It’s still good to know it. Thank you. I really appreciate what you said. Because the fact that you said it means that you care.
Frankly, the silence was depressing. I far prefer negative feedback to nothing.
Agro, please don’t be discouraged from posting your ideas here, in spite of what some may say (or not, as the case may be). I am one of the ‘silent’ followers here. Besides, this is BLF and there is nothing wrong with you posting to this thread. You haven’t hijacked anything just because others don’t contribute ideas of their own.
- The YKK Philosophy
Jason, I disagree with you about TIR lenses. I find if they’re done well, they give me exactly the beam profile I like for walking in my neighborhood at night. Olight S1A is a good example.
I love to see the new ideas, but I find it hard to extrapolate the small images into full products. It’s hard to see how your design is more compact than anything else with those.
You’re among the few who actually expressed attention. And, what’s more, gratitude. This has not escaped me.
Your previous post was a light in the dark. Thank you David.
Thank you too. I have seen these concerns before. Your post reinforces them. I don’t present my ideas as well as I should. I should improve.
I will try……..but if anything comes out of it, we’ll all see……….or not. I don’t feel strong enough to learn CAD now. But I’ll try anyway.
Is it just me or has this thread seem to have turned more into “agro’s future projects” rather than “BLF future projects” ?
This thread started out good, kind of a research area for new project ideas led by someone willing to make some of those projects happen. However, I get the impression it has become something else — a wishing well, a grave for people to toss ideas into, /dev/null.
Maybe people are still waiting for their BLF GT, maybe they saw the mess that happened and aren’t interested in BLF custom projects, maybe they are out of money, who knows.
Half the people who ran the BLF projects aren’t active anymore.
This^
The BLF GT was a great project and produced a great flashlight, but the execution at the most critical times was unfortuneatly shall we say, a bit trying (not from the fault of any of those who stepped up in a storm of issues, hat’s off to all who made it happen, it was just not great to have things bouncing a thousand directions all at once)
To the point of I think a lot of members are at this time saying, the last thing we need now is a new project.
It was a project that became as they say “Became a life of it’s own” and it claimed victims of team members and BLF members at large, the forum has changed since this experiment for better or worse, it is what it is. JMHO
Later,
Keith
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Maybe no more gigantic lights? That is the reason for all those issues.
If a BLF project light is normal sized things should be a lot better. The next BLF light coming out is the FW3A. Let’s see how that goes.
It is a project that became as they say “A life of it’s own” and it claimed victims of team members and BLF members at large,
A small note, I don’t think it claimed any team members. If you are thinking of the Miller leaving, that was due to his illness and personal life needing his attention. Plus other people stepped up to fill in his role.
Was there a different team member you were thinking of?
Maybe I said that wrong.
What I meant to convey is a portion of senior members who had projects in the works or who were regular contributors have seemed to have left the site either temporarily or permanent of just AWOL since the first of the year.
The large influx of youtube, facebook etc. additions has changed the vibe here for sure.
I know, you can’t stop progress.
Thanks.
Keith
Posted this in the lantern thread, but I’d really like to see a microlantern for use in tents that’s ultralight.
Nitecore makes some compact lanterns, like the LA10 or LR10. In case that would be close enough.
There’s also the option of putting a diffuser cone on a regular AA/AAA/16340 light. Then it could serve as both flashlight and lantern. The Olight S1 Mini Ti works well for this, and IIRC it comes with a GitD cone.
I know, I know. Sometimes I’m acting a bit silly. But I can’t help myself. This light is so ridiculous that I just had to draw it. Or maybe it’s not?
This is expensive light. High budget. But there’s nothing cheaper in its niche.
Well, there’s nothing more expensive in that niche either.
Single 21700, CFT-90, FET+linear driver:
It seems like the driver designers on this forum have pretty much concluded that you need a high-powered buck driver to handle the CFT-90. I think this is why no one is really building a single cell flashlight around that emitter.
I suppose if you could get a driver to work well and then match it up with something like a Samsung 30T you would have a pretty interesting light.
I would like to make a donation for all the great work you guys have done, and for all I have learned on this great forum.
I have also bought some of the great BLF developed flashlights, and saved money with coupons etc.
Can I please confirm that this is the correct address to donate to on Paypal:?
The Miller has been pretty busy lately and hasn’t had much time for forum stuff, but I’m sure one of the other members like ToyKeeper or Texas_Ace can confirm things given a little time.
Given the situation with the person who started this thread, would it not be a very good idea to have sb assign this thread to a person active in BLF??
Or, at the very least; remove the donation information as it is now…. (copy & pasted below from post 1.)
wimmm777$gmail.com (replace the $ for @)
This outdated information should not be left active as far as I am concerned.
.................................. "Slow is Smooth, Smooth is Fast" ...................................
The OPTOFIRE - 4.63Mcd aspheric LED flashlight The SYNIOSBEAM - 10Mcd recoil LED flashlight List of the farthest throwing flashlights
Click this to go to signature links. I'm still around, just not reading many new threads.
48G – 192mah/mm3
MJ1 – 193mah/mm3
Yes and no.
2. Driver integrated with LED MCPCB
Agro, your driver/mcpcb idea is what made me loose interest in your design. It just seems to not make any sense.
Interesting. Could you elaborate on that?
Heat is bad for electronics.
I think small is over rated. I find my DQG tiny 7x to be too short. When I hold it, my pinkie and ring finger hang off the back. I don’t like that.
Plus I’m not a fan of tir lenses. They are no good for walking at night.
This is why I have no interest in your design and other similar designs. I just have no use for it. Sorry.
That’s my excuse for not talking about it.
Surely that’s not the reason for everyone here to not talk about it.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Something like 1 x AAA or 1 x AA, 2700k temperature, very long runtime at 0.5 – 3 lumens
This^
JMHO
Later,
Keith
Thanks.
Keith
Cheers to kiriba-ru and Lux-RC.
Hi Miller,
wimmm777@gmail.com
Thanks JasonWW
I will wait for confirmation..
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
