making 3. Batch Texas Avenger "TA" / Bistro HD OTSM drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
196 posts / 0 new
Lexel
Lexel's picture
Kenjii wrote:
Hi,
my drivers came in today. Looks very good.
Can someone tell me where to connect the eSwitch on the 17mm Driver?
Regards
Kenjii
the pads on 17mm size are marked OTC
Lexel
Lexel's picture
Today the last 200 AMC7135 arrived
I reflowed all boards but 4 17mm TA Bistro as I am still waiting for 6 17mm boards from Oshpark
6 envelopes are ready to be shipped but its to late for today
khas
Last seen: 1 month 1 week ago
My driver arrived today, very nice looking driver.
Thanks
DeJaVu
Last seen: 11 months 1 week ago
!{width:100%}http://www.metronixlaser.de/bilder/flashlight/TA_drivers2.png!
Im having trouble decoding these spreadsheets :).
So was my driver shipped last time you posted 12 days ago, or is it due this shipment?
Lowtech
Got mine as well but unistalled, maybe tonight
Lexel
Lexel's picture
NarsilM drivers were shipped later on 6. June
DeJaVu
Excellent, should be here soon then. Cant wait Smile
steve42
Last seen: 9 months 2 weeks ago
Thanks Lexel. Received my 3 drivers today. Impressive. You must have good eyesight to do this!
I’m going to need a magnifying headset of some sort before working with these. Cheers.
steve42
tekwyzrd
tekwyzrd's picture
My drivers were delivered today. Odd how it took twice as long to travel from New York to Ohio as it took to travel from Germany and clear customs.
Tomorrow should be fun. Reflow the xhp70 to the 32mm star, reflow the star to the heat spreader/shim, reflow the brass ring to the driver, and assemble the Chimera. Forward clicky already installed as is the modified button cover. New photos in the Chimera thread tomorrow.
I’m really looking forward to seeing the results of the xhp50.2 and 22mm TA driver in the Convoy L5. I’m reasonably certain I’ll be pleased with the 3a tint and slightly larger hotspot (compared to the xml2 u2 3c it replaces). I prefer a 3d tint over 3c so the 3a should be just a bit cooler than a 3d.
Thanks again, Lexel!
edit: the Convoy L5 was my first ‘good’ flashlight (torch) and though it is no longer produced I know it has unrealized potential. With the TA driver it can be used with 2s 26350 in one battery tube or 2s 26650 with both tubes. The reflector finish produces a really nice beam without rings (xml2) and I feel it is a forgotten gem worth updating. I’ll admit I’m not overly fond of the large stainless bezel but with a few layers of foil to improve heat transfer from the pill it is very effective in shedding heat. If you have a Convoy L5 post your opinions or mods in the upcoming thread.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
solRNY
thanks lexel for the drivers, they works great.
my S70 draws 9.5A TC 4.06V keeppower
my L6 draws 8.3A TC 4.13V keeppower
Lexel
Lexel's picture
Last drivers shipped today
tracking for the last 4
tracking numbers can be seen here
https://www.deutschepost.de/sendung/simpleQuery.html?locale=en_GB
09. June
19. June
MtnDon
MtnDon's picture
Last seen: 3 hours 14 min ago
Mine are already in the post office system in my state and are on their way to my local post office Smile
zifzif
Last seen: 2 years 9 months ago
Dang, really sad I missed out on this. New here and just learning about the TA + Narsil. Looks like exactly what I need for an upcoming mod. I look forward to batch number 4, if you choose to do another!
Lowtech
Think he started a 4th run?
Anyway its just what a big light like the L6 needs.
solRNY
solRNY wrote:
thanks lexel for the drivers, they works great. my S70 draws 9.5A TC 4.06V keeppower my L6 draws 8.3A TC 4.13V keeppower
both L6 and S70 maxed out the dmm limit of 10A at TC with fresh LiitoKala Smile
JasonWW
JasonWW's picture
Last seen: 1 day 21 hours ago
Measuring with a dmm isn’t going to give you the best accuracy. A clamp meter would be better. The L6 with Liitokalas should be about 12 amps.
MtnDon
MtnDon's picture
Mine were waiting for me at the post office when I picked upthis morning! Thanks Lexel
Jensen567
Last seen: 2 years 7 months ago
Got mine last week and forgot to post. They look good. Will be using the 30mm tomorrow when I rebuild my L6 using XHP70.2. Hopefully the current draw is reasonable. My KP 26650s all seem to have fairly high IR numbers, so I think it will be fine.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 days 16 hours ago
You’ll be fine with any 2S set-up, using 26650’s, I run the 70.2 P21A using the Sanyo IJoy and Efest 20700’s 19-20+ amps, in a Jax X6 Hunter, it’s the Lumintop SD75 70.2 P2 1A 2S2P on Sony VTC5A’s at over 23-24+ amps is when the 70.2 turns BLUE in Turbo…. till the batteries wear down a bit…
KB1428 “Live Life WOT
Jensen567
I’ve done that to two 50.2s now. Not sure about the 70.2 as the P2 1A I have used I have been nice to. The M2 30G 80+ CRI is going to go in the L6.
On the 50.2 it seems like a few times going blue is about all it can handle before it starts going blue using lower currents. Then half the emitter goes out.
KawiBoy1428
Yep burned up a few of them 50.2’s, but the 70.2 is hanging tuff at up to 20 amps, Ive since run the older VTC5’s in the Lumintop, just a hint of blue for a short burst, assuming battery sag is kicking in, been working fine for the last 2 weeks, all 4 dies still looking good, 20 amps or less would be my guess for max current draw, if you want it to live some, my KP’s were giving up like 15 amps in the X6 Hunter, so with their high capacity they would be the best all around battery, again just a guess….
Worse case scenario if I toast them, I’ll re-flow the 4-70.2’s I have as spares and use normal batteries! Big Smile
The 70.2 is just Insanely Bright! Thumbs Up
Jensen567
Yeah I have a P2 1A in a JKK36 host running only 4 to 5 amps and even that is almost as bright as my M2 30G XHP70 on DD. I also made a mistake, L6 is getting M4 30G 80+ 70.2, 1 bin brighter than my current 70.
solRNY
just received a ut210e clamp meter today,
measuring with the clamp meter at TC with fresh LiitoKal
S70 draws 12A
L6 draws 10.5A
JasonWW
JasonWW's picture
measuring with the clamp meter at TC with fresh LiitoKala
S70 draws 12A
L6 draws 10.5A
It’s odd they are so different.
Do they both have the same driver?
solRNY
JasonWW wrote:
It’s odd they are so different. Do they both have the same driver?
yes, same driver.
JasonWW
JasonWW's picture
solRNY wrote:
yes, same driver.
Hmm, same batteries?
Same positive wire size?
Maybe someone could give a reason?
solRNY
JasonWW wrote:
solRNY wrote:
yes, same driver.
ah ha! the wire size to the S70 is 18awg, and the wire size to the L6 is 22awg. remembering that i tried to solder 18awg on the L6 but couldn’t do it as it kept shorting with the reflector.
JasonWW
JasonWW's picture
solRNY wrote:
JasonWW wrote:
solRNY wrote:
yes, same driver.
Oh cool! It’s good to know that 22ga can cut exactly 1.5 amp over 18ga.
A trick you can do with the wire is get the solder liquid and then remove the iron and quickly press down on the joint with something flat and metal. It will flatten the joint so that only the insulation will touch the reflector.
Lexel
Lexel's picture
Another solution is to use a Dremel and remove some material on the reflectors base
And use some tape to protect the reflector from dust
Jensen567
Installed my 30mm driver in the L6 today with an XHP70.2 M4 30G 80+ CRI, and a lighted momentary switch. Loving narsil. I did have to file the driver edges slightly to get it to fit the driver pocket, but no big deal. 18ga wire. Haven’t measured current yet, but its super bright. The L6 reflector also blends the tint of these new emitters well, I dont have much color shift at all in the beam.
